My lennox furnace kicks on, then it shuts off
My heater will kick on, every thing is firing, the ignition thing lights up, the pilot gets lit then it kicks off, with the combustion fan running blowin cold air in the house. i've replace the air filter, cleaned the ducts, but still the problem, can u help?
  • 1 more comment
  • itsallgravy0 Mar 12, 2009
    thanks for answering, but if u can tell me what the leds on the board means, the actual furnace or the thermostat itself. and the gas valve that u r referring to, r u talking about the giant knob goin into the furnace or a smaller one inside the actually leading to the pilot? sorry for asking simple questions, but your help is greatly appreciated!
    ok maybe i should of worded it different. "Where is the board?" u mean the thermostat? or down under by the actual furnace? i do see the knob in which ur talking about for the gas. but it does light up, and burn for like 10 seconds and shuts off, and tries to restart like 3 times after that. should i try and clean the flame sensor since i havent the 3 years i lived here? lol and where would that be located?
    Thanks for responding in my time of need, i will check it out. another question if you dont mind answering, this only happens when the heat is was already running, and then i call for it to go longer, if that makes sense, then it will have trouble keeping the gas on. do u still think its the gas valve? i would probably need a techinician to fix it wouldnt i, i not to fond of blowin myself to smithereens lol. u have been a lot of help and i thank you for your time, u have narrowed my problem down to a couple of things instead of a whole new furnace! :-)
  • 478 Answers
It should have a diagnostic set of leds on the board, with the code list on the door and the control board itself. If it get to the pilot stage and the shuts down its most likely the gas valve. You can check for continuity from mv to c on valve, you should have it. Then with a valtage test from mv to a ground or common as you here the next click of a relay on the board after the pilot has had a few seconds.
Posted on Mar 12, 2009
  • mark milligan
    mark milligan Mar 12, 2009
    Yes the gas valve is the aliminum box with a knod or on off switch are located. When your furnace fails to ignite it kicks the fan on to purge area. There two leds the first is the first digit of the fault code the second is the second digit. Look at the control board closly the code list is there or on a panel somewhere.
  • mark milligan
    That particlur gas valve has a main and pilot circuit just becauuse one does doesn't mean the main will.If it never fully ignites the flame sensor has'nt came into play yet.
I have a nordyne furnace model # e3eb-017h. Furnace doesn't kick on at all. No relay click or anything but it's getting power. Did the thermostat trick with touching wires together to kick on the furnace...
Check the pilot light sensor. Have seen this issue before. Sometimes after lighting need to hold it in longer. If it doesn't detect the lit pilot wise it will sit in safety shut down mode
Oct 28, 2014 | Heating & Cooling
Lennox g26q3
electronic ignition or pilot type? assuming electronic ignition, check the airflow sensor for dirt in the peto tube, or a defective sensor, if you hear the high voltage click but have a failed ignition chec that the pilot is being lit, and that the thermopile/infrared sensor is good. one of those is your problem.
Mar 23, 2014 | Heating & Cooling
Pilot light goes out after thermostat kicks off
If it's a direct spark ignition type heater maybe that's how it's designed to.work .When called for heat pilot open allowing gas then ignitor spark and ignite the pilot then gas valve open and allow gas through burner then unit fires off .
Once temp is met pilot valve closes and pilot out .
Feb 19, 2018 | Desa International Heating & Cooling
Lennox furnace model G11Q3-110 v.2 burners light but go out before fan comes on
Troubleshoot an ignition problem on a Lennox gas furnace ...
? 2:44
https://www.youtube.com/watch?v=yXIxgzwMkPs
Nov 17, 2012 - Uploaded by grayfurnaceman
This furnace should light its pilot with a spark then the pilot proves its on ... Troubleshoot an ignition problem on a Lennox gasfurnace .... Pilot and no inducer but is the same model as that great video! ... You probably have dirty burners. ... How do you know spark module is not sending 24 volts to mv and pv ...
Lennox Furnace Model G11Q3-82-2 - RepairClinic.com
Nov 19, 2012 | Heating & Cooling
I have a Dayton 3E437A furnace that does not activate the igniter or solen.
Try the flame sencor looks like a small rod this may need cleaning but if you jumped ou tthe pressureswitch then this will need to be replaced , check air filter is clean .
Oct 20, 2011 | Dayton Gas Furnace Heater
Lennox G8Q3-90-4 will not ignite the pilot. The
While holding down the control knob for the pilot, you either have to use the pilot ignitor or match light the pilot. Then old the knob in for 60 seconds, before releasing it. If the pilot remains lit, turn the control knob to ON. If the pilot does not remain lit, the Thermocouple or Thermopile may need to be replaced.
Hope this helps you to solve the problem.
Mar 23, 2011 | Heating & Cooling
Lennox gas furnace G21Q4/5-100-1 sometimes won't kick on
Hi check out the flame senser is clean also jump ou tthe pressure switch see if it lights when you do this , igntion modul is just a box with some push on wires just get the right one the info is all on the module
Feb 16, 2010 | Heating & Cooling
Lennox Gas Frunace fires goes out, fires goes out, fires goes out
Check your thermostat anticipator setting. If you dont know how to do this don't try on your own or you may damage your thermostat.
Dec 12, 2008 | Honeywell Electronic Programmable...
Pilot lights fine, furnace fires up, when it turns off the pilot goes out
need to have at least 3 feet of vent out of the roof, if it is to low the coll air will cold soak down to the pilot and shut it down.
Nov 08, 2008 | Cozy (W352E) Heater
Washing Machines Logo
388 people viewed this question
Top Washing Machines Experts
