Question about Garden
Blades will not engage on my 3225 cub cadet mower. the pto has some vacum. but does not engage
SOURCE: My Cub Cadet 2135 PTO won't engage.
i had the same thing happen
found that the on/off switch had come unplugged from the wire harness just below the switch
had to attach the wires to something underneath so the weight did not pull the wires down and taped the two switches together to prevent it from pulling apart
it needs some kind of clip to hold them together
hope that this works for you
jo
Posted on May 24, 2009
panilling9
  • 284 Answers
SOURCE: cub cadet mower pto will not stay engaged while
be sure your battery is good and your system is chargingning the battery while run
Posted on May 26, 2009
panilling9
  • 284 Answers
SOURCE: engine stalls when electric PTO clutch is engaged
check your spacers to be sure you havent locked the clutch assembly directly to the motor shaft
you should be able to turn it fairly free less some clutch drag
SOURCE: My cub cadet zero turn mower won't engage the
I have a cub cadet zero turn 50' mower, i start mowing and after about 10 minutes it starts running out of gas, i pull out the choke to keep it going but it just keeps getting worse to the point of quitting. If i slow it down to a idle or just a little more it will stay running but that is not fast enough to cut the grass. does anybody out there know why i am runnung out of gas. I put a new filter on it, It did not help.
Posted on Jun 20, 2009
  • 109 Answers
SOURCE: Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Posted on Jun 29, 2009
The lever to engage the blades on my Cub Cadet rider LTX 1042 KW has no resistance the the blades do not engage. Did a part possibly break off or come loose?
The blades are engaged electrically via the PTO on the engine shaft.
Check the connector and wiring to the PTO unit, or the electrical plug on the engage switch.
Oct 09, 2016 | Cub Cadet LTX 1042 KW 42" 18HP Kawasaki...
LT1046 cub cadet blown clutch..what caused this with new Pto switchpto switch froze..replaced it still will not engage blades.what could blow the new clutch
Are you sure it's blown? Run two jumper wires from the battery or power side of the starter solenoid and energize the clutch. If it energizes and clicks, that's eliminated. Did you blow any fuses?
Jun 16, 2016 | Cub Cadet Garden
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
More results from forums2.gardenweb.com
Sep 25, 2015 | Cub Cadet Garden
After reverse, my cub cadet zero turn mower pto will not re engage the blades. sporadic up to the point of stopping altogether. is it the switch or clutch?
I would guess it is the switch. My Cub Cadet has a safety feature where the blades (PTO) stop when you hit reverse. There is an override where you turn the key back about a quarter turn or so and hit a button right above the key to make the blades run even in reverse. Therefore, I would guess the ignition switch is the problem but I can't be certain. Or it could be the electric switch that engages the PTO.
Aug 10, 2014 | Cub Cadet Garden
Why does my cub cadet die when i engag the blades
Bad pto switch or child back up switch on trans. shorted
Jul 01, 2014 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
Jun 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
81 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
