Question about GE / Caddx Networx Programmable LCD Keypad NX148E
My GE Networkx NX-148 has error message fault front door. What can be the problem.
Washer was working.. electicity whet out... when emergency generator came in.. door lock message.. nothin I do works
Why is the "F dl" light come on - Kenmore Elite HE3 ...
https://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...
iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock ... orrepair the following Door Lock Mechanism broken or removed from the Door ... these are usually indications of a failed door latch assembly and will require replacement. ...FdL code would not reset until I turned washer on to start load.
Troubleshooting - Support - Dexter Laundry
www.dexter.com/support/troubleshooting/
Dexter Washer Troubleshooting. Select your problem form the following list to reveal a list of possible solutions and supporting documentation. Constant ... F1 / Door Lock Error Door failed to lock properly. + ... Error Code F13, F15, F17, F19 +.
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Failure Code, Condition, Check/Repair. "F1?, Water ... "F7?, Door lockrelease fault, ?· Bent pull-rod for door latch. ?· Bad door latch ... Water overflow error, Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord. ?· Check wiring ...
Why won't the door open on my Kenmore front-loading ...
Dec 10, 2015 | Washing Machines
Error message dE
hello there and thank you for choosing fixya
dE - Lid door open error Lid /door isnt fully closing or is open during wash cycle. Close lid.
· Check wiring harness
· Check lid switch
· Check unbalance switch
· Check circuit board
Jul 28, 2011 | GE Energy Star WCVH6260F Front Load Washer
Keypad message reading 12volt low battery on three wireless zones. changed out all batteriies and still getting message.
This could be referring to your battery backup for the control panel. Make sure your battery connections are secure and check the batteries' voltage with a multimeter. If it is showing less than 12 volts and has been connected to the control panel for more than 24 hours, the battery is bad and needs replacement. Contact your local alarm company and ask them verify the battery is bad, and they can install a new one for you right then.
Feb 23, 2011 | GE / Caddx Networx NX 8 Control Panel...
How do you retieve the error codes?
All Mitsubishi DLP Televisions have a built in Diagnostic Decoder to store the last fault in memory. This will help the Mitsubishi Technician determine what area or part defect could exsist due to your television not coming on or turning off by itself. In order to read the error code from the front panel lights, you need to know how to access this information if it is available.
Please remember not to unplug the tv from the power outlet because this will reset the error code. The television must be in the power off state or shut off state to retreive the code.
Error Code Operational Check
Note: The TV must be in “Shut Down” and not have been switched Off, to perform the Error Code Operational
Check.
Pressing the front panel “ACTIVITY” and “CHANNEL DOWN v” buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The “TIMER LED” flashes denoting a two digit Error Code, or indicating no
problem has occurred since the last usage.
Note: The front panel buttons must be used, NOT those on the Remote Control. • The number of flashes indicates the value of the MSD (tens digit) of the Error Code. • The flashing then pauses for approximately 1/2 second. • The LED then flashes indicating the value of the LSD (ones digit) of the Error Code. • The Error Code is repeated a total of 5 times.
Example: If the Error Code is “23”, the LED will flash two times, pause, and then flash three times, then this will repeat itself for four more times before the blinking stops. If you forget the code, you can start all over again after the LEDs have stopped blinking. Just remember you are looking for a two digit code, denoted by a pause in the middle.
Example: You are watching Television and after 20 seconds it shuts off with no picture or sound. By pressing on the front panel the INPUT and MENU at the same time starts the Diagnostic Procedure, and the TIMER LED will then blink six times, and then a small pause, then six more times. This is an error code of 66, and will indicate to the Technician a defect in the lamp ignition circuitry. This will help us to order parts for the repairs without guess work.
In addition to the above code retrieval procedure- most new Mitsubishi LCD & DLP televisions have a built in Error Code Log or menu system. To access this feature the television has to be on and have a picture or blue screen to read this fault menu . To read this Error Log in the television you have to use the Mitsubishi remote control and follow this procedure: Press & release the Menu button, followed by 3564 on the remote control. You will see Lamp time, Code & Status. If an error has happened, please read the numbers indicated under Code to our service person or office staff. We can determine by these codes how to handle service on your unit.
Jun 03, 2010 | Mitsubishi WD-65732 65" Projection HDTV
GE WBVH6240 Front load washer. Pump running while empty
you would need to go into the fault codes and read them. the tech sheet should be under the lid or in the kick panel
Feb 07, 2010 | GE WBVH6240F Front Load Washer
ERROR MESSAGE 5F
This fault concerns the relay drive circuit. If this fault code cannot be canceled, replace the oven control (also called clock or ERC).
Jul 26, 2009 | GE JKP15 Electric Single Oven
My washer wont spin
Frigidaire front loader model # GLTF2940ES3.
Cycle ended prior to spin segment. Checked error code history to find E47 fault. Troubleshot per manual. Found that the "PTC one-spot check" read ~1582ohms. Although the book indicates that this is sufficient and recommends (rather tells) you to replace the control board we were still skeptical seeing as this is a ONE POINT check on a device that is non-linear. We went with the lesser of two evils. Purchased and replaced a new door lock. Works again! Phew, that could have been costly.
Aug 02, 2008 | Frigidaire GLTF2940ES Front Load Washer
GE / Caddx Networx Programmable LCD Keypad   NX148E Logo
29 people viewed this question
Top GE Home Security Experts
Sean
Bill
Level 1 Expert
Electro Med Services...
Are you a GE Home Security Expert? Answer questions, earn points and help others
