Question about RIM BlackBerry Curve 8310 Smartphone
Cant format sd card
Installed new sd card go to ''format card '' menu select it then the phone appears to just freeze it just stays on that screen cant turn off - on nothing have to remove battery to start phone again??????
  • Shoaib Rais
    Shoaib Rais May 11, 2010
    just take out the card and try to format on the ext card reader ur card may be having problems may be the file system is corrupt pls try it on laptop card reader or any ext card reader format there and then insert the card if the problem persist try changing the card
  • 41 Answers
Your sd card may have too much memory or it may be an hd
Posted on Mar 13, 2009
How do I set my LG L164VL to save to SD card instead of Internal Memory Phone runs on Nougat 7.0
How to turn external SD card into internal storage
1. Go to device "Settings", then select "Storage".
2. Select your "SD Card", then tap the "three-dot menu" (top-right), now select "Settings" from in there.
3. Now select "Format as internal", and then "Erase & Format".
4. Your SD Card will now be formatted as internal storage.
5. Reboot your phone.
Dec 28, 2017 | LG Cell Phones
Www zoom co jp
did you format the card after putting it in the recorder?
press menu
use toggle switch (the scrolling wheel on the right side) to scroll till you find sd card on the menu
push in on toggle switch to select it when you have sd card on the screen
when you do that you'll see 2 choices remain or format
select format then press in on toggle switch
you will be asked if you're sure you want to format the sd card
select yes
the manual said it is important to format your card in the recorder
hope this helps
W
May 07, 2013 | Zoom H2n Digital Handy Recorder With...
Trying to format microsd to my lg9oo and it wont work asks for a code or freezes up on me. what do i do?
Hey
These steps should do the tick!
1. From the home screen press Menu then select Settings.
2. Choose Memory manager and select External memory.
3. Press Format and enter the password, which is set to 0000 as default. Your memory card will be formatted and ready to use.
4. To view the new formatted folders on your GW300 press Menu and select My stuff. Choose My memory card.
Cheers
May 21, 2011 | Kingston MicroSDHC 4GB (4 Gigabyte) Card...
My micro sd 1gb was formatted but the card appeared to have 0kb space available, what should i do/
The most common thing that causes these problems is that an Incorrect format was done on the disk. Here are two different ways that you can fix these errors. I will give you the step by step way to fix them on each one.
First Way To Fix Your Issue:
  1. Stick the SD Card back into the Card Reader on your Laptop or Desktop Device.
  2. Open My Computer.
  3. Right Click on the SD Card.
  4. Select Format.
  5. Format window pops up.
  6. Under the Drop Down Menu of File System Select NTFS.
  7. Then Click Format Wait till it finishes.
  8. Then you should be done and the problem fixed
Second Way To Fix Your Issue:
  1. Stick the SD Card Back into your Phone or Camera.
  2. Select the System Settings on the device.
  3. Select format SD Card on your device.
  4. This should fix the issue.
If you are still having problems with this card then the SD Card is probably bad and needs to be replaced.
Apr 23, 2011 | SanDisk 1GB microSD Memory Card
How can i format sd card for dash
To format the microSD memory card from the device, follow these steps:
Note: When the microSD memory card is in the device, the device automatically creates a file system on the memory card. If the memory card is not formatted, you must format the card. The option to format the memory card is only available when a memory card is in the device.
  1. Verify that media card support is enabled.
  2. From the Home screen, press the Menu key.
  3. Scroll to and select the Options icon.
    • Note: To select, press the trackball.
  4. Scroll to and select Advanced Options.
  5. Scroll to and select Media Card.
  6. Press the Menu key.
  7. Scroll to and select Format Card.
    • The 'Any data stored on the card will be deleted'message appears.
  8. Select Yes.
Sep 03, 2009 | T-Mobile Dash Smartphone
When i put my r4 into my ds its just says cant find menu?
hi it sounds like a software problem. follow the following instructions. Please can you try and reformat the 2gb micro sd card in your pc and copy firmware from the CD back onto the 2gb micro sd card following the instructions below. be warned that formating will remove even the games from the card so make sure you have a backup of the games saved to your computer. any saved games will also be erased.
To format the 2gb micro sd card
1. Insert sd card into usb stick and into usb port.
2. Close autoplay screen if it appears.
3. Right click on removeable drive. (Eg D, E, F or J etc) that appeared on screen in computer window.
4. Left click on format in menu and when format window appears, tick quick format box and select ok. This will erase all content on the sd card and remove any corrupt firmware.
To reload firmware
1. Insert cd into pc cd/dvd drive.
2. Open cd drive on screen and copy and paste the files and folders from the system/english 1.18 folder on the cd to the removeable drive that the usb and micro sd card are in. The folders that you will copy are "_system_" and "moonshl" and the files will be "menu.dat" and "mshl.nds".
3. Once copied, check removeable drive to ensure files and folders have copied over.
4. Remove usb stick from pc and insert sd card back into R4. R4 menu should appear on DS screen.
this normaly sorts this out. paul
Jul 07, 2009 | Nintendo DS Lite Console
LG Dare turning off almost constantly
try typing 2945#*# and a menu appears,from that menu select reset phone.reset it may be your problem is solved.
May 30, 2009 | LG Dare VX9700 Cell Phone
I bought a new mico sd card for my nokia 6233 bu it keeps sayin memory card not formatted hw cani format it
Dear
There Are two ways to format sd card
1) by Phone : Go to Memory card option
Gallery - memory card - option - format
& ur card will be formatted
2) By pc : connect ur phone to pc or sd card reader & right click on removable disk which is your sd card's slot & select format option.
Then it will ask for custom & quick format, select one from them & ur card will be formatted
Thanks & regards
Feb 23, 2009 | Nokia 6233 Cellular Phone
Cant format micro SD Card
try to reformat the sd card to the required FAT 16.... use a computer..and sd card adoptor for you to connect the card to the computer
tnx
Feb 05, 2009 | Motorola Mobility MOTORAZR2 V9 Cellular...
G500
Might it be that what you refer to as "reset the memory" is actually format the memory, that is erase all its content and lay down a new, fresh, clean system?
If yes, then in the SET UP menu, select FORMAT and press right, select media type (what ever memory it is you can cleaned/formatted), press either right or MENU/SET button. To confirm select YES with left or right and press again the MENU/SET button. Once it starts to format " Now FORMAT" displayed would be shown with a graph at the bottom indicating how much of the memory has been formatted and how many more to go.
If no, pls post back what is displayed in the screen.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 06, 2008 | Konica Minolta DiMAGE G500 Digital Camera
RIM BlackBerry Curve 8310 Smartphone Logo
265 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
