Question about Bosch Water Heaters
Bosch YPRM34XB with 76 number flash up
Stop working with number 76 flash up
3 Suggested Answers
  • 234 Answers
SOURCE: I have a bosch YS2433R 'Highflow' hot water
http://homeappliance.manualsonline.com/ex/thread/view/idThread/1696702
Posted on Mar 19, 2009
Solution for a code 10 or 99 (for my own reference as much as anything!)
Hit change and the down arrow on the controller for 3 seconds.
Wait for the controller to beep and display 00 before using the down key to display 93.
Hit the On/Off button until 000 is displayed on the screen.
Press change and down simultaneously and the controller should revert to the pre set temperature. Hey presto! Hot water!!!
Posted on Aug 29, 2011
I have Model PTG2-42PVN it shuts off and the remote flashes C7 and 76. What does this mean???
Could be the remote control. Disconnect remote and see if tankless works fine.
Probably bad PC board. Rheem will send new board and you can install yourself.
Bad PC board is kind of like the motherboard on your computer, so expect same level of performance after replacing motherboard ... which usually means the computer's days are numbered before another major problem.
Copy following links:
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Sep 18, 2012 | Water Heaters
Code C8-76?
PC board is probably bad.
Rheem, Richmond, Ruud, Paloma, etc will send you another PC board, and hopefully the success rate will equal success rate of replacing motherboard on your computer.
Before calling service technician, copy following link for troubleshoot resources:
Aug 02, 2012 | Rheem Water Heaters
Getting a 76 flashing on my Paloma PTG-74XP tankless water heater
Error code 76
http://waterheatertimer.org/pdf/Rheem-Tankless-Fault-codes.pdf
Open following link for Rheem/Paloma/Richmond/Ruud tankless troubleshoot resources including error codes, self help, manuals, parts links, tips, and contact information.
Read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 30, 2011 | Rheem Paloma PTG-74XP / RTG-74XP Liquid...
I have a bosch YS2433R 'Highflow' hot water system. It has a YPRM34XB controller. The controller constantly flashes the number '99'. My home has no hot water. How do I fix this error on the controller so...
Nov 01, 2010 | Bosch & Tankless LP Hot Water Heater
C4 flash 76
I had the same problem so i called Rheem at 1-800-432-8373 and spoke to a technition who told me that error code C4-76 meant that the mother circut board was shot and they were going to overnight me one and also send a contractor to install it all for free! Feel free to call them with the model number and serial number and they'll do the rest.
Your Welcome
Oct 30, 2010 | Rheem EcoSense by 7.4 GPM Tankless Water...
My tankless remote digital controller won't go above 76 degrees F
76 is an error code. Look in the owners manual and it will tell you what the problem is.
May 31, 2010 | Rinnai Digital Remote Water Heater Control...
FLASHING CODE C-7 WILL WORK FOR A WHILE THEN STOPS
disconnect the remote and see if the unit works properly; could be lost comm. between the burner control module and the burner assembly.
If your getting error code 76; contact Rheem customer support at (800-432-8373) and notify them IF you are getting a code "76" error
Mike...
Nov 15, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
FLASHING C4 76
Had a Ploma unit - same as Rheem. Not sure what C4 is...but code 76 is lost comm between the remote control and the burner control module. Unplug unit = take front cover off...their should be a square circuit card assemble in front of you. Top blow capacitors are typically used in todays electronics, and they have an obvious curve if the capacitor is blown. If the caps appear swolen on the top they are blown. STOP! If your unit is less than 5 years old..contact manufacturer for defective power supply. This particular problem is known to the MF...If you have a Poloma/Rheem they send you step by step instructions on how to replace this board yourself...if you're slightly technical you can do this repair yourself.
Oct 26, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Water Heaters Logo
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
