Question about Sony Computers & Internet
Laptop (sony) will not turn on when button is pressed.
It appears that the power supply is good as it has a green light on.
  • chashav Mar 12, 2009
    Repair the on/off button?
I don't know if it is the same problem that i have. I am looking for solution tooo, but i have a temporary solution for now. To turn on my vaio laptop some times is a problem. I push the power on button and only the battery led blinked but nothing else happend. The only way that I found to turn on my computer is taking out the battery and the AC connector, press the power on button serveral times and some keys some times, (I suppose that is a electric condenser that is bad and I try with this procedures discharge it), then put in the battery and push again the power on button, some times don't start at the first, but allways that i follow this procedure my computer start, some time need to retry two or five times the procedure, of push the buttons without battery and try again with the battery in, at the end when the computer start, i connect the AC connector and everything works fine....
Posted on Oct 24, 2009
  • 50 Answers
Just remove the battery from laptop and again fix it carefully.
Posted on Mar 12, 2009
NY Samsung laptop turns on, but only a blue screen appears. The green light on front of laptop isn't coming on.
This sounds like the Blue Screen of Death. Most likely a hardware problem. Does the blue screen display words and numbers? If so try to write down numbers and do a Google search. This should give you a good starting point. Or send me a snap shot of screen and I\'ll see what I can come up with. Hope this helps.
Jan 16, 2015 | Samsung Series 5 Ultra 530U3C - Ultrabook...
Thought I should add more detail about what the laptop is doing. The laptop sat for a long time with a dead battery, because the power supply low voltage wire got chewed by one of our puppy's when it was...
from the web -
1 Removed the battery
2 Removed the AC power
3 Plugged in the AC power again
Note:- At this point the light from flashing amber light to solid green indicating AC Power
4 Plugged in the Battery
Note:- Solid green AC power light and Amber charge light
Oct 30, 2013 | Toshiba Satellite C655D-S5084 Laptop
The unit appears to be dead but the green and yellow channel LED's continuously flicker.
I am guessing that the lights are near the network cable plug? This simply shows that there is a signal on the network cable that is plugged-in. The laptop may be dead. Is there a light on the power supply? If you remove the battery, plug the power in and press the power button, what happens?
Dec 15, 2012 | Computers & Internet
I cant turn on my HP520 notebook pc. when i press the power button, it blinks once, and the charging light blinks for 9times(orange light, the 8th times was green light) i tried to remove the battery and...
Alright, not sure if this will help, by my understanding is that you are saying that when you power the computer using the power supply adapter, nothing comes on? Then when you have your battery installed on, then there are lights blinking from your battery charger LED amount of times. In this case there are no promblem with your laptop and it is your power supply adapter that is damaged and will need to be replaced. It is not charging the battery. The battery is still good, but does not have enought charge to power up your system. You can find a charger on ebay for a good reasonable price compare to getting it from Hp. I hope this can help you.
Jan 13, 2011 | Computers & Internet
Power supply flashes green and no lights on laptop
Remove battery pack, press and hold power button for 5 seconds, then put battery pack back in and restart pc. This should take care of it. A bad memory stick can cause problems like this as well.
Nov 12, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
I was watching a Blu-Ray movie this morning and my PS3 just shut off and proceeded to have a red blinking light. I pressed the power button and a solid red light appeared. I pressed the power button...
You have major problems I'm afraid. You need to contact Sony about fixing it/replacing it. Just pray it's under warranty. You could equate this problem with the 360's Red Ring of Death.
Oct 21, 2009 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
246 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
