Question about Onkyo HTR500 Receiver
I have a ht-r558, The sound keeps cutting out, untill i turn it right up
Onkyo ht-r530 subwoofer stopped working
Turn the out put leval down on your sub, End the reciever, I was turn up to high,End that will cause it to cut out.
Oct 20, 2012 | Onkyo Ht R530 Receiver 7.1 Surround Sound...
I have an Onkyo HT-R680. I have noticed after about an hour or more while playing Xbox or PS3 the sound will start to cut in and out. 5 secs of sound, 5 secs no sound. Continually like that untill I shut...
I've been having similar problems. I placed small fan to better circulate air in the closet I keep it in and that has fixed the problem so far. So some sort of thermal overload, I suppose?
Feb 23, 2011 | Onkyo Audio Players & Recorders
Samsung LED UE46B7020 tv wont play sound through my HT-C5500
i know this is going to sound stupid but i couldn't get mine to work either after following every instruction to the T. I then rechecked my optical digital connections again and found that I neglected to remove one on the rubber protective endings. I took it off and plugged the end back into my TV and BINGO! THEATER SOUND from my tv!
The Ticket
May 09, 2010 | Samsung HTC550 Theater System
Hard starting when cold cuts out
its an old car have you checked the the ht leads do it in the dark to see if there are any sparks or arcingit could just dampness cut the tips out of a rubber glove thread the leads through the wrist part will fit over the distrubuter that should keep the damp out outherwise change all ht leads
Nov 11, 2009 | 1989 Toyota Camry
Samsung HT-TWZ312 surround sound probs
With the home theater system off, press the 0-1-3-5 buttons in that order on the home theater's remote control.
Power on the home theater system.
With the wireless module on, press the [ID SET] button on the back of the wireless module for five seconds.
If your home theater continues to display rear check after you have tried the steps above, call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Hope this helps!
Jul 05, 2009 | Samsung HT-Q100 System
Keeping the settings permanent
Hello, are you making the changes in the speaker settings section in programming? Thank you, CB
May 24, 2017 | Onkyo HT-S670 System
MGA CS-2657R/2658R
Journeygal,
Check The Following Components Off Ihvt pin 3 For Open: R558 P/N 103p338010, D 553 264p338010, L502 321c030010, R521 1.2 Ohm You'll Need A DMM For The Job And Any Cheap One From Radio Shack Will Work.
Bill
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
Sep 28, 2008 | Mitsubishi WS-55807 TV
Problem w/ surround sound for Onkyo HT-R430
you are in stereo mode which only uses the two front speakers, hit the surround sound button remote or hit the mode button and cycle through until you get to the Dolby II setting
Dec 31, 2007 | Onkyo HT-S680 System
Picture cuts out and sound delays
Wow, I have the same problem. I have even tried using never used DVDS, it just freezes after a while. I will get small glitches every few minutes. I am calling Samsung tommorow and raising hell, this was a Christmas present and I am embarrased. I also use HDMI and have changed the set up to 720P.
Dec 01, 2007 | Samsung HT-X40 System
Onkyo HTR500 Receiver Logo
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
