Question about Dell XPS 420 PC Desktop
Change the volume in WMC doesn´t working...
When i cahnge the volume in WMC with my Dell XPS420 remote Control, the v"olume changes" in the Windows Media Center, but the volume keeps the same. I think i need to program the Remote Control or something to change another output channel or something like that?
    Problem Solver:
  • 11 Answers
If the remote control causes a visible change with the volume control display but no audible difference, there are only three possible fixes. 1.)Go to Windows "Start > Control Panel > Sounds > Advanced. Here you will find a set of several volume control slide bars each with a check box at the bottom for muting. Un-check any controls marked as muted and raise the volume to 50%. Exit Control Panel. 2.) Many P.C. speaker systems are self amplified and have their own volume controls which supercede anything you do through Windows. 3.)If the problem persists you most likely have a jack plugged into the wrong feed. Allways power OFF and ground yourself before fiddling with computer jacks.
Posted on Jan 29, 2010
My remote appears to be the same as a neighbours and their remote is controlling my TV volume, how do I change this?
Not much could be done as both tv works on same frequency as most brands each has its own frequency and covering windows with heavey courtains might help or buying different brand of tv
Jan 13, 2015 | Insignia 98TRASW5NEBYA Remote Control...
Directv remote and LG remote will not control tv, just receiver
Let's start simple first. Your TV is not responding to either remote control, but specifically if your factory original LG remote does not operate the LG TV, then the problem could be with the IR receiver in the TV itself.
Ensure nothing is blocking the IR receiver on the TV. Move anything out of the way.
Test both remotes to ensure that they are sending an infrared IR signal to the TV. Use a digital camera (such as the one on your phone) and point the remote into the camera lense and press the power/volume/channel buttons. You should see a faint flashing light in your camera viewfinder. This indicates that the remote is sending IR signal. If you don't see anything, then there is no signal. Try FRESH batteries.
If your remotes are working, and since this is an LG, look at the back of the TV by the video inputs. Look for a port called "REMOTE CONTROL IN" or similar. It looks like a 3.5mm headphone jack. This port is used for external remote control and may be dirty.
UNPLUG the TV, then use a regular 3.5mm male headphone jack to plug in and out several times. You basically want to push all the way in and all the way out several times to dislodge any dust and remove any oxidation that has built up in the port. 10-15 times should do fine.
Then plug in the TV and try your remote.
Best of luck.
Nov 05, 2017 | LG 32LG30 32 in. LCD HDTV
My remoute control joust change the volume and anyother keys doesn't work.
The remote's volume keys are "punch-thru" keys, meaning they'll work for the TV for which the
remote is programmed no matter what mode the remote is in. It seems your remote is not
in "TV mode," but the punch-thru keys (volume UP/DOWN) are working.
The Solution: change the remote from "AUX mode" or "DVD Mode" back to "TV mode", by
pressing the "TV" button at the top of the remote.
Either that, or your remote keypad has failed with the exception of the Volume UP/DOWN keys....
Also, your batteries may be failing, since it takes a tiny amount of energy to light
the IR (infra-red) LEDs at the front of the remote to change the volume.
Is your remote a "multi-function" remote?
Could help more if you could post your Samsung remote model number, since
www.samsungparts.com lists 37 pages of TV remotes (at 10 models per page).
Jul 02, 2011 | Samsung TV Remote Control
RCA Home Theater RT2906 doesn't respond to Remote
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Have you tried new batteries?
May 16, 2011 | RCA Audio Players & Recorders
My dell xps 420 will not power on. power light
Hi
If your system's power light blinks amber, it means the computer is receiving electrical power, but an internal power problem might exist.
Do the following to tackle this issue:
  • If applicable, make sure that the voltage selection switch which is at the rear of your system matches AC power in your area.
  • Ensure that the power cable is securely connected to system board.
Here are links with pictures to assist you in opening the system and reconnecting the internal cables.
Please follow safety instructions before you perform these tasks. Here is a link, which gives you complete safety instruction.
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/parts.htm#wp1372453
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/parts.htm#wp1372490
Next is to see the system board design. Here is the link.
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/parts.htm#wp1402834
and if you wish to research a bit more here is the link,
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/trouble.htm#wp1076480
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/trouble.htm#wp1097292
Here you will find complete manuals for further research
If this does not resolve the issue, then the motherboard or processor is faulty and you need to get it replaced, so if your system is within warranty why pay extra, get it replaced from Dell. Else contact a local tech and he'll help you out.
Please rate as per the assistance level. Thanks :)
May 21, 2010 | Dell XPS 420 PC Desktop
WMC PC and TV no longer communcating by remote
For the remote : try replacing bateries
Device driver : try reinstalling the tv tuner from the device manager.
Please name you model number of ur pc.
Jun 20, 2009 | Dell Dimension 3100 PC Desktop
Volume control
Hello
If it is just not functioning for volume but do perform other functions then do open in there would be screws or can just be lock's clean the board and pad with cotton dipped into acetone if you don’t have acetone just use the dry cotton if it still doesn’t work change the remote
Good Luck
Oct 25, 2007 | LG 42PC1DA 42 in. Plasma HDTV
Remote volume control for Sharp Aquos 42inch LCD not working
ok please open the remote then clean it with pencil eraser.
Oct 09, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Dell XPS 420  PC Desktop Logo
156 people viewed this question
Alun Cox
