Question about Yamaha RAV434 Remote Control WW510600
How to program rav434
Program for satellite receiver
How to program yamaha remote rav434
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Sep 02, 2014 | Yamaha RAV434 Remote Control WW510600
URC-4220
Google that for "manual" to see if one is available which will have a list of POSSIBLE codes to try--not all remotes will program for all units......
Jun 17, 2012 | RCA Direct Tv Satellite Receiver Drd435rh...
I am trying to connect my tv to the directv satellite dish, I am having a few problems. My question is does this tv need the cable connection from the satellite or do I just need to connect the satellite...
The dish is always connected to the receiver and then the receiver is connected to the TV. Then you have to call Direct TV to have the receiver authorized to receive programming. Or, call them in the beginning and let them do everything.
Jan 05, 2011 | Televison & Video
Sat finder detects signal on 61.5 Sat but receiver does not display or lock.
Hi, Mary with Dish Network Customer Service. The 61.5 Satellite carries mostly High Definition programming. If your Satellite Dish is an older model, it is not equipped to bring that Satellite in. It is the part on the Dish called the LNBF (the eyes) that will pick up the satellites. Your receiver is a Standard Definition, you should be reading the 119 & 100 Satellites. I hope this helped but if you have additional questions, please let me know.
Dec 22, 2010 | DISH Network 311 DTV Receiver
Will I be able to receive HDTV programming on my TV?
Your HDMI Cable or Component Cables will plug right into their receiver box. You won't need anything else and they should supply the cables too.
Jan 06, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Have Direct TV using a Sony Digital Satellite receiver model #SAT B2-2 /Sony Satellite dish purchased in 7/97. I get local channels thru Direct TV. Recently, local channels will show on the Direct TV guide...
Your dish is out of alignment. The local channel satellite doesn't have as strong of a signal, so a slight misalignment will cause problems.
It could also be an F-connector needs to be replaced at the dish or multiswitch (if you have one). Sometimes moisture builds up inside the connector and corrodes the copper stinger inside.
If you go into your satellite signal strength menu and find the local channel satellite, you're sure to see either a weak signal or an intermittent one.
One more thing, if a tree has grown in the line of sight between the dish and the satellite, this will cause signal problems too. In this case, you either have to trim the tree or move the dish.
Hope this helps!
P.S.
The customer service reps at DirecTV usually idiots reading from a script with no real field experience.
Mar 25, 2009 | Televison & Video
Need to program a directv philips series 2 remote
tivo button is the Directv button (tivo home) at the top of the remote. if u have the new directv remote, the tivo home button is the menu button. remote needs to be on satellite. to program codes.
Dec 20, 2008 | Philips DSR708R DirecTV / TiVo DTV...
I have a MD8830 and want to use the freesat receiver system for T.V. viewing, the set up guide has an option for a set top box or one for no set top box, can this be used for satellite viewing without a...
If your satellite receiver has an NTSC RF modulated output (RG 59 F connector), you'll need a TV tuner card in your PC to watch it.
If your satellite receiver outputs NTSC composite (unmodulated, RCA cables: yellow, red, white), you can use something like ADSTech DVD Express to connect to your PC using a USB port.
Once you've got your receiver interfaced to your PC or other display, you'll probably need to download the latest programming guides / channel assignments into the reciever using USB or serial cable.
Due to various countries legal restrictions, finding such bin or autoroll files, even for Free to Air satellite programming, is most easily done by word of mouth.
Sep 17, 2008 | Medion Computers & Internet
Yamaha RAV434 Remote Control WW510600 Logo
65 people viewed this question
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
 Grubhead
Grubhead
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
