Question about JVC Video Cameras
Cable from Camera to TV
Hi there, maybe this is a silly question: where does the three-pronged cable that goes from camera to TV get plugged in camera-side?
I can easily plug the three prongs into the TV but I can't see any kind of opening on the camera that will take the single metal end....???? What am I missing?
  • 10,594 Answers
Usually AV connectors are located under cover.
If you provide me exact model of JVC camcorder so I can help you to locate AV connector.
Posted on Mar 12, 2009
How to install a video machine if I don't have the tv remote?
I'm assuming by "video machine" you mean some kind of DVD player or Blu-ray player or something of the like. I will explain how to install a DVD player. There are two major cables: one sends the video to the TV and the other sends power to the DVD player. The power cord plugs into the wall with the other end attached to the DVD player. The video cable plugs into the TV. If you have an HD television, the video cable will have a male HDMI piece that plugs into the TV while the other end of the cable plugs into the DVD player. If you don't have an HDTV, then you will use an RCA cable which has three prongs: Yellow, White, and Red. These three colored male prongs plugs into the corresponding color coded holes in the TV. The other end goes into the DVD player. When you have everything plugged in correctly and the DVD player is on, all you have to do now is change the TV input. You will need the TV remote that came with your TV, or a universal remote that has been configured to work with your TV. Find a button on your remote that reads "Source" or "Input". This will cycle through the sources and inputs of your TV including AUX, VIDEO1, VIDEO2, etc. Keep going until you are on the correct input to see the DVD player menu. Good luck!
Jul 01, 2011 | Philips 42PFL5332D 42 in. LCD Television
Manual for samsung es65 camera I would like to view my pictures on my samsung TV I was told I could do this direct from the camera to the TV just by using the a/v cable Is this correct and if so what ports...
You can download a user manual from here:-
http://downloadcenter.samsung.com/content/UM/201002/20100202195655453/ES65_ES67_English.pdf
You should have a AV cable with the camera, that has 1 round plug at one end and 3 round plugs at the other.
The single end plugs into your camera, there is a socket on the side marked AV. The three plugs at the other end go intot the TV.
They are colour coded (White - audio left, Yellow - Video and Red - Audio right) you need to find three sockets on your TV which match. Once connected and a slide show running on your camera, select one of the AV tv channels on your tv remote control.
If there isn't the 3 colour coded sockets on your TV, there probably is a couple of SCART connectors on the back (Big black socket with about 20 holes) You can buy adaptors, from electrical stores, which convert your AV cable out to a scart. Its just a box with the 3 coloured inputs and a scart output.
Jul 03, 2010 | Samsung Cameras
We cannot view camera images on TV from G2. We could in the past. Image in camera viewer goes blank when plugging tv cable into camera. Tried new cable. Still the same. Has something failed in camera?
Hello. I'm not sure if the camera has failed but try this sequence.Plug camera into tv then turn on camera then push review button. This is the only way 2 of my cameras will work for tv viewing.
Builderdale
Feb 26, 2010 | Canon PowerShot G2 Digital Camera
Unable to view moves from the camera on my TV set.
this could be correct as the signal for the Camera LCD screen is now being sent to what ever device is connected on the TV out cable.
ensure your connection is
Camera - TV out
TV - Video in.
ensure that your TV is set to the correct channel or input setting to view the signal from the camera.
Nov 14, 2009 | DXG Technology DXG-565V Flash Media...
Canon EOS XTi video output not working
Check that you have the right video cable first. It should have a plug with three contacts at the camera end and 1x black and 1x yellow plug at the other. Check that your camera is set to the correct video output for your region.(NTSC/PAL setting is found in the menu) To check the camera is working correctly, press the playback button to display an image on the lcd and then plug the cable in. If the screen does not blank the camera has not detected the cable being plugged in. A service centre would need to repair the connector or board if that is the case.
Mar 29, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Sony DSC-W170
Your Sony Cyber-Shot DSC-W170 came with a cord that had a little flat plug on one end and three separate plugs on the other end.  The single plug goes into the bottom of your camera.  The end that has three plugs has
(1) USB
(2) video output
(3) audio output
(2 and 3 are for hooking up to your TV)
If you connect the USB end to your PC and the single, flat plug into your camera, this acts as the USB cable.  There is no USB plug on the camera (for just a USB cord).
Feb 23, 2009 | Sony Cyber-shot DSC-W170 Digital Camera
Canon powershot A85 camera, only seeing black and white on TV
Please check Yellow video connector in TV and hook camera video cord there to see color picture of Canon A85
Feb 20, 2009 | Nikon Coolpix 5600 Digital Camera
Jazz dv179
The Charger has a standard two pronged plug to go into the wall. The other end goes into the camera at the back bottom. You will see the female received for the male plug.
Dec 18, 2007 | Jazz DV-179 Digital Camera
Video Cameras Logo
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
