Question about Water Heaters
How to empty edesa water heaters - Water Heaters
2 Suggested Answers
AndrexT
  • 20369 Answers
SOURCE: Edesa t e 1500 water heater I need the Base plate that holds the statt and 2heater elements c 150 type
38.26 UK Pounds from here. Check it is the right model.
Electric water heater
Posted on Oct 08, 2016
I have replaced this old water heater. But I am not able to get the water out of this water heater. There are some sediments and water it not coming out. How can I empty the water?
I had the same issue a few months ago. To clear the sediment blow back into the hose making sure the valve at the tank is open. I had to blow two or three times during the draining process. 50 gallon tank took about 45 minutes to drain
Dec 09, 2013 | Rheem 50 Gallon FVR NATGAS Water Heater...
Do you have to shut off pilot when draining a rheem hot water heater
No.
But if tank is empty for days, you don't want the water heater firing, since it will eventually affect the metal heat-transfer surface between water and flame.
http://waterheatertimer.org/images/Gas-Water-heater-diagram-50.jpg
http://waterheatertimer.org/How-to-repair-Rheem-FVIR.html#air-intake
2) Add comment and say what you are doing.
Jan 24, 2013 | Rheem Water Heater Drain Valve
Do I need to empty my water heater to change the bottom thermostst.
For safety reason, You've better empty your tank first before work onthis thermostat.
Regards
Apr 24, 2011 | Water Heaters
Empty boiler
Turn main water off to the water heater, it may be a valve on cold side coming in to shut off. Next turn power off to the heater and drain the tank the drain will be located near the bottom of the tank.
You will need a water hose to connect to the drain to run water outside. Open a faucet hot side to allow you to drain the tank.
Upon reinstall connect the tank up and fill tank and open up hot side on one faucet at a time to purge out air from system before turning power back on. Make sure you have water flowing from each faucet's hot side before turning power back on.
Jul 02, 2010 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Empty water from hot water unit?
Shut off the valves going into the top and connect a hose to the drain at the bottom. Open the drain valve and lift on the safety valve, on the side near the top. The water will drain out of the hose.
Dec 26, 2009 | Toto Water Heaters
Hot water heater will not stay lit
It could be that you need a new regulator if the pressure was low - and now is high - but it's over-compensating - virtually shutting off the supply.
Check all valves are fully open - and any water traps are empty. It is possible for there to be a condensate in there - that is occasionally blocking the nozzle - causing a flameout.
If there is any yellow flame at all or signs of soot- get the unit serviced.
Aug 28, 2009 | Water Heaters
Water Heaters Logo
300 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
