Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Projection tv My red light on my mitsu projection will not stay converged with the other two lights. Its like wathching 3D tv. All of the lights still work but when you manualy adjust the convergance it goes out of alignment within a few minutes. Have you ever seen this befor?
I have a
Posted on Apr 22, 2008
  • 63 Answers
This symptom indicate that your tv convergance ic faulty need to replaced ( change out all the two ic )it will solve the 3D effect problem,hope it will help.
Posted on Aug 03, 2007
My Mitsu rear-projection WS-B55 was purchased in '03 or so. Now the screen is sometimes turning red. I can do a system reset, and the color goes back to normal. Then it eventually (maybe days later)...
No,pictures go all red?Pictures have colors shaded shadows or 3D pictures look alike?Yes,than the tv it is developing a problem known as a convergence problems it dying.The tv convergence board have problems,must be resoldering those 2 or replaced 2 STK covergence ICS and some or all of it resistors too.To fixed the tv convergence board,to solved the convergence picture problems.The shop,will cost u like $300-350 for diagnose the problems and do all the resoldering work or replaces those parts on the tv convergence board.
Apr 08, 2011 | Mitsubishi WS-55809 55" Rear Projection...
I turn the tv on and it comes threw with a fogy green and red picture with very little blue. there was dust on the lens and i cleaned them but and all the lights light up but still the green and red. i...
TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 27, 2011 | Philips 55PW9363 55" Rear Projection...
Picture stays red with blue background and adjustments make no difference
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 17, 2011 | Philips Magnavox 9P6034C 60" Rear...
It will turn on, but as soon as the bulbs light up, the tv will go blank and the red power light will start blinking.
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 13, 2011 | Panasonic PT-47X54 47" Rear Projection...
Tv turns off red light flashes and i hear a chriping sound
This problems is also parts of tv convergence board have dead 2 STK convergence ICS and some or all the resistors dead too.This problems the 2 STK and some or all it resistors are completely dead that why u only have red flashing light and chirping sound only.If your tv have any life function left of the tv convergence board u would have only mis alignments of colors R,G,B lines,have colors shadows or 3D pictures look alike.The shop,will cost like $300-350 to get the tv convergence board fixed also fixed this problems too.
Jan 05, 2011 | Hitachi 53UWX10B 53" Rear Projection...
Left convergence on mitsu vs-60609
Convergence IC's inside of your TV are nearing end of the life. If during adjustments that you made Red and Blue was moving in all directions (left, right, down, up) than resistors and fuses still probably OK. IC's (part number will start with "STK" and they attached to huge aluminum radiators) have to be replaced and fresh heat sink compound have to be applied.
After that convergence adjustments should not be a problem. And color will stay together for another several years.
regards.
Russ.
Apr 04, 2010 | Mitsubishi VS-60609 60" Rear Projection...
I have a mitsu VS-45605 and it seems that all 4 main colors have split. is my tv toast?
Projection TV2_bing.gif sets have several common problems listed below.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Mitsubishi VS-45605 50" Rear Projection...
I have a Hitachi 43UWX10B that won't turn on. When I try, the red power light flashes, and I hear intermittent chirping. Any way to verify the problem and estimate repair costs?
Your convergence chips have failed.
Sometimes when they fail the TV will look 3D or distorted and sometimes it will just loose video and audio and chirp.
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly. 4) TV Chirps
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 05, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Colours are out
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Mar 10, 2009 | Toshiba 42H81 42" Rear Projection...
Mitsu 47 inch tv's red light convergence is off!
The solution involves replacement of STK393-570 IC , which is
usually done by a skilled tech.........T.
May 22, 2007 | Mitsubishi WT-42313 42" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
53 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
