Two procedures to be followed at both mafikeng and plumtree border posts
Tip
How to reset nokia mobiles life timer to ''0''
Nokia life timer is a counter that keeps track of the Total call time of your phone. It will show how much the phone has been used, and it?s the best thing to check if you?re planning to buy a used Nokia Mobile.
To see the Total Call Time or the life timer counter, On the standby screen type the following code *#92702689# (Easy way to remember this is ? *#war0anty#). And it will pop up a message that shows the life timer in hours and minutes.
Here is a detailed procedure to make this life timer zero.
REQUIREMENTS:
The following files are required to reset the life timer:
  1. Nemesis service suite link: Download from Here
  2. lifetimer.pm file: Download Here
PROCEDURE:
1. Download and Extract the lifetimer.pm file, and Download Nemesis Service Suite.
2. Install Nemesis Service Suite on your Computer, It won?t take much time.(select the first option)
3. Install Nokia Cable Drivers (No need to install, if you have Nokia PC Suite already installed)
4. Connect The Phone in ?PC Suite? Mode to the PC
5. Open Nemesis Service Software
6. Click on ?Scan for new Device? Button on Top right Corner
7. It Will take a few seconds to scan, and it will load up the software interface after communicating with the Phone.
8. Click the ?Phone Info? Button.
9. On the Bottom, Select and open the ?Permanent Memory? Tab, which is next to the Fbus info.
10. Click the ?Write? button on Below right, and open the Extracted lifetimer.pm file on your PC.
11. After the lifetimer.pm file is opened , it will immediately start writing it to the Phone?s EEPROM Area.
12. The Procedure will end when the progress bar reaches 20%. This is normal , and on the bottom right side, it will display its done.
13. Unplug the Phone, and Restart it.
14. After boot up, Check the life timer .
Note: This method has been tested on following devices: Nokia 6630, 6670, 6680, 5500 sport, 5700XM, 6110 Navigator, 6120 Classic, N70, N72, N73,N76, E50, E51, E61i, E65, N80, N91, N95, N95 8GB, 5800XM Mobile devices. If you want to try it on other S60v3 or S60v5 mobiles, do it at your own risk.
Caution:
  • Power Failure During Writing will cause damage to the Phone, And there is a chance that it might brick the phone as well.
  • Loose, worn out Data Cables Might fail the Writing process, and there are chances of damage to the EEPROM area of the phone.
  • Do not attempt this with phones that are not included in the confirmed list.
By:- Mohammed Abdulhadi
on Jun 21, 2010 | Cell Phones
I purchased a book on January 27, and I inadvertently deleted before I read it. how can I get it back
Accidentally Deleted a Book .cdPopoverMessage { overflow: auto; max-height: 200px; _height: expression(this.scrollHeight > 200 ? "200px" : "auto"); /* IE */; } .cdPopoverMessageHeader { font-family: verdana,arial,helvetica,sans-serif; font-weight: normal; line-height: normal; } .cdPopoverMessageSignpost { color: rgb(153,153,153); } .cdPopoverMessageAttributes { color: rgb(95,95,95); } .cdPopoverMessageBody { font-family: verdana,arial,helvetica,sans-serif; font-weight: normal; padding-left: 2em; padding-right: 2em; } .newSinceLastContent { color:#009900; font-size: 9px; margin-bottom:10px; padding-left:2px; } .newSinceLastImage { float:left; } .fontGrey { color: #797979; } .cmPage em { font-weight: bold; font-style: normal; } .postOfficialSignpost { padding: 6px 15% 0px 17px; } .postBody { padding: 3px 5px 5px 5px; margin-left: 8px; } .postHeader { font-size: 9px; padding: 10px 10px 0 0; text-align:right; } .postFrom { padding: 0 0 7px 0; } .postFromBadges { padding: 1px 0 0 19px; } .postEditNameLink { font-size: 9px; } .postContent { line-height:140%; padding-top: 2px; padding-right: 15%; padding-bottom: 8px; padding-left: 17px; font-family: verdana, arial, helvetica, sans-serif; font-size: small; } .postFooter { padding: 0px 10px 0 17px; } .postFooterRight { font-size: 9px; text-align:right; } .postFooterLeft { float: left; } .postRating { margin:3px 10px 0 0; font-size: 9px; text-align:right; } .postFooter, .postRating, .postHeader { /* color: #666; */ } .postBody em { color: #c60; } .cdReplyLink { padding-top: 0.5em; border-bottom: 1px dashed; display: block; } .cmPage .cdReplyLink a:hover { text-decoration: none; border-bottom: 1px dashed #c60; } .cdReplyBox { clear: both; display: none; margin-top: 0.5em; } .cdEditBox { clear: both; display: none; margin-top: 0.5em; } .cdPostBoxHeader { font-weight: bold; background-color: #dbedf9; padding-left: 12px; padding-top: 5px; line-height: 1.6em; font-size: 10px; } .cdPostBoxOuter { background-color: #dbedf9; padding: 0em 2em 0.2em 6em; border-bottom: 1px solid #b4c9e8; } .cdBoardViewerBevel { clear: both; margin-bottom: 1px; border-bottom: 1px solid #a1bed3; } .cdPostBoxBucket { background-color: #dbedf9; border-bottom: 1px solid #a1bed3; padding: 