Question about McCulloch Electrical Supplies
IGNITION COIL FG6000MK
BAD IGNITON COIL NO SPARK
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: i have a generac ix
You engine has a low oil level sensor. If the oil level is low or..... the sensor is bad it will ground the ignition from the coil with the engine switch on. For troubleshooing only disconnect ONE wire from the sensor AFTER you make sure the engine oil level is properly serviced. Then check for spark.
If this does not correct the problem just respond and I will help you.
Thanks for choosing FixYa,
Kelly
Posted on Mar 29, 2011
Troy bilt troubleshooting
-Try replace spark plug first. If still do that then the ignition coil is bad when it's hot.
Good luck
mai
Aug 28, 2014 | Garden
98 ford explorer replaced egnition. Now it wont start. Starting fluid does turn it over. But isn't getting feul
out of fueL, bad fuel , old fuel>?
replace what exactly , ignition parts t are many.
key switch.?
Igniton coil(or coils, or cops or coil packs)
Distributor.
spark wire, (not replaced 1 by 1 = fail..)
ok , the PCM monitors spark and that fails, (even if spark is good)
it will cut fuel. so what did you touch>?
i use a noid light, if pass I check fuel pressure
if noid fails, i find out why PCM is cutting fuel.
check fuses 1st. always. for ever. and ever
Jul 05, 2014 | Cars & Trucks
Opel ignition problem car wont start
does the igniton switch turn or if dont your gonna have to replace it if the switch turns and it trys to start most likely the distributor is bad somewhere could be the pickup coil could be the ignition module get a new distributor and hope that your ignitio coil is still good if not then get a new coil and you may as well buy spark plug wires and spark plugs
Nov 25, 2012 | Cars & Trucks
Mcculloch generator fg7000ma will not start. changed spark plug still nothing
do you have spark if not first check off on switch if good check coil and flywheel for rust if no rust coil is bad
Sep 12, 2012 | McCulloch 13HP 338 Cc Portable Generator #...
No spark on one igniton coil of 2000 Lesabre buick
Hi Glen, If the problem persists after replacing the coil I believe you must look at the cables for an internal broken circuit. Also check the ground connection. If all else fails check the computer. Regards John
Jul 22, 2012 | 2000 Buick LeSabre
I have no spark at #1 from the igniton coil, but the rest have spark. Is it possible for just 1 segment of the coil go bad or is my problem somewhere else?
if the car has a single geel pack that applys power to all plugs yes one side can go bad, Have a mechanic chek it out with an ohm metter.
Feb 28, 2012 | Ignition System for Ford Escort
My 5700 watt 11 HP McCullough generator wont start. I'm getting good gas to the plug but no spark.
The spark coil is bad if you have no spark
Small engine repair. Part is expensive.
Have you checked spark for sure?
1) Spray WD-40 directly into carburetor
If machine has spark, it will fire
2) Is exhaust port clogged with carbon and dirt?
3) Get new spark plug
Pull out old spark plug
Put spark wire on plug
Hold spark plug wire with fingers
Put spark plug threads against metal opening where spark plug came out.
Metal to metal
Pull cord or push starter
Look for spark between metal
No spark, then spark coil is bad.
Oct 25, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
What cause sparkplugs not to fire
A
  1. Faulty coil/coil pack
  2. Faulty or corroded wiring
  3. Faulty spark plugs
  4. Faulty ECU
  5. No fuel in combustion chamber
  6. Faulty security system2_bing.gif, cutting ignition during operation.
Apr 30, 2010 | 1997 Dodge Intrepid
Igniton coil f p0356 primary or secondary circut malfunction what does this mean
Integrated ignition coil on plug
Ignition coil F is cylinder number 6 need to check or replace
Spark plug or coil,
Very rare you have to check PCM pin E39 to see if you have a short in the wire.
Sep 26, 2009 | 2005 Ford Expedition
Ignition Coil for Honda 125 CM /84
The 12v coil on a 6v system will only give a weak spark at best. The coil in the photo should work very well assuming the wires are long enough. Any 6v twin coil should work. If you fit another coil and the bike has spark but will not start, swap the wires at the points. Don't purchase a condenser unless the old one has gone bad. If needed, get a 6v condenser matching the old one.
A “very helpful” rating for this answer? Thanks from Dallas Texas!
Jun 16, 2009 | 2000 Honda CM 125 C
Electrical Supplies Logo
24 people viewed this question
Top McCulloch Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
