Question about Zenith B25A11Z 25" TV
VIDEO TAPE WHEN PLAYED WAVE AT THE TOP OF THE TV SCREEN
I have a NEC 68cm TV when i play VHS videos but it only happens on some videos which is strange is it because some videos are recorded in a higher frequency.
What happens is the top of the picture waves hard to explain if it was a tree it would bend to the right the horizontal hold does not seen to fix it its like a horizontal problem.
Wayne.
Can you adjust the horizontal pot on the curcuit board
    President:
  • 2,992 Answers
This is a common problem usually seen when playing copy protected tapes. The part of the picture affected is normally off the top of the screen. Sometimes the problem is also due to the VCR itself and differences in tapes. It's also possible for the TV itself to be causing this, although you would probably also notice this flag-waving (that's what it's called) on regular TV viewing if that were true.
Sometimes increasing the height of the picture can push the affected area off the top again. But this can also cause you to lose part of the picture you want. Also, the height adjustment may be difficult to find as it's not something normally used. On some TV's it's a small pot somewhere on the board, but most newer sets have electronic adjustments through a service menu that you need to know how to access.
I'd suggest trying another VCR first and play one of the tapes you know shows the trouble. That might be all it takes. Then consider trying to increase the picture height if it's just a small bit at the top of the screen.
Posted on Mar 12, 2009
I've had a DR-MV5S DVD video recorder & video cassette recorder for years to transfer DVD over to VHS tapes. Something has recently happened where I can't record VHS tapes. Can't play VHS tapes on the...
Register and download the manual for free audio.manualsonline.com
http://portablemedia.manualsonline.com/manuals/mfg/jvc/jvc_dr_drmv5s.html
If it won't PLAY VHS tapes it must have a serious mechanical problem (if it even loads) or its heads are glommed up, so it obviously won't record them either. When's the last time you ran a cleaning tape through it?
Solve the load or playback problem and it will probably record.
Time and poor storage conditions are the mortal enemies of tapes. Store the in a 'played
Feb 26, 2011 | JVC DR-MV5S DVD Recorder/VCR
I have a panasonic NV370 video machine there is sound but no picture any advise on how to fix the problem
If this problem happens when a video is being played back all you need to do is clean the video head. I would use Servisol Video 40. The best way is to take the top off and give it a good clean wherever the tape comes into contact.
May 05, 2010 | Panasonic NV-SJ205 VHS VCR
VHS Video Tape - Picture Roll.
Picture roll is caused by the frame rate being out of sync with the play back device. If the tape was recorded at say 25 f/m and is being played back at 26f/m. If you can, adjust the frame rate until the picture stands still.
Mar 30, 2010 | Philips VRX242AT VCR
Can't record from camcorder to VHS tape on LG Model VCR
ok,uve gone OUT of cam and IN to VCR player?,then press play on cam and record on VCR,u should see whats recording as long as your on your normal video channel
Aug 17, 2009 | LG V181 DVD Player/VCR
Toshiba 26AV502U (new) video dropout if VHS tapeis not perfect
Had problem checked by local outfit called "Circuit Pro"; their analysis was compatibility.
Actual answer was that the Toshiba required a better quality input from "any" VHS source.
I finally took a "less than perfect" VHS tape with me when I returned the Toshiba TV to the store and demonstrated the problem to one of the TV sales people. He played the VHS tape through a display VHS/DVD player to three different brands of TV. The picture was often "black screen" on a Toshiba, but was merely poor quality on the other two brands. I upgraded to a Sony KDL26M4000 from the Toshiba 26AV502U.
Dec 03, 2008 | Toshiba 26HF84 26" TV
Recording from one vhs recorder to another.
If your plan is to copy a VHS movie to a blank VHS tape, the connections would require a 3 wire RCA connector/cable. The unit where the original movie will be played will be the player. Connect the yellow video RCA cable to the VIDEO OUT, the red & white to the AUDIO L/R OUT. On the 2nd unit designated as recorder, slip in the blank VHS tape. Connect the other end of the RCA 3 wire cable to yellow VIDEO IN, the red & white to the AUDIO L/R IN. Connect the RF OUT of the 2nd unit (recorder to the ANT IN of a TV set. Set the TV to either Channel 3 or 4 as the case may be.
If the recorder has a manual selector or via remote, pls verify that it is set to Video and not tuner (or channels) input.
Press Record on the recorder (2nd unit), press play on the 1st unit (player). The TV will serve as monitor to your copying progress.
Hope that this be of some help/idea. Pls post back how things turned out or shoould you need additional information.
Good luck and kind regards.
Nov 11, 2007 | Televison & Video
Video image problem- Blue screen?
If your unit is fairly new,your VCR part might be the problem.Take it back!
If you have this unit for awhile,two things:
1. You need a professional A/V repair guy to clean up and check your VCR head.
2. The rental VHS tape is dirty.
Jul 28, 2007 | RCA DRC8335
Adapter question
There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter. There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR: 1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology. 2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly. 3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds. 4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly. 5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Jvc 200u problem recording to vhs video tape, from camcorder
Yes, if the camera is a US camera then it is NTSC. That would be your problem, you are trying to record an NTSC signal to a PAL video. THe frame rates and resolutions are all wrong. I am even surprised that it is playing back on your TV okay...
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Zenith B25A11Z 25" TV Logo
172 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
