Question about Goodman CKL36AR36 Air Conditioner
I have a ckl42-1a, it was running and started sqealing,fan shut off and iturned unit off.any ideas
  • 31 Answers
Yep. Your fan motor just died. Has an automatic shutoff on it to the compressor so you don't burn your compressor up. Call atech to replace motor but get all info off the motor if you can. Cheaper if you buy the motor yourself and just have them install. Just remember, if it is not EXACTLY the same motor, it most likely will not work!
Posted on Apr 23, 2013
I don't have a remote ! if iturn it on it cools but later it turns fan
if you are turning it on using the buttons on the indoor unit it probably has been put into test mode and reaching set point hence the fan only running. i suggest buying a universal remote to solve your problem.
Apr 25, 2016 | Heating & Cooling
Iturned off a Kenmore elite side by side refrigerator for couple days,and rellaced evaporator fan motor.How long takes the fan motor starting work?
If you replaced the fan motor with a new one, it should start working as soon as you plug it in. Are the blades bent and catching on something? The fan should run with the compressor. Did you wire it properly?
Dec 27, 2014 | Kenmore Refrigerators
Belt pulley squeal
Th cam shaft pulley has to be turning if motor running. Maybe fan is equipped with clutch that is bad.
Jan 28, 2018 | Toyota 4Runner Cars & Trucks
Mr slim indoor fan shuts off
Might change the battery on your control. I wish these had a hard wire thermostat not a big fan of the remote can be confusing.
Mar 19, 2013 | LG LS-L1210CL Mini Split Air Conditioner
Fan was running but neither fridge or freezer were getting cold. You could hear the compressor attempt to start every so often. We replaced the capacitor and the relay and the unit cooled down. The...
Hello
Have you checked the thermal overload on the compressor.It should be mounted on the side of the compressor to feel the heat and shut it down if need be.
Usually a disc type.
Jun 16, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Cooling fan is loud . I'm going to replace the lamp in the unit because all 3 lamps are blinking on the front panel. Unit shuts down but I'm wondering if there is a seperate cooling fan in the back of the...
That's probably the Color Wheel you are hearing. When you turn the set on the color wheel has to run, one of the several things that has to happen for the set to come on. The color wheel sends a signal back to the control circuit to tell it it's running. If these sets fail to light the lamp they will shut off and try again, that's why you hear the color wheel start then wind down then start again. The set should try three times before it decides it's not going to be able to turn on.
One way you can tell the difference in the fan sound and color wheel sound is if you can get the set on, let it run for a little while so it gets warm, then when you turn it off the color wheel will start winding down but the fans will continue to run for a minute or two.
Mar 25, 2009 | Samsung HLN617W 61" Rear Projection HDTV
A/C Problems
SOUNDS LIKE THERMOSTAT IS NOT SET UP CORRECTLY THE HAVE TO BE PROGRAMED TO YOU UNIT
Aug 28, 2008 | Honeywell Electronic Programmable...
Weather King question?
check the capacitor outside, if that doesnt work let me know.
Jun 27, 2008 | Weather King 10AJA4801AH Air Conditioner
Fedders Window AC Unit
I would try to start the unit with only the fan running at first. If it stays running then cycle on the compressor and see how it does. If the unit does not operate when compressor is turne on then we have to dig deeper into that.
Aug 13, 2007 | Fedders J Chassis A6J12E7A Air Conditioner
Goodman CKL36AR36 Air Conditioner Logo
43 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
