The programmes do not switch
The water does not drain automatically till the machine is stopped and programmes is switched manually to drain, then water gets drained but the items do not get dry till the programme has switched to again so the programmes do not work
  • 15,935 Answers
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Zanussi zdt 6053 usually will not run full cycle (on any cycle) but stops with constant error beeps. But it is draining ok and sometimes goes full cycle (not often) Any ideas?
Could be anything!
If you suspect that there is a fault then it will be displayed by blinking LED "END OF CYCLE". As the display of failure in hexadecimal code it can flash up to max. 15 times than short pause and after that repeat fault code. You must to count the number of times the LED "END OF CYCLE" flash up.
Example from user manual: Anti-flood device is activated.
- continuous flashing of the indicator light of the running programme
- 3 intermittent audible signals
- 3 flashes of the END OF CYCLE indicator light
(which means "i30" fault code, the cycle is interrupted and the
drain pump switches on).
Possible causes:
Water leakage from the tub - sump and various connections
(pump, upper spray arm duct etc.); floating sensor blocked
mechanically; microswitch faulty; fill solenoid blocked
mechanically; circuit board faulty (solenoid triac short-circuited);
wiring faulty.
26226179-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Could be also:
To cancel a washing programme in progress:
- Open the dishwasher's door.
- Press the programme selection/cancel button for about 3 seconds,
until the indicator light of the running programme turns off and the
END OF CYCLE indicator light flashes, indicating that the running
programme has been cancelled and that the machine has
returned to setting mode. It is now possible to select another
washing programme. If a new washing programme will be
selected, check that there is detergent in the detergent dispenser.
NOTE: only during the drying phase, if the dishwasher's door will be opened and remains open for more then 30 seconds, the running programme will be automatically cancelled and the machine will return to setting mode. This will happen, always only during the drying phase, also when the machine is switched off by pressing the
On/Off button and remains switched off for more then 30 seconds.
Jun 26, 2016 | Zanussi Dishwashers
My maytag home top loading washing machine over fills with water, ie. the switch to stop filling and start washing doesn't go off. I can drain it by setting it to spin.
top loading machines comes with a pressire switch to determine the water level.IT will fill with water till the switch is triggered to stop filling and continue with the next task of washing. there would be a rubber hose connected from the wash bucket to the pressure switch. Check for broken,leaking,bitten by rats hose or probably the switch it self is faulty, which is rather rare.
Aug 24, 2011 | Washing Machines
Front Loader LG Inverter 7.5kg model WM-12330 FB On the last wash it wouldn't drain the water away. Tried 'drain' programme and rinse & spin programme - all works normally till it needs to drain and...
Have you already check your drain clean out? If it's not draining, you'll need to manually drain the washer, via the small hose that pulls out, once it is drained you can unscrew the large clean out filter, and see if anything is caught up in that area.
If all that is clear, it's most likely, you'll need a new drain motor. Also, did you notice if your getting a "OE" error code on the display?
Feb 28, 2011 | LG WM-2277HW Front Load Washer
The functions has stoped but the door is not getting open.the model is hoover nextra.what i should do to get the door open?
switch off at the wall then manually drain the water using the (emergency drain outlet near bottom) if your model does not have one of these turn on and off at wall then set the wash programme to drain only this will be indicated in the manual of on the programme guide on the front panel.
Now your door should unlock once the water is drained.
Feb 28, 2011 | Hoover AL120 Front Load Washer
The washer has stopped emptying and spinning. The pump does not appear top be making any sounds either.It is a hotpoint aquarius
OK... Pessure switch is proberbly stopping the machine from spinning due to the water level in the machine... The pump could have just stopped working, or, the control board could be broken and therefore the pump not getting a supply current, or, the propeller in the pump could be jammed by debris.
1. Turn the machine off, and unplug...
2. Take the drain pipe and lower it to an outside door or other place to safely drain the water away that is still in the drum.
3. Follow the drain pipe till it reaches the pump. Check the lead to the pump to make sure it is properly engaged into its recess on the pump motor.
4. Take the hose off the pump in order to clear any debris and then replace the hose
5. Having done all that, plug the machine in and turn it on
6. Put it onto a spin programme ... The machine should now lock the door, then both pump and spin actions should start... If not, your control board or cabling is at fault
Aug 20, 2009 | Hotpoint Washing Machines
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
Jan 24, 2009 | Indesit W 123 Front Load Washer
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
