Question about Cobra Radio Communications
How to fix the charger of cobra cxt 227,I try to charge it one by one but it still not charging
The charger is not working how can i fix it
SOURCE: Cobra PR3850WX will not recharge batteries
There is a contact in the upper left hand corner of the batt compartment.This has to touch the metal of the last batt.If your batts have paper around them scrape it off where it contacts that contact point.
Posted on Nov 18, 2008
eradiostore
  • 1654 Answers
SOURCE: my charger will not charge
1) Clean the battery contacts on the radio, battery and charger with a pencil eraser.
2) Test the charger by turning the radio on while attached to the charger (do NOT transmit, as this may cause damage to the unit). If the light on the charger comes on while the radio is turned on, you have a good charger, and a bad battery.
3) If the above test detects a bad battery, replace the battery.
4) Not sure if the battery is bad? Trade the battery out of a known good unit into this one to see if it solves the problem.
Posted on Mar 11, 2010
SOURCE: I have the cobra CXT275
Just went to their site and this is what it said:
This may simply be a matter of misinterpreting the low-battery indicator. We use two different types of battery indicators:
  1. Battery Level Indicator: This battery indicator is always visible, and has several segments. When all the segments are lit, the batteries are full. When only the last segment is lit, the batteries are almost exhausted.
  2. Low Battery Indicator: This type is usually NOT visible. It only appears when the batteries are low, at which time it flashes on the display to warn you of a low battery condition.
Please note that when you turn on your radio it first performs a display test. Everything on the display will light up for a few seconds, including the Low Battery Indicator. This does not mean that the batteries are low. After a few seconds the display test will end, at which time the Low Battery Indicator should go away.
Posted on Feb 01, 2011
  • 33 Answers
SOURCE: I have a pair of
Your batteries may be bad. Sometimes over charging batteries will cause them to wear out.
Posted on May 05, 2011
  • 52 Answers
SOURCE: Problems charging Cobra Walkie-talkie MT800 battery
Downloading the manual will now make the batteries charge?
apimom
Posted on Jul 23, 2011
CXT 195. What amp charger to use?
Do you mean 145? I cannot find a 195 on their web site. The CXT 145 comes with a USB Y charger cable, designed to charge off a USB port. Use a high output USB adapter. Amps of 1 to 3 should work fine. You are using rechargeable NiMh batteries and they do not care as long as it is at least 1 amp. Higher amp will charge a bit faster and make the batteries hotter.
Aug 01, 2015 | Cobra Radio Communications
What charger do I use on my cobra walkie talkies model number cxt 195
Any micro USB, or take out the batteries and use an external charger.
I put new batteries in my Cobra 2-way radios and charged them for 24 hours. Still shows "low battery" when I turn them on.
Check your charger and battery contacts. Cleaning battery contacts on the radio and charger with a pencil eraser will remove dust, dirt, debris, and hand oil which may cause the battery to charge poorly. Secondly, you might want to check that your charger itself is working properly. If you have a second known good radio you might try charging it on the same charger.
Best regards.
Sep 28, 2014 | Cobra Radio Communications
Batteries only hold charge for hour or two
put in different brand batteries.Use name brand not the cheapo's
Jan 20, 2014 | Cobra Radio Communications
Cobra Mirco Talk CXT 195
pls check usb cable , replace with new gud quality short length usb cable n try to connect the same in back side USB port not front side ..
Jan 15, 2014 | Cobra Radio Communications
How long should you charge the batteries on your Cobra cxt235 when you first get it?
usually overnight is the best with the radio turned off.
Always charge your batteries with the radio turned off, else you'll burn out your batteries before their time was due for replacement.
I hope I have answered your query for you.
Best regards,
Peter
Feb 14, 2013 | Cobra Electronics cxt-235 Microtalk Cxt235...
How long should you charge the batteries when you first get it?
you never want to over charge any batterys with most kinds of batterys 30 mins is a good time to charge them for if they need to be charged longer you will want to allow the battery time to cool down before charging agian.
Manual for Cobra Micro Talk CXT 275 Manual
I have this manual. I looked online at the Cobra site for a digital copy, and the manual for the CXT225 is a very close match. I checked it page by page and only found one small difference in the section on charging the battery. (Don't leave it on the charger more than 24 hours). Here's the link to the CXT225 manual: https://www.cobra.com/downloads/manuals/CXT225_MANL.pdf
Oct 25, 2012 | Cobra Two Way Radio
Cobra HH 40 charger specs
I have a Cobra HH-40 CB radio and am charging it as I type. The included charger is rated at 16V DC, 100mA. The pattery pack charges 10 AA rechargable batteries (the manual specifies NiCd, but you can also safely use NiHM). The 12V DC car charger included cannot be used to charge the battery pack, but can power the radio.
Mar 25, 2009 | Cobra Radio Communications
Radio Communications Logo
44 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
