Question about Bosch 24 in. SHV46C13UC Free-Standing Dishwasher
Bosch SHV46C Bosch dishwasher (SHV46C13UC) doesn't "start". When I start the cycle, it makes a noise but doesn't fill with water. The drain pump is working because I poured water into the basin and watched it disappear. The noise that it's making is a constant low-toned rumble/hum. I sometimes would hear this noise at the end of a cycle when things were working fine.
  • 1 more comment
  • alight9010 Mar 12, 2009
    Thanks! Is this something I could do myself?  I'm moderately handy but have never worked inside of a dishwasher.
    I have been fiddling with the washer a little and I'm pretty sure the sound is coming from the drain pump.  I poured water in and powered on the washer and watched the water get sucked out.  It seems as though the washer thinks it has water in it so it's just constantly trying to drain. Is there some sort of sensor or float that tells it when there's water in the basin?  Maybe that thing is faulty....
    Problem Solved!  Thank you internet!
    I found this thread and followed the advice - now the washer is running its cycle as it should.
  • 478 Answers
Replace the fill valve that sound is it trying to open
Posted on Mar 12, 2009
  • mark milligan
    mark milligan Mar 12, 2009
    Yes, it right where the supply come in from water line.
Bosch SL1501B dishwasher doesn't drain water after the washing cycle. Also with new drain pump. What else could it be?
Check the following.
1. The drain hose has to be discharging at a high enough point to prevent water flowing back into the machine.
2. Make sure your drain hose is not twisted or kinked.
3 . Make sure your drain line is not blocked push a flexible hose down it to dislodge any fat/debris
4.If your drain line discharges into a shared drain with another appliance i.e. garbage disposal make sure it is not blocked.
5. You may have a blockage at the inlet to the pump which would slow down the pumping rate,
Since you mentioned the mushroom shaped float allowing the washer to empty this may be defective.
See the link attached.
Hope this helps.
Crofter
Bosch Dishwasher Does Not Drain
Apr 30, 2015 | Bosch Dishwashers
Bosch dishwasher makes noise but doesn't start
When you start a wash cycle on your Bosch dishwasher and it does not work, stay calm. It could be something simple, especially if you just installed it. Make sure the power cord is connected properly and a circuit breaker did not trip. How to Troubleshoot Bosch Dishwasher That Doesn Fill With Water
Sep 25, 2017 | Bosch Dishwashers
When the dishwasher starts or when water starts to enter dishwasher there is a loud noise.
ther could be something stuck n your drain pump.
the way it works is first the unit drains,the it fills,then it start to wash. now if you hear this noise after it drains then it could be your water valve or after it fills when it starts to wash it could be your circulation pump. it depends on what cycle you hear the noise. let me know if this help by posting 4 thumbs up for this answer, thanks
Feb 28, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Dishwasher: BOSCH SHE43 - pump keeps draining
Your dishwasher is stuck in flood mode. Bosch dishwashers are built with flood switches located in the bottom base pan of the dishwasher. The flood switch is connected to a rod that activates a small interlock switch. When water enters the base pan on a Bosch dishwasher, a Styrofoam puck lifts the rod, activating the flood switch.
When the flood switch is activated, the dishwasher will go into a no-fill, only-drain mode. The drain motor may also run with the door open to the unit. This is definitely a sign there is water in the base pan. This can be caused by the drain being clogged. There are two ways to fix:
1. You can uninstall the dishwasher and tip it forward to about a 45 degree angle to drain the water out of the base pan. (This is probably why Ian Bint's solution fixed the problem.) Be sure to put a towel under the dishwasher first so that the water is soaked up in the towel instead of going all over the floor. Once you've drained all the water out of the base pan, reinstall the dishwasher and begin a cycle. If it fills and runs, you are good to go.
2. You can also unplug the unit, then remove the kick panel at the bottom in the front. (It's attached with two screws.) Then get some old washcloths or small towels and reach into the base pan below the dishwasher to soak up the water. The pan is directly behind the plastic base panel rim. Once the pan is empty and dry, your dishwasher will no longer be in "flood mode" and will run properly.
If the base pan keeps refilling with water and the no-fill problem returns, there is definitely another issue, such as a clogged drain. At this point, you need to decide whether to invest in an expert evaluation by a certified Bosch repairman and make the necessary repairs, or buy a new dishwasher.
Jun 28, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
At the end of the cycle the water is not draining out of the tub. I vac'ed out the water, removed the filters and checked for debris but found non.
Check drain hose first.
If you do not find any blockage, then you will need to access the pump, remove pump hose and look for blockage in there.
If there is no blockage at all, then either the water level switch, a faulty pump (not switching from recirculate to drain) , a wiring problem, or a faulty timer board can be cause the machine not draining.
May 06, 2009 | Bosch SHV46C03 Built-in Dishwasher
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch dishwasher has water in bottom after cycle is complete
Hi
Kindly check for the following :
Check for hose kinks or food plugging drain hose. Start at the drain port exit.
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
If you have recently installed a new garbage disposal, check knock-out plug at connection.
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for any further clarifications.
A Fixya Rating would be appreciated if.
Thanks
Rylee
Feb 13, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
I think I need to check the water pump/motor on my Bosch SHU43C dishwasher. It seems the water enters at the start of the wash cycle but then there is silence through the remainder of the cycles. Water...
Read this page, it may be helpful to you
http://www.repairclinic.com/0088_9_1.asp
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Aug 03, 2008 | Bosch Dishwashers
Bosh dish waher
Does it make the same noise when it's just filling or just when the motor starts? Usually just filling the dishwasher opens a valve and doesn't run the pump. If it makes noise during filling the valve may be getting hot and shorting, or may have a loose connection, or air may be in the water supply line causing the valve to bounce. If it takes a long time to fill the filter may be clogged.
Nov 30, 2007 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Bosch 24 in. SHV46C13UC Free-Standing Dishwasher Logo
1,147 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
