Question about Sharp UX P200 Plain Paper Thermal transfer Fax
Can't AUTO RX fax but can send ! ! ! ! If that works, then the fax auto settings are not set properly. Do you have the service manual? Do you have de RAM clear procedure? If posible the ram clear in this equipement? Read the receiving fax section but not found answer! this particular model have same auto RX setup problem?
In Option Setting turn off distintive ring choose numer 5 and start to store and thats it.!!.
Posted on Sep 29, 2009
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 121 Answers
You can try this:
http://www.sharpusa.com/files/fax_man_uxp200.pdf
hope it helps
Posted on Mar 14, 2009
How do I set the Fax 2910 Brother to print a fax confirmation each time? Thanks
Using the Reports Key
Five reports are available:
1 HELP LIST: Prints the Menu Table so you can see at-a-glance how to quickly program every menu selection.
2 AUTO DIAL: Lists names and numbers stored in Speed Dial and One Touch Dial (FAX models only) memory, in numerical order.
3 FAX ACTIVITY: Lists information about the last 200 incoming and outgoing faxes. TX means Transmit; RX means Receive.
4 TRANSMISSION: (CONFIRMATION) Prints a Transmission Verification Report for your last transmission.
5 USER SETTINGS: Lists settings for GENERAL SETUP, SETUP RECEIVE, SETUP SEND, SETUP REPORTS, and TEL SERVICE.
The settings for REMOTE FAX OPT are included.
Jan 18, 2011 | Brother IntelliFax-2820 Laser Fax
I am unable to send a fax brother intelifax 775 fax manual
go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 24, 2010 | Brother IntelliFAX 775 Plain Paper Thermal...
My machine (1020) will not except incoming fax's Why? Do I have to set up machine differently?
Some machines have a three answering modes.
1-manual-you have to pick up the fax headset and then press send when someone calls you with a fax.
2- auto-The machines answers the phone line when it rings and receives the fax automatically.
3-answer- the machines acts like a voice answering machine only.
Check your display or user settings to see that it in in AUTO RX or receive mode. .
Hope that helps.
Jan 17, 2010 | Brother FAX-1020 PLUS Plain Paper
I cannot receive faxes. The machine rings, the
check to see how the rx mode is set up as it may be set to manual it should be auto.. this means if a fax comes in you will have to lift phone or pressthe start button to receive the fax in manual mode whereas the auto or fax mode will turn the fax on automatically
Aug 13, 2009 | Office Equipment & Supplies
We have dial tone and cant recive faxes but can send them HELP
check the setting on the display hasnt been changed to manual or tel settings it should have a RX mode this need s to be set to auto or fax mode otherwise you will have to keep lifting reciever and then press start button torecieve faxes
Jul 28, 2009 | Office Equipment & Supplies
Won't receive faxes
Make sure the receive faxes button is set properly. If it is not set to fax only, you will need to manually receive faxes, the machine will not auto answer.
Dec 11, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother Intellifax
Not familar with MNL, does sound like you have the receive mode set to manual. set to auto anser or answer machine. In manual mode the phone will ring until you tell the fax to receive. In auto mode after so may ring which you set, the fax will pick up...
Aug 28, 2008 | Brother IntelliFax-2820 Laser Fax
Telephone callers get fax sound even when fax is in manual
Sounds as though you are answer ing a phone that is not connected to the unit and you have the Man/Auto switch set to on. Press Function then Data Registration press Set using the > scroll to RX Settings press Set scroll to Man/Auto Switch make sure it is turned to Off.
Apr 21, 2008 | Canon FAXPHONE L80 Laser
Pixma mx 310 fax auto
enter rx settings and select teleline as fax priority.
Mar 30, 2008 | Canon FAX-JX200
Not receiving faxes.
If you have had a power outage or spike, it may have reset to factory settings.You have to go into you menue and find the fax settings mode. Go to the receive,make sure it is set to auto.If not you may have a tx/rx board problem.
Oct 18, 2007 | Office Equipment & Supplies
Sharp UX P200 Plain Paper Thermal transfer Fax Logo
370 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
