Question about Horizon Exercise & Fitness
Lost lubing instructions for treadmill and tool ex wife took them
I need to be able to lube something on the treadmill to get it to work again on a Horizon CST 3.6 model.
  • 1 more comment
  • Anonymous Apr 13, 2009
    What do you oil on a T-25. Where do you oil this treadmill.
  • Anonymous Mar 18, 2014
    my Horizon CST treadmill has a pinging noise. It will shut down after approximately 50 minutes of use and smell hot
  • Anonymous Mar 19, 2014
    P1 flashing after I lube and reset on my horizon RST 5.6
    Problem Solver:
  • 12 Answers
Horizon fitness sells silcone gel lubricant or many stores also carry it.
Gerritt
Serving the Twin Cities
Posted on Mar 13, 2009
Does this norditrack use wax or silicone lube
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
I am assuming you have never waxed your machine before. If this is the case, you should be safe using the liquid silicone lube. When this becomes an issue is if you were using the powder wax and tried to change to a silicone liquid. It would still work, but you would, more than likely, end up with some wax build up on your rollers.
How to Lubricate Treadmill Using Liquid Lube Video
Jan 05, 2016 | Exercise & Fitness
Instructions for lubing treadmill belt
see the video attached. Lube the rollers bearing front+back
God bless you
Oct 01, 2013 | Proform Quick Burn Pro Treadmill with 12...
The treadmill shuts down as I go faster
This happen because the lack of LUBE maintenance schedule
Lube with 100% silicones or wax see your instr. manual
2) Lube the rollers bearing. with wd-40
3) test the drive belt motor.
4) Test the input voltage motor, if there are the motor need repair
see my personal TIPS for motor help
5) Test the output board, for input voltage motor, if there are NOT the board is faulty. see the block diagram
God bless you
Dec 05, 2012 | Precor 9.31 Treadmill
My Reebok v6.80 treadmill turns and lights up but won't go.
1) LUBE the deck belt,you have a WORN deck belt, this happen because you didnot lube according with the schedule maintenance
29 LUBE the rollers bearing too
3) Test the drive belt motor, for worn or crack, or adjust if is possible
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Nov 28, 2012 | New Balance 1400 Treadmill
I lubed the deck. The treadmill still does not go. What should I do??
1)Lube very well the deck belt
2)lube the rollers bearing
3)measure the input voltage motor, if there are the motor need repair
4) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty, see the block diagram
God bless you
Jun 11, 2012 | Exercise & Fitness
My pro form zt3 treadmill is making a noise whenever it's running...I've looked under the hood, but I don't know what's causing that noise.
Dear Sir:Please Lube THE machine in according with the instruction manual maintenance, May be you have a worn Decknad replace it.2) Test the rollers bearing and lube front and rear 3) Test the main motor for bearing Lube 4) Drive belt test and replace if necessary.
sincerely. God bless you
May 03, 2012 | Exercise & Fitness
Treadmill
Dear Sir:
PLease LUBE the deck belt, is possible the deck is worn!
2) Test the drive belt too 3) Test and lube the roller bearing 4) Lube the bearing main motor. All this parts is subjects to maintenance, see your instruction manual.
Run the software calibration for diagnose, and troubleshooting.
May 03, 2012 | Horizon Fitness Horizon T101 9 Program...
I replaced the belt on the Proform 530x and it still sticks. I have also tried to silicone spray the deck,. Help ?
You must LUBE very well the deck belt. 2) adjus the roller bearing and LUBE very well 3) Motor can be LUBE follow the instruction manual for LUBE. 4) Adjust the deck belt see the diagram.
sincerely. God bless you.
Apr 23, 2012 | Proform 530 Treadmill Walking Belt
Does the belt need to be oil merit treadmill 725t
LUBE THE DECK BELT, this produce shut down by lack of maintenance in according with the instruction manual. Maybe you have a deck belt worn.
2) Lube the rollers bearing too in according with the instruction manual.
3) Test the drive belt, and see if need replace or adjust .
Apr 17, 2012 | Merit Fitness 715T Treadmill
What is meant when it shows "lube belt"?
You need to apply lube between the walking belt and the black deck surface. Most manufacturers use silicone lube. We sell a lube kit for our treadmills that includes an applicator and a bottle of liquid silicone.for around $20.
Feb 09, 2011 | Horizon Fitness Horizon T103 Treadmill ...
Exercise & Fitness Logo
536 people viewed this question
Top Horizon Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
