Question about Poulan Garden
Poulan pro 300ex will not restart, unit just died while mowing, ran fine before it died
Unit died and will not restart
4 Suggested Answers
  • 24 Answers
SOURCE: Poulan Pro model 185H42ST dies after 30-45 minutes mowing
Put a carb kit in it. If that does not work replace the gas cap they are supposed to breath and if they get clogged it will create a vacuum in the tank starving the engine for fuel.
Posted on Apr 24, 2009
  • 6468 Answers
SOURCE: poulan pro 300ex riding lawn mower
pull the top cover and see if the starter gear broke if so napa has them for about $10
Posted on May 08, 2012
  • 6468 Answers
SOURCE: I have a 18.5 Poulan Pro riding lawnmower that runs fine untill I activate the blades. It then dies after mowing for a few minutes. I disengage the blades and it runs fine. Any solutions?
does it loose power then die or just shut off?does it run rough then die?try and run it with the gas cap loose th event could be plugged and the extra fuel needed to mow the vent might not be keeping up or a plugged fuel filter
Posted on Jun 09, 2012
Where can i find the serial number on riding mower Poulan Pro 300EX
Usually under the seat.... Sometimes around the battery area as well... older ones would have them on the frame up close to front tires.
Oct 13, 2015 | Poulan Garden
Poulan pro 42 cc 2 cycle chainsaw ignition coils keep burning out
It is not common, but there are so many poor quaility units out there it does not surprise me.
Jan 26, 2013 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Jun 06, 2012 | Garden
Poulan pro 300ex riding lawn mower
May 06, 2012 | Garden
Poulan Pro riding lawnmower 42" 18.5 hp 6 speed It mowed fine. Would not start when I wanted to mow again. Turns starter a little, but not enough to start. Recharged battery--same condition existed. ...
Replace the battery. Even though the battery may say it's good, it doesn't have enough of cranking amps. Go purchase a battery with 350 cranking amps. This will fix your problem. The battery power isn't enough to kick the starter completely up to turn the engine.
Jul 06, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I purchased a poulan pro self propelld lawn mower in May. I went to use it yesterday, it started and ran fine for about 5 minutes. It stalled, so I restarted it and it dies in a few seconds, and now will...
Common condition for this time of year and also 1st mowing in the spring. Debris from the gasoline supply and tank has settled in the bowl or jets of the carburetor.
Float Bowl Carburetor; cleaning main jet
1) remove the float bowl retaining bolt
*this is the main jet ... very small hole in the center of the bolt allows fuel to enter the inside of the carburetor
2) blow air or spray carb cleaner thru the hole in the center of the bolt
3) additionaly you may want to use a small wire (called 'tag' wire) to clean the center hole
4) remove the bowl to drain fuel/debris
5) you may need to replace the gaskets/o-ring for the bowl nut and bowl to carburetor body
*NOTE: for the future and winter storage, a product called StaBil can be used in the fuel storage can all the time, it will help condition the fuel.
Nov 10, 2009 | Garden
Apr 24, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Garden Logo
24 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
