Question about John Deere Garden
JD LA125 steering problem
My 5 year old JD LA125 has too much steering play
Jd sx85 6 years old can't get out of neutral
to force shift get the rear tires off the ground then shift while rock wills back and forth but thats not a fix something inside transmission has broke
Aug 28, 2014 | Garden
John deere la140
Try a little grase. May help. That's the problem with these gensis JD
May 06, 2014 | Garden
My uncle has a john deere 111 and my dad turned it on and off apparently trying to get the key out and it hasn't worked since. What should my uncle do?
Is this the old JD 111 made from 1979-1986? I would guess that it was left out in the weather over the years and that is why the key was stuck. Check the ignition switch and the starting solinoid. That is where I would start. Let me know if that is it. If it still does not work, then there are other routes to go. I have a JD 111 from 1980 that was recently left to me. I tuned it up last year and it still runs good. That is a testament to the old JD's.
Aug 17, 2011 | John Deere Garden
5 year old grandson just found his mothers old PS2 and the Mad Catz racing wheel and pedals. Lookig for instructions for wheel/pedals so he can play his PS2 "Cars" game. Wheel doesn't turn car...
Well, the game has to first be compatable for the MAD CaTz Steering Wheel. The Mad CaTz Steering Wheel is compatable with almost any racing game. Instead Of Using the Pedal for the game, he can use the X button that is ON the Steering wheel.
Feb 16, 2011 | Mad Catz Racer Racing Wheel - PS3 for...
After using my la125 for about 30min the engine will stop and will not stay running uses lots of oil
Depending the age of the B&S 21hp engine, your looking at anything from a blown head gasket or worn valve guides to a complete overhaul. If come to the overhaul, it is best to have a new engine installed by known a good tech outside JD. JD will charge a small fortune to do this. I replaced two engines this year on two different JD mowers. I was able to get the customer old worn out engine replaced with a new upgraded engine with two warranty vs a 90 day rebuild warranty. Matter of fact the short block costed more than a whole engine but need to have your old model number cross referenced so you can get a suitible replacement.
Jan 13, 2011 | John Deere Garden
Loose steering
Bob, yes you can adjust the steering box with out problem.
Jun 01, 2009 | 1993 Ford Bronco
Won't play DVDs from asia .. need region code unlock.. help.
1- Open tray
2- Press setup
3- Press 1 3 8 9
4- Use Up/Down key from remote control to change the Region
5- Press setup
Apr 03, 2008 | Jwin JD-VD135 DVD Player
Nesesito un codigo para un dvd marca jwin grasias
Some unlock codes for Jwin DVD players are:
Jwin JD-VD100 / JD-VD703 / JD-VD753
1. Press SETUP
2. Press PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER
3. "VerX" is displayed (X=RC)
4. Select the RC with RIGHT and LEFT (255=Codefree)
5. Press RETURN
Jwin JD-VD120
1. Press SETUP
2. Press 1, 3, 6, 9
3. Current RC should be displayed
4. Select RC with UP, "DOWN" (0=codefree)
5. Press ENTER
Jwin JD-VD130
1. Method 1:Press SETUP
2. Press 1, 3, 6, 9
5. Press ENTER
1. Method 2:Open the disc tray
2. Press PROG
3. Press ENTER 3 x
4. A menu should appear.
5. Select RC with UP, "DOWN" (0=codefree)
6. Press STOP
7. Close the disc tray
Jwin JD-VD135 / JD-VD147
1. Open the disc tray
2. Press SETUP
3. Press 1, 3, 8, 9
4. Use Up/Down keys to change the region
5. Press SETUP
Jwin JD-VD140 / JD-VD501
2. Press 2, 8, 1, 2
3. Use the arrow keys to change the region (9 = multiregion)
4. Press SETUP
5. Close the disc tray
Jwin JD-VD145
2. Press 9, 7, 3, 5
3. Change the region
Jwin JD-VD200 / JD-VD203 / JD-VD500 / JD-VD503
1. (Open the disc tray)
2. Press SETUP
3. Press 1, 3, 6, 9
4. Press LEFT 3 x
5. Press RIGHT
6. A new menu entry appears (Version)
7. Select it and select RC (0=codefree)
Jwin JD-VD138 / JD-VD504 / JD-VD602 / JD-VD603 / JD-VD745 / JD-VD903
no known hacks
or you can try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 18, 2008 | Televison & Video
Garden Logo
61 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
