Question about Bushnell 10 x 42mm Sportsman Binoculars
Double image I see double images when in focus
  • Anonymous Nov 26, 2007
    Several of my family members and I have double images when looking through binocs unless you pull them really close together which is not easy to do and still see through them.
    President:
  • 1,114 Answers
The distance between the centers of the eyepieces of your binocular must be the same as the distance between your pupils. This distance is adjusted as follows: 1. Focus on a distant object. 2. Pivot the two halves of your binocular farther or closer apart until you can see a single unobstructed, circular field of view. Make sure to focus on a distant object when you do this because when you focus on a close object you always see two slightly overlapping circular fields. Your binocular may have a scale on the top, between the eyepieces, to help you remember this setting.
Posted on Aug 03, 2007
SOURCE:
Out of focus, double blurred image with pinks & greens
Out of focus, double blurred Problem with the Sony KP-51WS500 51 in. Rear Projection Television
Apr 21, 2011 | Sony KP-51WS500 51" Rear Projection...
Focusing problems
Hello Samaro,
This effect is produced when the tho sides of the binoculars are not focusing the same.
Since you sayit is present at long distance, it might be that one barrel is stuck and is not focusing the same as the otherone when you scroll the middle "focuser".
What you can do is open it up and try to clean it, also see if there is something, that is making one of the lenses not move forward as far as the other one.
Good luck,
Dahaka
Jul 28, 2008 | Fujinon CD Binocular
Double image after magic focus with a number 4
Replace Both Of your convergence ICs STK392-110 they are big black IC will have part# on them Call Mats for parts 1-800-628-1118
Sep 25, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Double screen image
Double image shows that TV got problem of Convergence Out ICs failure and will be replaced two ICs mounted at D Board of TV.
ICs, STK392-360 are available in Part Store, click to see an image and price info.
Apr 27, 2009 | Sony KP-65WS500 65" Rear Projection...
The image of my 53sbx10b are double after few minute
Replace convergence ics. Hitachi has a ki for this consisting of STK-395-110 ic and some resistors.
Apr 13, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Need to adjust lens focus on all three projectors
If its a double image that sounds like convergence.
Apr 09, 2009 | RCA D52W23 52" HDTV CRT TV
Double image on green
Focus won't help if it is a double image. Sounds like convergence amps need to be replaced. Very typical on these.
Jul 04, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Double outline "red" around images
Hi you have bad convergence ic stk modules ,Cost for repair center to fix is 250.00. call your local repair center ask there prices on convergence ic repair. It is a very common problem every 3 to 5 years .Our service center does a lot of these.
thanks doctor video 1987
Jun 01, 2008 | Toshiba 42H83 42" Rear Projection...
Double image 6 yr old unit
Have you let set warm and then tried Magic Focus? Maybe after 15min.
Nov 25, 2007 | Hitachi 61UWX10B 61" Rear Projection...
Projection TV
You will need to repair the convergence circuit to fix the double image. The second issue of the "perfect focus" stopping at 37% will be fixed at the same time. It is halting because the sensors detect no movement of the blue image. here is a link to the part number and how to purchase the board. http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Jun 03, 2007 | Samsung PCN5425R 54" Rear Projection...
Bushnell 10 x 42mm Sportsman Binoculars Logo
916 people viewed this question
Top Bushnell Optics Experts
Steve Allison
Steve Allison
Ekse
Damen Wong
Damen Wong
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
