Question about DeLonghi EC410 Espresso Machine
Ec410.b Poor steam pressure
I have vapour / steam coming out of my oil dipstick tube on my 1.8 diesel Ford Galaxy, is this to do with a faulty / worn pcv unit. Would this also contribute to poor starting if the valve is faulty?
The PCV allows one way flow and vents pressure (gases) from the engine and sends them to the intake side of the air breather for re-introduction into the air intake system of the engine.
A non-working or stopped up PCV can cause a build up of pressure, which must vent somewhere. The oil dip stick is often the choice, especially if there is not a tight seal at the top of the tube.
White smoke or steam/ vapor usually means water is entering the internal workings of the engine. Head gasket leaks, cracked heads, and cracked blocks are the common source of such entry. Also water leaking into a cylinder will cause hard or poor starting as the piston is working against the volume displacement of the water. Upon cranking any water so leaking will be exited through the exhaust system and leave the vehicle as a white vapor out of the tailpipe.
Considering that most diesel engines have some "blow by", some water may be expelled out the PCV circuit.
Oct 09, 2016 | Ford Cars & Trucks
Why is steam flow poor?
cause steam loss, poor pressure control and result in energy loss,transfer potential through its impact on steam flow, steam temperature, and heat energy. House Office Carpet Residential Commercial Cleaning Geelong Commercial...
g" alt="25835367-uz2mdiououqsymi0uafmfkop-1-0.png">
Aug 24, 2015 | Black and Decker USA BLACK & DECKER Steam...
Why does my wrinkle release not work?
Poor water pressure? Corroded water line plugged with calcium from hard water? Water inlet valves not open? Bad steaming printed circuit board?
Jun 22, 2014 | Samsung 7.4 Cu. Ft. 13-cycle Steam Gas...
Wet steam, poor pressure
Have you tried cleaning the steam wand nozzle with a paperclip (or the pin tool mounted in the back door of the unit?
Milk deposits can make their way inside the nozzle and block it, describing the symptoms you're getting.
Apr 12, 2014 | Sunbeam Cafe EM6910
Poor heating of cappuccino
descale unit as per user book. this will increase steam pressure and thus milk temp.
Feb 02, 2014 | Jura Capresso IMPRESSA Z6 13299
The steam in my handheld steam shot does not seem to be very hot therefore the surfaces, specially cloth ones do not get clean properly. What should I do?
If it steams it is as hot as it is going to get. Water steams at 212 degrees F at sea level so the only way to increase that heat is to pressurize that steam to a higher density than sea level which is about 32lbs per sq. in. Your steamer has no method to pressurize that steam to increase that heat. Conversely, as the pressure decreases, say you live in Denver which is about 5000 ft above sea level, then that steam will only get to about 203 degrees F. (See: http://whatscookingamerica.net/boilpoint.htm) Steam Cleaning at best is a poor method of cleaning as all it does is saturate the clothing item with water, which in theory loosens dirt, but no way is provided to remove the dirt. A rug shampooer has a vacuum that sucks the dirt away from the carpet along with the suds for a better cleaning method. In my opinion a hand steamer will only remove wrinkles at best.
Mar 20, 2011 | Bissell Vacuums
No Pressure when extracting coffe
it's quite simple, Quite Simple: manual says packing grounds too tightly/ too fine a grind causes this problem; does your steam wand put out adequate steam? if so, don't pack so tight. of course, the manual is full of lies, so chalk it up to poor workmanship/quality control at factory/bad design/bad business practices a'la lower end breville machine. take yer pick.
Nov 05, 2008 | Breville ESP8XL Espresso Machine
Milk temperature setting
Hot Milk:
steam pressure time 6
puls width 1
puls period 15
Milk Foam:
puls width 1
puls period 15
Hope this will help you.
/Mirran
Aug 28, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
DeLonghi EC410 Espresso Machine Logo
22 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