0.5em 0; } .cdPostBox { /* width: 90%; margin: 0 auto;*/ padding: 0 12px 0 12px; } .cdPostBox form { margin: 0; padding: 0; } .cdPostBox textarea { width: 100%; -moz-box-sizing: border-box; -webkit-box-sizing: border-box; box-sizing: border-box; height: 8em; font-family: verdana,arial,helvetica,sans-serif; font-size: small; _font-size: x-small; line-height: 140%; } .cdPostBoxInputs { float: left; _height: 30px; } .cdPostBoxInputs input { margin: 6px 0; } .cdGuidelinesLink { margin: 0.5em 0 0 0.5em; font-size: 0.9em; float: right; } .cdEditBoxAttribution { padding: 0em 1em 1.25em 1em; } .cdClear { clear: both; height: 0; line-height: 0; font-size: 0; width: 100%; } .cdIgnoreStatus { display: none; color: #c60; font-weight: bold; padding: 0; margin: 4px 0 4px 0; } .jsDisplayTog { display: inline; } .cdPostError { color: red; } <style> .jsOffDisplayBlock { display: block; } .jsOffDisplayInline { display: inline; } .jsOffVisibility { visibility: visible; } .jsOnDisplayBlock { display: none; } .jsOnDisplayNoneBlock { display: block; } .jsOnDisplayNoneInline { display: inline; } .jsOnDisplayInline { display: none; } .jsOnVisibility { visibility: hidden; } .jqOnDisplayBlock { display: none; } .jqOnDisplayInline { display: none; } .jqOnVisibility { visibility: hidden; } .jqOnDisplayNoneBlock { display: block; } .jqOnDisplayNoneInline { display: inline; }< /style> <style> .jsDisplayTog { display: none; } .cmPage .postBody .postFrom .iconImg { visibility: hidden; }< /style> .cdPostError { color: red; } .cdCommentPostBox .fontGrey { color: #AAAAAA; } .cdCommentPostBox .fontRed { color: #FF0000; } .cdNonReplyPostBoxBevel { clear: both; height: 0; font-size: 0; width: 100%; border-bottom: 1px solid #a1bed3; margin-bottom: 1px; } .cdNonReplyPostBoxHeader { font-weight: bold; background-color: #dbedf9; padding: 5px 12px 0 12px; font-size: 13px; } .cdNonReplyPostBox { padding: 0.5em 12px; background-color: #dbedf9; border-bottom: 1px solid #a1bed3; } .cdNonReplyPostBox .tiny { font-size: x-small; } .cdNonReplyPostBox a { text-decoration:none; } .cdNonReplyPostBox a:hover { text-decoration:underline; color: #c60; } .cdNonReplyPostBox em { font-weight: bold; font-style: normal; } .cdNonReplyPostBox div.cdFormRow { width: 100%; clear: both; margin: 0; } #cdNonReplyPostBoxForm { margin: 0; } .cdNonReplyPostBoxInputs { margin: 6px 0; } .cdNonReplyPostBoxInputs input { margin: 0 6px 0 0; } .cdNonReplyPostBox .cdPromptWrapper { text-align: center; float: left; } .cdNonReplyPostBox .cdGuidelinesLink { margin: 0.5em 0 0 0.5em; font-size: 0.9em; float: right; } .cdNonReplyPostBox textarea { width: 100%; -moz-box-sizing: border-box; -webkit-box-sizing: border-box; box-sizing: border-box; height: 8em; font-family: verdana,arial,helvetica,sans-serif; font-size: small; _font-size: x-small; line-height: 140%; } .cdNonReplyPostBox text { font-family: verdana,arial,helvetica,sans-serif; font-size: small; } .cdNonReplyPostBox .cdPromptFor { font-size: 9px; } .cdNonReplyPostBoxMsg { padding: 0.5em 12px; background-color: #dbedf9; border-bottom: 1px solid #a1bed3; font-size: x-small; } .cdNonReplyPostBoxAddedToThreadMsg { font-weight: bold; color: #cc6600; } .cdNonReplyPostBoxOtherMsg { color: red; padding-top: 0.5em; } .cdPageSelectorHeader .tiny { font-family: verdana,arial,helvetica,sans-serif; font-size: x-small; } .cdPageSelectorHeader a, .cdPageSelectorPagination a { text-decoration:none; } .cdPageSelectorHeader a:hover, .cdPageSelectorPagination a:hover { text-decoration:underline; color: #c60; } .cdPageSelectorHeader, .cdPageSelectorPagination { border: 1px solid #5c9ebf; padding:6px; height:21px; box-sizing: content-box; background: url(http://g-ecx.images-amazon.com/images/G/01/nav2/images/gui/tile-blue-bg._CB46870869_.gif) repeat-x; background-color: #b7d7e6; margin-top:8px; margin-left: 8px; } .cdPageSelectorHeader .cdPageInfo { margin-top:2px; } .cdPageSelectorHeader .cdPageSort { float:right; margin:4px 2px 2px 2px; } .cdPageSelectorPagination { padding: 4px 0 4px 0; color: #666; text-align: center; } .cdPageSelectorPagination a { padding: 3px; } .cdPageSelectorPagination a:hover { background-color:transparent; } .cdPageSelectorPagination a:hover { border: 1px solid #c60; color: #c60; text-decoration:none; padding: 2px; } .cdPageSelectorCurrentPage { border: 1px solid #c60; color: #c60; text-decoration:none; padding: 2px; background-color:white; } #cdNonReplyPost { margin-top: 8px; margin-bottom: 12px; } .cdMovedMessage, .cdLockedMessage { margin-top: 8px; margin-bottom: 12px; color: #666; } See latest post
Sort: Oldest first ' Newest first Showing 1-25 of 29 posts in this discussion Initial post: Mar 2, 2011 8:35:31 AM PST Andrea Solek says: I was in the midst of organizing my newly purchased books on my kindle yesterday when I accidentally removed one. It was a freebie, thank God. But when I went to re-"purchase" it, Amazon tells me I already own it.
