Question about Marshall Amplification Music
How can i fix the reverb on my marshall jcm 2000 tsl 60 head amp it as shop working
Stopped working
4 Suggested Answers
  • 5603 Answers
SOURCE: JCM 2000 TSL 601 MARSHALL AMP TURNS ON NO SOUND TUBES DONT LIGHT
If the tubes are not lighting, either the fuse has blown or the power transformer might have an issue.
Be vvery careful as there are lethal voltages present in these.
If the fuse blew, replace it and try just once as there could be other problems and more damage could be done.
Posted on Sep 30, 2009
PolyrhythmFX
  • 109 Answers
SOURCE: Marshall JCM 2000 dual super lead 50 watt going out on me
Very nice amp!
First off, is the amp getting sufficient power? An unreliable AC current from your wall can affect the performance.
Have you tried the amp with a different speaker? Checked for a loose connection from the amp to the speaker? Is it the correct ohms rating?
Second, are you experienced in electronics? The problem could lie in a faulty solder connection, a bad component, etc.
If you are not confident in opening the amp and troubleshooting it yourself, take it to a audio repairman. Marshall's are some of the easier ones to fix.....
Posted on Nov 24, 2009
guitarmanjoe
  • 336 Answers
SOURCE: my jcm 2000 tsl 100
Geez, how much drive or gain do you need? Maybe you should consider using a sustainer on your guitar if you expect it to be like using an ebow. No amp gives infinite sustain, especially a solid state one. A cheap guitar doesn't resonate well enough to do it regardless of what kind of amp you use. Too much drive takes away the punch attack or crunch and turns the sound muddy which makes it sound cheap, like a busted speaker. Marshall's aren't known for their drive, but for their tone overall. The combination of knowing how to use your effects and layering them in ways would give what I think you want.
Posted on Mar 08, 2013
MY Marshall JCM 2000 100Watt head is quiet TURNED fully on stand by OFF and ready to plug guitar into the INPUT Jack. Soon as I plug into the INPUT Jack cracking noise hissing noise.
I would suspect a bad cable. Also, these symptoms show up if you mistakenly use a speaker cable (unsheided) as a guitar cable (shielded).
Dec 12, 2016 | Marshall Music
I have a Marshall JCM 600 and the clean channel will not work
That probably indicates the channel switching relay is defective and it needs to go to the shop.
Jun 06, 2016 | Marshall Music
Just got a new Marshall DSL40C. The reverb does not work on either gain control or with the footswitch. Why?
Nothing wrong with the amp. Google it- these amps have extremely weak reverb. All of them are the same. It's the one weak point about these amps. And I love mine. I mic it when we gig. Sounds awesome both clean and driven. But you'll have to get a separate reverb pedal if you want "girl crush" or "pipeline" reverb. Don't listen to the above posters. It's the way these amps are.
Nov 30, 2013 | Marshall Music
On the Marshall 5 button footswitch for the TSL, there are 7 wires in the cable, 6 of which are clearly labeled by color on the circuit board in the footswitch. The brown must be combined with another wire...
Only 6 wires are used by the amp. Tie the brown wire to the metal frame to act as shielding if anything. You will probably find that the brown wire either connects to the shell of the connector or to nothing.
Apr 23, 2011 | Marshall Amplification Marshall 5-Button...
Need reverb tank for a Marshall Amp 8280,but don't know what type
Try this website:http://tubesandmore.com/ Look under reverb tanks. Check to see how many springs your old tank has and what size it is. I think Marshall used Accutronic tanks but have a look at all of them. There are pictures and info for each. Hope this helps.
Feb 27, 2010 | Music
Hi my Marshal G15 is making an echoy twang when played loud (& open E chords). does this mean the reverb is broken?
I suspect the vibration when it is loud is vibrating a reverb tank within the unit.
Test this bylistening with headphones and see if you get same sound.
It may be the reverb has a resonance or the cabinet does that is sensitive to your E chords.
The shock mounting of the reverb may have failed to isolate the reverb tank from speaker vibrations... hence the headphone test.
Jan 27, 2010 | Marshall 15 Watt Guitar Amp
Marshall VS65R is powered up it hums
Blown speaker NO (would not get sound at all)
Bad Reverb UNLIKELY (controls would deselect reverb and it would be out of circuit)
Bad preamp tube NO (controls have no effect)
Bad rectifier and/or filter caps LIKELY
Bad power amp POSSIBLE
Nov 29, 2009 | Marshall Mg50dfx 50-Watt Combo Guitar...
Very nice amp!
Nov 22, 2009 | Marshall Mg50dfx 50-Watt Combo Guitar...
Sep 29, 2009 | Marshall Music
Music Logo
Top Marshall Amplification Music Experts
matt martin
matt martin
Vito Vacirca Jr.
Are you a Marshall Amplification Music Expert? Answer questions, earn points and help others
