Question about Basement Watchdog Dual Float Switch and Controller
Basement watchdog dual float switch does not shut pump off
Pump continues to run until we tap the blue controller. Then it will continue to work for hours, then get stuck again.
How do I stop pump from running? Cistern connected pump does not seem to be pressurizing. Pump not cutting off, and getting hot.
Pump probably needs to be serviced. It probably pressurizes a tank and when that tank reaches a pressure the pump is turned off. But just guessing.
May 27, 2015 | Plumbing
Sump pump
I am presuming you're asking about a basement sump pump, the kind that keeps your basement dry. Well, those things are not meant to run all the time. They are usually triggered by a float valve. That is a device that moves according to the water level in the sump (in other words, the hole). When the water gets high enough, the float activates a switch, the pump kicks in, the water is flushed away, the float falls and that turns the pump off until the cycle starts all over again. The frequency of the cycle depends on how fast the sump fills itself. I have one that kicks in five times a minute. Another might have a much longer off time. But don't be worrying about yours not being on all the time... that is how they are supposed to behave. Of course, if you have water flowing out the top of the sump, that is a sign things are not right with the pump. Then you really need help.
Jun 25, 2014 | Health & Beauty
Intermatic t1202T 240v dual pool timer. Main pump continues to run and manual overide will not shut it off. Changed the timer mechanisim and same thing. Disconnected the Freeze control and it wil
Maybe the PF1202?
Probably just the freeze thermostat and not the relay.
Disconnect freeze thermostat wires from relay... and substitute a single-pole switch.
Be careful... power is ON
http://waterheatertimer.org/Intermatic-freeze-controls-and-parts.html#1202
http://www.amazon.com/dp/B003Y5EY6E/?tag=waterheaterti-20
http://waterheatertimer.org/images/178T24-thermostat-wiring.jpg
http://www.amazon.com/dp/B003P52CKS/?tag=waterheaterti-20
Do not leave the single-pole switch connected since 15 amp rating of typical switch is less than amp rating for 40 amp pool centers
Gene
Jun 01, 2014 | Intermatic & Indoor/Outdoor Rain Tight...
Little Giant 554455 VCMA-20ULS 230V 20' My pump runs when the float is down low in the tank and comes off when the float is high in the tank. So it runs continuous. Has something gone wrong and...
The float switch went bad... probably because of the water...you could replace it, but the parts are hard to get and with the time involved it will be easier and cheaper to replace it...
heatman101
May 29, 2011 | Little Giant 554455 VCMA-20ULS 230V 20'
The alarm continues to sound. The red light for battery is on. I did add water and it went off for a very short time m, but then continued. I added more water, definitely full, and it continues to...
(Batteries may be substituted by using a deep cycle marine battery with the same specifications as described above, but the battery fluid sensor option will not function. Simply connect the battery fluid sensor to the positive terminal of the battery to disarm battery fluid sensor alarm).
Aug 05, 2010 | RTO Basement Watchdog Sump Pump
Saniflo sanibest continually running , noisy ...
The float switch will be the problem.
We do not replace the switch, just change the unit as labour to strip and replace switch makes it un economical.
Jan 28, 2010 | Saniflo Sanibest macerator with multiple...
Attached a pump to drain collected water. The
the water should still collect into the tank. the dehumidifier had a float switch that shut the unit off when the tank is full. In turn it should have a second switch, probably a float switch that turns the pump on and off so that the pump doesnt continue to run when there is no moisture in the tank
Nov 26, 2009 | Frigidaire FDL50R1 Dehumidifier
Pump continues to make noise as if its cavitating when there is no water to pump.
If there is no water to pump then it is cavitating. It should turn off when the sump is emptied down and the float drops onto the switch arm
Oct 21, 2009 | RTO Basement Watchdog Sump Pump
Dishwasher starts washing before float switch shuts off
That is it , it is the electronic programer circuit board timer. change it. Vitally
May 12, 2009 | Dishwashers
Anti-flodd Aqua Control
exact same problem here, we had power cut and after power came on the pump was continuously running with error EF3 showing.
This has happened before - design error with AEG
May 27, 2007 | AEG Lavamat 88840 Front Load Washer
Basement Watchdog Dual Float Switch and Controller Logo
54 people viewed this question
Top Basement Watchdog Plumbing Experts
Donni Steen
Tom Chichester
Are you a Basement Watchdog Plumbing Expert? Answer questions, earn points and help others
