Question about Brother MFC7360N AllInOne Laser Printer
Print unable EF on brother HL-4570 CDW
LCD screen says to turn off then power back on to reset... and it did up to now... but now it doesnt. This started happening from day 1 when i first used it, but i didn't think anything of it because it would always reset. But now that i've had it for 1year and 3 months, meaning it is no longer under warranty, it will no longer reset. And i just spent $500 on genuine brother extended yield toner!!!
SOURCE: Brother Printer HL 1240
OK figured out the sequence to resolve this error:
power off unit
unplug power cable for 1 minute
reset the power cable
open front door
press and hold the reset button under the lights
turn the power on
printer should then be reset
Posted on Aug 16, 2008
SOURCE: Toner
Trick the thing. Put a piece of black electrical tape on the "eye". (Take cartridge out, on right side there's a small clear hole). Worked for me!
Posted on Oct 22, 2008
SOURCE: BROTHER Hl 2040 PRINTER WON'T PRING
I got exactly the same problem and the "reset" didn't do anything. I fixed it by putting a piece of duck tape on magic eye on the cartridge.
Fallow those step to do the same thing as me:
  1. Open the front panel.
  2. Remove the toner and the drum
  3. Remove the toner FROM the drum
  4. On each side of the toner, there should be a little glass. Put the piece of duck tape on one of them. I put mine on the right side.
  5. Put everything back in.
  6. Turn on your printer if it's not already.
  7. Now, the low toner light should be gone and the green light should be on.
Now, you can really empty your cartridge.
Posted on Nov 06, 2008
  • 19 Answers
SOURCE: What is a waste toner box. what does it do and
like the name suggest, it collects waste toner. Any toner that is left over from the print process is waste toner. Once the waste toner bottle is full, the printer will stop working until You have replaced it with an empty waste toner bottle. So in short, if it is telling u to get a new one, get one or the other option is to empty it yourself which is very messy and if u dont clean the bottle of all toner dust, may not even work.
Posted on Oct 11, 2009
Testimonial: "I had no clue what a waste toner box is. Your response helped me. Thank you."
  • 145 Answers
SOURCE: My Brother HL 4040 says
Gently pull the toner cartridge out. don't want to spill toner,,, inspect to see if all plastic has been removed. warning toner is super fine soot do not repeat do not vacuum it up ,,, messes up vacuum and puts dust in air,,stains clothing
Look at contacts on toner cartridge and scrub with old tooth brush,,, look at contacts of printer same same.
Posted on Nov 27, 2010
Testimonial: "problem solved, thanks."
Brother dcp 7055 EF problem
Please provide detailed information on what the problem is; just saying model and problem give us nothing to work with.
Jun 26, 2015 | Brother Office Equipment & Supplies
How solution Unebal to EF in Brother DCP 7055 matchine ?
Error code EF - Irregular power supply is detected
Print Unable EF
Turn the power off and then back on again.
Sep 29, 2014 | Brother DCP Office Equipment & Supplies
How do you replace a fuser unit for a Brother HL-6180DW
how to solve hl-brother printer 6180dw power on off print unable to print ef triy again back
Feb 12, 2014 | Office Equipment & Supplies
I have brother DCP 7055 it shows print unable 71 error pls suggest
I have brother DCP 7055 it shows print unable 72 & some time it show 71 error pls suggest
Dec 18, 2012 | Brother Dcp-7055 Laser Print Copy Scan...
MY BROTHER PRINTER DCP-7055 EORRER REPLACE TONER
This came from the Brother HelpDesk, yes they rang me and it worked.
Cover open Press Clear "Replace Drum?" (ignore this and quickly...) Press Start (blank screen, quickly...) Press Up arrows then switch to down arrow to 00 Press OK
Mar 09, 2012 | Office Equipment & Supplies
Brother dcp 7055 error-EF
brother dcp 7055 error-EF laser
Nov 22, 2011 | Office Equipment & Supplies
Everything appears fine on our 14 month old HL-4070 CDW. However we're still unable to use it. The LCD continues to display "print unable 3B, even after 5 power on-off cycles. Suggestions?...
it could be the coagulation of ink in between the cartridgebetter dip it in mild hot water for some times and replace it wiping the water. it would do the trick and solve your problem . it has been practicallytested.
If this solution helpful/useful for you please rate the solution. THANKS FORUSING FIXYA.
May 19, 2011 | Office Equipment & Supplies
I have a Brother HL-3040cn printer, led display says "unable to print 1A" how do i clear this? It also says to turn the power off and open the top cover wait 30 minutes then turn it back on. But...
I have a Brother HL-3040cn printer, led display says "unable to print 1A" how do i clear this? It also says to turn the power off and open the top cover wait 30 minutes then turn it back on. But this doesnt work?
Apr 20, 2011 | Brother HL3040CN Laser Printer
Open Questions:
See all Brother MFC7360N AllInOne Laser Printer Questions
Brother MFC7360N AllInOne Laser Printer Logo
112 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