Is there a way to recapture the lost book back on to my kindle? Reply to this post Permalink ' Report abuse
1 of 1 people think this post adds to the discussion. Do you? Yes No In reply to an earlier post on Mar 2, 2011 8:36:22 AM PST ShirleyKat says: Look in your archived items (Home, Menu, View archived items). Just click and it will be back soon. Reply to this post Permalink ' Report abuse
6 of 7 people think this post adds to the discussion. Do you? Yes No Posted on Mar 2, 2011 8:37:02 AM PST J. Harnden says: Sure, go to your archive folder on your Kindle and click on the book you deleted and it will re download it back to your kindle :) Reply to this post Permalink ' Report abuse
3 of 4 people think this post adds to the discussion. Do you? Yes No In reply to an earlier post on Mar 2, 2011 8:37:29 AM PST M. Francis Professor of Kindology says: It should show up under archived items on your home page. Be sure your wireless connection is on, then just click the title under archives.
Or, you can go to Manage Your Kindle right here. Scroll down to the list of books you've bought. When you get to the title, you'll see where you can re-send the book to your Kindle. Reply to this post
Jan 29, 2016 | Tablets & eReaders
Border in each column
Follow this steps to achieve that.
  1. Click on the column you want to have a border, On the Page Layout menu click Borders
  2. On the Borders and Shading window go to the Borders tab not the Page Border tab
  3. Select the borders you prefer then on the Apply to: drop down select Paragraph. Click ok then your done.
May 12, 2010 | Microsoft Windows XP Professional
How to add a border in microsoft word office 2003
To add a border on a page, try the following:
  1. On the Format menu, click Borders and Shading, and then click the Page Border tab.
  2. To specify an artistic border, such as trees, select an option in the Art box.
  3. Click one of the border options under Settings. To specify that the border appears on a particular side of a page, such as only at the top, click Custom under Setting. Under Preview, click where you want the border to appear.
  4. To specify a particular page or section (section: A portion of a document in which you set certain page formatting options. You create a new section when you want to change such properties as line numbering, number of columns, or headers and footers.) for the border to appear in, click the option you want under Apply to.
  5. To specify the exact position of the border on the page, click Options, and then select the options you want.
If you'd like to add a border to a picture, text or webframe, just click on this link for further instructions: http://office.microsoft.com/en-us/word/HP051901201033.aspx
Mar 31, 2010 | Microsoft Computers & Internet
I cannot install page border to microsoft word
Please try the following steps.
  • On the Format menu, click Borders and Shading, and then click the Page Border tab.
  • To specify an artistic border, such as trees, select an option in the Art box.
  • Click one of the border options under Settings.
  • To specify that the border appears on a particular side of a page, such as only at the top, click Custom under Setting. Under Preview, click where you want the border to appear.
  • To specify a particular page or section for the border to appear in, click the option you want under Apply to.
  • To specify the exact position of the border on the page, click Options, and then select the options you want.
  • This should solve your problem. Thanks
    Aug 20, 2009 | Microsoft Office 2003 Basic Edition...
    HELP PLEASE
    Most likely this is an issue with your print margins. Try changing the margins by making them smaller.
    May 29, 2008 | Microsoft Office Professional 2007:...
    HELP
    You may need to adjust your margins so that the bottom border shows. In other words, go to file> page layout>margins and adjust the bottom margin to a lower number, the check print preview.
    If that does not work, try checking the border settings. Perhaps line weight has been set to 0 or color has been set to white or no color for the bottom, causing it to be invisible.
    May 29, 2008 | Microsoft Office Computers & Internet
    164 people viewed this question
    k24674
