Question about Marley Water Heaters
Marey electric heater E2 error - Marley Water Heaters
2 Suggested Answers
SOURCE: What are the pros of Marey Power Gas Tank less Water Heater?
The pros of the Marey Power Gas Tank less Water Heater are as follows:
1. Available in propane and natural gas
2. DIY installation process optional
3. Very reasonably priced Does not use electricity but does require a 2 D-Cell battery
4. Only uses gas, when water is turned on (decreases natural gas wastes)
5. Equipped with easily adjustable gas and water knobs
6. Digital display makes it easy to read water temperature
7. Very compact design
8. Works great with low water pressure levels
You can have more information about it like how it works and installation process etc.
Posted on Jun 23, 2017
Jun 23, 2017 | Water Water Heaters
My water heater is a "Marey" propane and the water won't get hot and it keeps saying "E2" I lost my manual so I can't see what that means. Do you know?
An E2 code is often an indicator of an electrical problem inside the water heater. The most common problem is with the inlet water temperature sensor. Often a reset will fix the problem. To achieve the reset unplug the unit. Open the unit being careful of fragile electrical wires. Next remove the computer board and then disconnect each plug in wire and reseat them one at a time. Reassemble the unit and plug it in. It should be in working condition, without the E2 code.
Marey electric heater E2 error Marley Water Heaters
and also another idea here
found this helpful answer from plumber on JustAnswer com
and finally, how I found the answers.
E2 Google Search
Apr 26, 2017 | Water Water Heaters
Just installed, shows error code E2, is not heating water
May 22, 2015 | Water Water Heaters
Error code e2 on Rheem tankless water heater
e2 is not shown among common error codes:
Error e2 might be: Brownout condition or too low of voltage to thermostat. Double check wiring and check for 24 vac between R and C. E2 will clear 15 sec after proper voltage is restored.
Before calling service technician, open following link for Rheem troubleshoot resources including Rheem chat and typical generic manuals and common error codes:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Model number and serial number are required for Rheem contact, and then they tell you what error code means without saying how to fix it, and then tell you to call service technician.
Tankless water heater manuals each say to have qualified technician perform yearly service. Most causes for common error codes are covered by yearly service.
Yearly service is fairly standard in the HVAC and water heater industry with advancement of high-tech 'energy' saving appliances. Of course all costs are energy, and the service call probably costs more that the 'energy' saved by energy-saving appliance. But with high tech stuff like tankless, it is good to have a reliable service guy who knows your machine.
http://waterheatertimer.org/images/Tankless-wiring-1200.jpg
Jul 27, 2011 | Rheem Tankless Hot Water Heater...
I have a Marey LPG tankless heater. The water temperature fluctuates. At my kitchen sink - warm water. In my bathroom shower lukewarm water. At my outdoor shower - nice hot water. How may I fix this...
Ok i intall tankless water heaters and sell them and repair them . The trouble your are hving is more than likely ,the mixing valve on your shower has a ajustment on it to prevent you from burning your self . that is the number one reason in showers when water never get to temp . What it is doing is addng cold water to your shower for you bummer . Take handle off and adjust water temp to your hottest setting . Some times you have to remove the low flow washer in shower head to get the right flow . also every time you start up your hot water it shouldbe set all the way ot other wise withe the battery 2 D models the unit will not sence flow and shut off the unit ,with some units it is a fine balancing act to get them adjusted right. If your buying a tankless water heater always buy a blower type unit that has a computer that runs it . You will be happy . If the Battery operated unit is for a cottage or a smallcabin then your just going to have to fix the pumbing to make it work right many of the safety features of the newer showers are not made to work well with tankless water heaters .
Apr 16, 2011 | RTO Lp Gas Tankless Water Heater By Marey
Constant water leak from the valve that came in the MAREY water heater
That is the temperature pressure relive valve (TPV) . It is either foiled with some thing or going off because of a pressure or temperature problem. If it is leaking continuously it is foiled and needs cleaning. If I where there I would replace it with new.
Feb 08, 2011 | RTO Lp Gas Tankless Water Heater By Marey
Omega tankless water heater giving error code E2 incomplete burn
it sounds like your flu pipe may be clogged,, they just snap together or have little screws holding them together,, take the sections apart and make sure nothing is is the line reinstall and try it out
Jul 06, 2009 | Omega Reliance& Electric Compact Water...
Water Heaters Logo
250 people viewed this question
Top Marley Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Marley Water Heater Expert? Answer questions, earn points and help others
