Question about Gateway Computers & Internet
I have a Gateway DX4710-05 with Windows Vista 64-bit and I'm trying to install a PCI HDTV TV Tuner. Everything seems to install ok, but I can't get it to scan for channels. The pci card is from Sabrent. I don't know which video card have.
    Problem Solver:
  • 17 Answers
First you need to find out exact model of your TV Tuner. If it is installed it should be in
Start\Control Panel\System\Device Manager\Sound, video and game controllers.
To check installation you can double click it and in tab "General" you will see "This device is working properly" or not.
Knowing the board part number you can check out Sabrent web site for drivers: http://www.sabrent.com/#itemName=&itemID=0&section=Drivers and see if they have a newer one - if yes, then give it a try.
Posted on Sep 13, 2009
When installing driver of philips capture card, it says device not found (SAA7130 tv tuner).
the driver you are trying to install 32 bit or 64 bit might not be compatible with the operating system
Nov 01, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
I have a Philips SAA713X TV/FM Tuner PCI card. But it's not working with Windows 7. I want to download the drivers for Philips SAA713X compatible with windows 7. Please help?
if its not compatable to it, it want work for that windows i mean you can try to download the drivers but when you do it just going to say error what it is is drivers are only formated on and older system for 32 bit processer and your system must be 64 bit processer .
Feb 24, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
I am having problem doing installing drivers of philips tv tuner card xpert TV7134. i am using os windows7 64Bit, when i start loading driver this error interrupts me SAA7134 WDM drivers loading failed! i...
Is it 64 bit compatible, if needed try to source drivers elsewhere or a little trick i have learnt is alot of xp drivers work in windows 7 if manually installed, if you can do this give it a go or let me know and ill give you instruction, was the card certified for vist, if si try to get the vista drivers and give that a go, hope this helps
Nov 15, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
Video Cam Suite 1.0 does not work with Windows Vista 64 bit
Excuseme If I don't explain so clair, because I don't speak english well, but let me try that I did to solve this problem. First I installed a Virtual Machine(VMware Workstation 6.5.1) in miy Pc(64 bits) . Second, I installed a Windows Vista home basic(32 bits) or Windows XP Sp2 (32bits) on it., depending of what Operative sistem do you have in your real machine. And finally I could installed the Videocam suit in the Virtual Machine and everything was ok. I could transfer all my videos of the camera to the pc very easy The only inconvenient is that you need to transfer the videos downloaded of the virtual machine to the real machine with a flash memory or similar something.
Jun 12, 2009 | Panasonic PV-GS500 Camcorder
TV TUNER
Well you have answered your own question almost.  Here is what you do.  Go to the manufacture of the tuner and request a version of the driver and software for vista 64bit.
Jan 24, 2009 | Microsoft Windows Vista Ultimate Edition
I try to install the tv tuner that designed to windows vista 32-bit but my laptop has a vista premium 64-bit. why it's not working?
which brand of tv tunner> also which type. I assume it is a usb. YOu may just need a 64-bit driver which may be on the disk which came with the tuner. Baring that you may be able to go online to the web site of the company that made the tuner and download the 64-bit driver from there.
Jan 23, 2009 | Microsoft Windows Vista Ultimate Edition
Phillips SAA7130HL TV Tuner VISTA 64 BIT DRIVERS
well i had the same prob, so i downloaded drivermax, which I think is free.
drivermax scanned my computer and found all the drivers I needed including the vista philps tv tuner driver.
another way is to download iobit advanced system care which is an excellent free program and click the utilities button and then click drivers update. This should give you the philips driver as well.
hope this helps
it certainly worked for me
anyway you should be able to use the 32bit xp driver.
regards peter
Jan 23, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
DRIVER PHILIPS SAA713 X FOR WINDOWS VISTA
Download the Windows Vista driver for your card from the manufacturers website. This should fix the problem. Hope this helps.
Jan 22, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
More ram and vdeo card
it sounds as if your MoBo is seeing the video adapter as a source of ram. if that is the case, then installing memory in units of 1Gb will cause a stick to not be seen, therefore utilized. you may want to refer to you manual for memory limits and poosible comparibility issues. they are usually quite in depth. also, make sure that they are all the same make model and speed. these issues have wreaked havoc on the prettiest of pc's.
Nov 28, 2008 | Computers & Internet
Computers & Internet Logo
143 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
