Question about John Deere 22HP Hydrostatic 42" Riding Mower
Valve adjustment on a LT155 John deere 15 hp ohv engine
daneinwv
  • 124 Answers
SOURCE: How do I adjust valve rods and what's the
Hi I'm Dane, and I'm going to help you solve you problem. Glad to finally get this answered for you. The piston should be set to top dead center on the compression stroke. Adjust the valves when cold to .004 Intake and .006 Exhaust. Torque spec is 61" lb .If you found this reply helpful, please leave me some THUMBS UP if you think I'm deserving! :-) Thank you! Dane
Posted on Dec 06, 2010
  • 11 Answers
SOURCE: have john deere lt155 in storage for 3 yrs won't
sounds like one of two things can wrong...
1) the magneito may have built up a fine layer of rust up between it and the fly wheel magnets.
*solution to this is to take some fine sandpaper (wet/dry will work) and sand the magnets on the flywheel and then carefully sand the two contact post's on the magneito that face the flywheel when it turns. after this you'll have to re-gap the magneito. you can use a good crisp buisness card to do this.
loosen up the two bolts holding down the magneito (dont take them out) so that the magneito will slide to flywheel when magnet comes around...place the buisness card on magneito post's surface so that it creats a bearer between it and the flywheel (you'll have to use both hands to do this) then while holding the buisness card in place turn flywheel (by hand) (its easy and safer to remove spark plug to do this) untill magneito automatically slips towards the flywheel magnet (dont remove card yet). tighen the bolts so that the magneito stays in place while you remove the buisness card slowly so as that you dont disturb the placement of flywheel to magneito... once you tighten the bolts the rest of way you in buisness
2) the pionts might need to be re-gapped or even replaced.
* they are located under the flywheel of mortor. you'll have to take it off to get this far..
i would try the magnneiot solution first.
Posted on Jun 25, 2009
bbreton
  • 437 Answers
SOURCE: need instructions for changing a drive belt on a John Deere LT155
I have googled LT155 and came upon john deere LT155 lawn tractor(noncurrent). It took me to John Deere's site. I put in your model number and it had several catagories. I would try the alphabetical list, go to B and look for traction belt.
Good day.
Posted on Oct 14, 2009
SOURCE: John Deere 185 deck height adjustment
having a problem with dive belt being hit by the mower deck 185 john deere suggestions !!
Posted on Jul 16, 2010
SOURCE: Have John Deer LT155 that gives me problems starting
hi the kohler 15hp had problems with the hydraulic lifters hyperpumping with oil and not bleeding down thus holding open the valve. check out kohler.com on google also check out troubleshooting hydraulic lifters.com on google.
Posted on Oct 19, 2011
John Deere lt155 traction drive belt adjustment
http://www.instructables.com/id/How-to-change-the-traction-belt-on-a-John-Deere-LT/the link shows the routing and idler spring either wrong size belt -inserted wrong or broken spring idler pulley
Sep 11, 2016 | John Deere Garden
Manual for John Deer LT155 wiring an scymatics
I wish people would learn how to use GOOGLE!!!!
VERY FIRST THING ON A GOOGLE SEARCH, IN IMAGES!
john deere lt155 wiring diagram Google Search
Please be patient, the website below seems to be very slow.
John Deere LT155 Wiring Diagram
Jul 26, 2016 | Cars & Trucks
How do I adjust valves on john deere 310c loader/backhoe diesel
Horace if you have an ohv engine, remove the hood to access the valve cover. remove the 4 bolts and be very carful not to break the gasket. roll the engine until the rockers feel loose. If you call the mower repair shop they will give you the measurements, i think they are ext. 0.07 int. 0.05. but check for sure. LUCK to YA.
Oct 11, 2013 | John Deere Garden
My 13 hp ohv 5 speed 38" cut tractor dies after mowing for 10 or 15 minutes and will not restart until it cools off. i have changed fuel filter and cleaned the air filter and have also made sure my gas cap...
Just maybe, since this is an OHV engine, the valve lash needs adjusting. Your are possibly seeing the results of poor clearance when the machine heats up and the metal valve train expands, Then after cooling, the train is within tolerance again, allowing the engine to start and run. Check into adjusting those valves.
Sep 20, 2010 | John Deere Garden
Kohler CV15S on a John Deere LT155 smokes alot. I pulled the head off to check the cylinder. The cylinder looks perfect but the head gasket looks as if it has had blow by between the exhaust valve and the...
I also have a John Deere LT155 Garden Tractor, and 'I have issues with white smoke and cannot get it started. I have detected gas smell in the oil. Quick call to a JD service centre told me it was likely a head casket. If the smoke is white, then that is likely your problem.
May 02, 2010 | Garden
Need instructions for changing a drive belt on a john deere LT155 lawn tractor. When mowing up hill the forward motion is slipping even though i am not loosing traction. if i come off the pedal and start...
Good day.
Oct 14, 2009 | John Deere Garden
John Deere 22HP Hydrostatic 42" Riding Mower Logo
764 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
