Question about Acer Aspire 3680 Laptop
''NEED TO REMOVE THE KEYBOARD ON A ACER ASPIRE 3680 2233''
I'm trying to remove the keyboard on my laptop with out breaking anything? I have removed the keyboard on other laptops this one is different not sure how to get to the screws can you help..?? ''NEED TO REMOVE THE KEYBOARD ON A ACER ASPIRE 3680 2233''
  • thord_one Mar 12, 2009
    Thank you I did that before it still does not release the keyboard I have all the screws out that i can see it seems there are more screws under the keyboard that i can not get to is there a plate along the top of the keyboard that pops off
    Nic thank you that was the solution I just had to b a little rougher around the hinges and the plate came off thank you! thank you that was the solution I just had to b a little rougher around the hinges and the plate came off thank you!
    President:
  • 1,073 Answers
Remove the screws on the both hinge,be carefull when you revove the keyboard backwards, its all plastic and verry verry easy to breake.
Nic
Posted on Mar 12, 2009
  • Nicolas
    Nicolas Mar 12, 2009
    U welcome my friend:)
    Maybe you can reconsider to change the rating you gave me to? ;)
    Anyway, im glad that i could help you solve your problem
    Nic
How do I remove acer aspire 9810 keyboard,I have removed the base cover and screen assembly but I cant fugure out how to remove the keyboard Thanks in advance Peter
to remove the keyboard, remove the screws at the back of your laptop. Then remove the Hard drive, then remove the Optical drive then remove the video card, and then power supply. Then remove the fan from the motherboard and you may remove the screws on top of the keyboard. Finally you may replace the keyboard.
Jul 15, 2010 | Acer Aspire 9810 Notebook
Acer Aspire 5602WLMI water in keyboard
Here is a great deal on a replacement keyboard:
http://www.sunvalleyus.com/AcerKeyboard/Acer-5601AWLMi-5602WLMi.html
To replace it, first of all, remove the power connector and the battery before you do anything on that laptop.
remove the 3 screws in the middle cover. remove that middle cover by putting a screwdriver in one of those holes which are covering the displaybrackets. pull it up slowly. same thing goes for the opposite side.
remove the 2 screws which are holding the keyboard and the cable to the mainboard.
Reassembly is the reverse of dissasembly, be careful with the ribbon cable as its fragile, and there is a little plastic piece that either pulls up or pulls out that releases the cable.
One of the easiest repairs to a laptop there is.
Jul 06, 2010 | Acer Aspire 5602WLMI Notebook
I like to know how to remove the keyboard for my acer 5050 laptop?
Hi there.
Push the screen back
Lift up the keyboard bezel using a small flat-head screwdriver.
Continue removing the bezel with your fingers.
Lift up and remove the keyboard bezel.
Remove two screws securing the keyboard.
Lift up the keyboard and place it on the laptop cover so you can access the keyboard cable connector.
Unlock the connector and pull the cable.
Remove the keyboard.
Good luck and thanks for choosing FixYa!!
Jul 14, 2009 | Acer Aspire 5050-3242 Notebook
I need to replace the keyboard on an Acer Aspire 3680 series laptop
Hi there.
Remove the laptop battery and the AC power supply, open the lid as far back as you can take it.
Get a small flat headed screwdriver, now, you have to take off the keyboard bezel, this is the strip of plastic above the keyboard with the power button on it, the best way to remove it is to start by the on/off button by gently prying the bezel up from the lid hinge, once you have one side out gently pull it up using your fingers, it will unclip and lift away.
Next you have to remove 2 screws from the top of the keyboard, these should be visible to you, once the screws are out carefully lift the keyboard up, you will see a ribbon cable that is connected to the motherboard, gently pull the tab up on the connector that the ribbon cable sits in and it should release it and you can now remove the keyboard and replace it.
To re-assemble just follow my direction in reverse.
Please post back with the results and for any additional advice if needed.
Good luck and thanks for using FixYa!!
May 22, 2009 | Acer Computers & Internet
Acer 5720 keyboard replacement instructions ?
Visit following website where you can find clear shot about removing keyboard from Laptop.
Click Here
thought above link is for toshiba but same procedure implements on acers too.
For complete user guide
Click here to download
Please post back if anything changes and rate all the answers.
Apr 25, 2009 | Acer Aspire 5720 Notebook
Instructions for acer aspire keyboard replacement
first of all, remove the power connector and the battery before u do anything on that laptop.
remove the 3 screws in the middle cover. remove that middlecover by putting a screwdriver in one of those holes which are covering the displaybrackets. pull it up slowly. same thing goes for the opposite side.
there you go smile.gif remove the 2 screws which are holding the keyboard and the cable to the mainboard.
Dec 15, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer Aspire 1640z keyboard removal
I don't have the diagram but i can give you direction.
1. remove the power cover first (where power button is), it might have 3 screw that hold, if there is 3 screw on the power cover, remove it first.
2. after your removed the power cover, you can see the screw that hold keyboard. remove that screw and you can remove the keyboard.
Jul 30, 2008 | Acer Aspire 1640Z Notebook
Acer aspire 3000
There are 3 screw behind the laptop, on the back of the screen hinges. Remove them then open the laptop, and with your finger nails, lift the power cover closest to the screen, it will then raise and you will be able to remove the keyboard.
Jul 26, 2008 | Acer Aspire 3000 Notebook
Acer aspire 5610 keyboard replacement
1. you need to remove the power cover (if you see the power button, that what i mean).
2. after you remove that cover, you will see 2 screw that hold the keyboard. Remove both screws.
3. Remove keyboard and replace it with new keyboard.
May 07, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire 3680 Laptop Logo
132 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
