Question about Asrock K7S41GX Motherboard
Windows problems hy i have a problem with the motherbord and i change it with ASROCK K7S41GX. I installed correctly, but after the boot, ask me if start in safe mode, safe mode with command promp, ... I select all the variants , but everytime, the windows not started and the systems reboot, What can i do?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 135 Answers
Windows keeps a record of the serial and/or model number of your motherboard when Windows is installed. If windows tries to start and senses that the number(s) of the motherboard are different, Windows refuses to start. You have to use your Windows installation disk and run the Windows Setup. If you have WinXP or Win2K you might be able to just run the "Repair" function, so try that first. If that does not work, run the complete Windows Installation. So long as you do NOT allow Windows setup to partition your Hard Drive, and you do NOT install Windows to a new directory (folder)... then Windows -should- retain all of your programs, personal settings, desktop picture, etc.
Posted on Aug 03, 2007
6ya staff
SOURCE:
I just installed an Asrock K7S41GX motherboard in my HP computer and it won't recognize USB keyboard and mouse or boot up. Any ideas?
Try temporarily connecting a standard keyboard. If it now boots up o.k., the OS should write the prescence of the wireless device to BIOS and you should be able to boot up with your wireless devices only.
May 13, 2010 | Asrock K7S41GX Motherboard
Is there driver for mothetherboard asrock ata 133 for win7
HERE IS THE SITE FOR DRIVERS AND BIOS UPDATE FOR THE ASROCK K7S41GX (http://www.asrock.com.tw/mb/download.asp?Model=K7S41GX&o=All)
Nov 25, 2009 | Asrock K7S41GX Motherboard
I have install a new mother board, but when i power the computer the power come on, but no response on the monitor
Or reset motherbord settings to defaults you can reset with 2 methods.
(1)Pull cmos cell from motherbord for 10 minutes so all settings defaults.
(2) Find jumper on motherbord named "Clear cmos" It has 1-2-3 pins.Put jumper in 2-3 position and thne power up then again put pin in 1-2 position thne all settings defualts.
Refix RAM memory.Clean dust from all parts.
Open processor and processor fan.
Remove pci cards from motherbord then check.
Make sure motherbord not ground with cabinet.
Let me know if you need further assistance.
Nov 15, 2009 | Asrock K7S41GX SiS741GX Mainboard...
I just installed a used Asrock K7S41GX board which is working just fine exept I have no sound through my external speakers. The internal speaker on the the board beeps on startup but nothing after that. Do...
If you hear just one short beep on the onboard speaker it means that everything is fine. You should download the drivers for the onboard sound from Asrock website.
May 18, 2009 | Asrock K7S41GX Motherboard
Need help on asrockmotherboard installation
i have problem my motherboard asrock k7s41gx i install the os xp service pack 3 but the audio didnot detect and the video card didnot detect how i do to detect the audio and video card
Apr 01, 2009 | Asrock K7S41GX Motherboard
Windows freezes when shutting down
If you can download the lastest bios for that PC from the internet that should fix your problem if that does fix issue reinstalling windows or does Xp restore from cds will
Mar 18, 2009 | Asrock K7S41GX Motherboard
How to disable internal vga on asrock K7S41GX?
GO INTO THE BIOS AT BOOT AND DISABLE/TURN OFF ONBOARD VIDEO .
Was this solution helpful? Show your Appreciation by rating it..RICHARDM69
Dec 14, 2008 | Asrock K7S41GX Motherboard
Asrock K7S41GX Problem with video card.
Bigger power supply 450 to 500 watts
Nov 29, 2008 | Asrock K7S41GX Motherboard
Boot up problem
Although this is almost always a hardware problem, pinpointing which hardware is the culprit can be a tedious task so before making any hardware changes, assume first that this may be is a software problem. Assuming that you have Windows XP installed as your OS. You can try fixing your system with System Restore. To do this, turn on your PC and press F8 during the boot-up process. Select Safe Mode and login with an Administrator Account. A pop-up window will then prompt you to enter Windows in Safe Mode or just Restore your system by using System Restore, choosing NO will automatically open up the SYSTEM RESTORE window. Choose a restore point (a point or a date where your PC worked well before having problems). Your PC will reboot with the configuration set on your selected restore point. If this doesn;t solve the problem. You can try fixing your system using your Windows XP installation CD. Just don't forget to set your CD as the first boot device.
Nov 13, 2007 | Asrock K7S41GX Motherboard
AMD XP2400+ with K7S41GX
Hi, the only reason that comes to mind here is your version of XP. A retail version will load on almost anything, a version supplied with a brand name computer may only be suitable for that brand, Dell/HP etc. Sorry if I am not much help, don't discard your old board, you could buy an add on card for ide connection then disable the onboard one and continue with the old system. Goodluck mistyman
Sep 09, 2007 | Asrock K7S41GX Motherboard
Asrock K7S41GX Motherboard Logo
151 people viewed this question
Top Asrock Computers & Internet Experts
Ekse
Thomas F. Schneider
Joe Negus
Joe Negus
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
