Question about Acer Aspire 3002LCi Notebook
I reinstalled itunes. afterward the audio is
I reinstalled itunes. afterward the audio is mute. it says there is audio configuration problem. how can i fix it? i have acer 3002 laptop. thanks
No sound or audio to my laptop
According to your problem first check the Audio configuration from control panel if the configuration become mute and reset it. If it doesn't help you then uninstall the audio driver and reinstall. You may have to repair or reinstall the OS, because it may be crashed. You can try to recover your problem by restore your system through system restore application. If it can't solve your problem then you have to replace the speaker of your laptop.
Jun 17, 2011 | Computers & Internet
No audio device found on my system and its marked mute
2 possibilities to try. #1) download Itunes (new version) and install - make sure you have volume up via keyboard key looks like speaker with rings to right. #2) try reinstalling your OS. It sounds like you deleted a pce of software that corrupted the OS
Jan 07, 2011 | Apple MacBook Air
No sound at all..
I found several things to check about this issue.
First of all, make sure Windows Audio and Windows Management Instrumentation Services are running. Steps:
  1. Go to start -> run. If your keyboard has a ‘windows key’, which looks like the windows icon and is often located next to ctrl/alt, you can get away with pressing (and holding) this key, and tapping the ‘r’ key. I use this shortcut almost every day. On that note, windows-key+e I use even more- try it.
  2. type ’services.msc’, without the single quotes. This opens a list of the various services running on your computer.
  3. Make sure iTunes is closed.
  4. Locate “Windows Audio,” and see if it’s running. If it is, the status will show ‘Started’.
  5. No? Well guess what, iTunes needs this to be running in order to communicate with your audio device. Start it. There’s a link to start it along the leftmost column. Once it’s started, find a blank area within the services window, right click and hit refresh. Or just tap F5. Has the service died? If not, skip to step 7.
  6. The service died, didn’t it? Look for a ‘Windows Management Instrumentation’ service. This needs to be running for Windows Audio to be running, even though it’s not listed in the dependancies. Fire it up, then fire up Windows Audio.
  7. Fire up iTunes, and enjoy.
Secondly, you can open Control Panel and uninstall and then reinstall QuickTime. You can download QuickTime at this URL: http://www.apple.com/quicktime/download/
Third, you can try to reinstall iTune and allow any settings about playback and audio configuration with iTune during that.
Hope those helps.
Jul 09, 2010 | HP Compaq WF1907 Monitor
I have iTunes on my Dell computer. It worked fine until a month ago, then it stopped working. It say ''iTunes has detected a problem with my audio configuration. Audio/Video playback may not operate...
You're most likely using a RealTech or sigmatel audio card in your Dell. This is a common issue with this card. Uninstall and reinstall the driver and the issue will go away. Make sure you have the correct version for your OS and get the newest version from your site and you shouldn't have any issues with it happening again.
Mar 22, 2010 | Computers & Internet
I have an Acer Aspire with Realtek HD Audio Manager. When I run a test on the control panel, the speakers transmit sound properly. However, anything I've tried to use recently like itunes or sound from the...
Hello
I had the same problem a few months ago, i also looked to see if i saw a mute function that was active anywhere.
I did not find anything so i just reinstalled the application and my problem was fixed. At the link below you can find the realtek audio app. for xp and vista.
Vusta/Win7:
http://www.brothersoft.com/realtek-high-definition-audio-driver-65158.html
Please rate this solution
Best regards
Sep 14, 2009 | Acer Aspireā„¢ T180 PC Desktop
NO SOUND ON DELL INSPIRON 6000 PLEASE HELP!
Try to uninstall and reinstall the Itunes c could resolve the issue.
Apr 01, 2009 | Dell Inspiron 6000 Notebook
I tunes has detected a problem with audio configuration audio/video playback
Go to Start> Run
Type in 'Services.msc' without the quotes.
Find Windows Audio in the list. Most likely it has not 'started', as stated beside each of the items in the list. Click on it, then click 'start'. Re open your itunes and it should be working.
Oct 17, 2008 | HP Compaq WF1907 Monitor
My computer sound doesnt work i think i deleted the sound device how do i get it back ?
go to start, configuration, hardware and see if there is a yellow ! next to your sound device. Ifso, reinstall the drivers. If there is no sound device at all also reinstall the drivers and than restart. Before doing this check if your sound is not muted or set extremely low.
Aug 08, 2008 | Audio Players & Recorders
ATA device code 10 my CD ROM won't start
Yes please uninstal and do the fresh reinstal the itunes drivers
Jun 28, 2008 | Computers & Internet
Acer Aspire 3002LCi Notebook Logo
69 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
