Question about Garden
Mcculloch chainsaw m3616
Chain bar oiler not working how to fix it
  • 24 Answers
SOURCE: poulan 2600 chainsaw
check and make sure you have the correct sprocket.is your chain .325,3/8?sprocket has to match as well as chain and bar
Posted on Oct 20, 2008
SOURCE: Chain oiler inop
this is a common problem and requires replacement of the pump. remove the bar and chain, the pump comes loose with a few screws. under it you'll see the filter which could be clogged, but not usually as contaminants are not likely to enter the tank. Small engine shops can order the new pump for you, hope this helps
Posted on Jan 02, 2009
  • 226 Answers
SOURCE: Can't get the chain oiler to work. Using standard bar oil.
You can always put some penentrating oil in the saw oil tube by the bar, spray it in with the plastic straw attatched. Sometimes this will clean things out. As far as the tube being un attatched,,,, taking case apart is usually the remedy - kinda takes a while... :) Hope this helps you, Rick.
Posted on Apr 26, 2009
  • 4088 Answers
SOURCE: how to adjust chain and bar oiler flow
The chain should be adjusted so that the chain can be pulled by hand fairly easily, but doesn't droop from the bar underneath. Oil flow should be set so that a running engine (chain moving fairly fast) will send a thin line of oil off of the tip of the bar (onto a piece of cardboard) with a few moments of running. Hope this helps!
Posted on Feb 27, 2010
Testimonial: "Thanks for advice about oil flow !adjustment needed I think !!"
dontbother10
  • 2220 Answers
SOURCE: McCulloch EB428 chainsaw and the auto oiler won't work
Good on you for what attempted already. I looked at the print and it appears there is a worm gear (item 50) and a driven pump (item 61) behind the clutch. I suspect one of the 2 has failed. I know you have done most of this already But does it ooze with the bar off?
Oil System Plugged:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL).
A link to the only IPL for a McCulloch EB428 follows:
http://www.ordertree.com/modelinfo/MCC/EB428-Chainsaw/139.EB428-Chainsaw.1.59.1.html
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Apr 30, 2010
The oil pump on our electric chainsaw is not working
First remove the chain and bar and inspect the oil slot that lines up with the oiler opening in the side of the engine block. You may find it plugged with impacted sawdust. Next inspect the oiler opening itself for blockage.
Mar 07, 2015 | McCulloch Garden
How to fix chain saw automatic bar oiler?
possibly plugged up with sawdust blow clean with air compressor
Feb 16, 2015 | McCulloch Garden
Chain oiling
yuo need to remove chain and bar.then remove clutch,remove flat plate covering oiler. NOTE:some saws requier a special tool to remove clutch left handed threads inspect oiler .sometimes the sawdust and dirt can be cleaned out and it will start workin again. and sometimes not
Oct 25, 2012 | McCulloch Garden
My chainsaw leaks oil out of a small hole or drain just below the base of the bar. is there anyway to way to stop this
are you sure you aren't talking about the chain oiler system? There is to be a small amount of oil to lubricate the bar and chain.
Jun 01, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I need to know which oil type goes into the oil chamber for the chain on a mac 3200 gas chainsaw, not the mixture...thanks
There really is no exact type of oil that goes into the chain and bar oiler. Each manufacturer usually makes their own, but any chain and bar oil will work. It is a thicker type of oil unlike a motor oil. Just ensure that the bottle says "bar and chain" oil
May 02, 2011 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Chain comes off mcculloch electramac em250 chain saw
Adjust the chain until you can pull on it and it will come away from the bar but will not hang from the bar. If that does not solve your problem then the chain or drive gear is worn out. If the oiler is not working it is for sure worn out.
Apr 25, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
What weight oil to use for a McCulloch electric chain saw with self oiler
Bar and Chain oil, available at Home Centers and Hardware stores. It is 30 weight non-detergent with additives to keep it on the bar and chain. It's less expensive than motor oil by the quart. HTH
Lou
Nov 12, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Apr 19, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
