Question about Microsoft Zune JS8-00001 Digital Media Player
Sro3013 wont connect
Plug it in to computer but tells me to add device
WHEN I PLUG IN MY PHILIPS GOGEAR PM3 2GB PLAYER IT TELL ME THAT ITS OKAY TO DISCONECT AND THATS ALL IT DOES !IT WONT TURN ON AND IT WONT POP UP THE BOX TO ADD MUSIC ... WHAT DO I DO ?
Heh.
When you plug in ANY MP3 player, it will show a general screen saying not to DC or that its charging. As for adding music, check your "My Computer" area, look for removable devices. And please, talk without caps lock on, it makes you look unprofessional, people will read it the same either way.
Hope this helps
Aug 06, 2010 | Philips GoGear HDD075/17 MP3 Player
I cant load my olmpus 300 on to pc,loaded camedia on ok but wont pick up my camera,tried to load it using devices butsays not in right file.checked usb devices,tried to add device but not having it
Consider NOT using the USB connection.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Jun 17, 2010 | Olympus Camedia Stylus 300 Digital Camera
"No Printer Found"
This sounds like your OS is not recognizing plug and play devices. You can try to do manual install from a CD or Manufacturers site.Just go to control panel and printers and click add printer and click add local printer and just follow the prompts. Make sure printer is unpluged from the pc before installation wizard tells you to plug it in since some will not install if plugged before driver or software installation. Hope this helps.
Mar 04, 2010 | Dell 1110 Laser Printer
HP DV9000 laptop - wireless router stopped working in computer. Won't connect - top it off I take it to computer repair shop and lost everything on hard drive - they can't tell me if its hardware related....
First I would replace the drivers, and check the device manager for any conflict with the internal router and the wireless device. then run the add hardware App and let windows Plug and Play find the device. with thye drivers re-installed it should come back, If it dont the have the motherboard replaced.
Jul 14, 2009 | HP Pavilion dv9000z Notebook
I can't add music to my device.
the usb port encountered a problem with your device and will not recognize it, restart your computer and try plugging it into a different usb port on your CPU.
Jul 08, 2009 | Audio Players & Recorders
The computer wont recognise my mp3
try messing with the usb settings on the mp3 player in settings/ system settings/ USB mode/ for a newer PC try MSC for an Older PC or mac try Mtp and if that dosen't work try auto detect just mess around with it fir a while
Apr 09, 2009 | SanDisk Sansa Fuze MP3 Player
My Computer and iTunes does not recognize my iPod
For it to recongnize, maybe try:
1: go to control panel
2:add hardware
3:connect your hardware device and click "yes i have connected the hardware"
4:scroll down and select install new hardware device
5:select install hardware that i manually select from a list
6:scroll down to windows portable devices
7:and choose MTP device
this should make it so your ipod is now recognised by the computer
---John
Give credit to Randomassist
Nov 24, 2008 | Apple iPod nano
Zen v plus - won't connect
I found the solution. When I connected my device to computer, it was unknown. I tried to reinstalled the software; however, the problem was still going on. To solve it;
1. Connect your device to your computer,
2. My computer, system properties, device manager
3. Find Creative zen which has attention icon
4. Click the Zen and then delete it
5. Plug out your device, and plug it again. That's all.
can1043
Oct 19, 2008 | Creative Labs ZEN V Plus MP3 Player
RCA TH1602 MP3 Player
As you plug the device into the computer, hold down the Play button. Leave it held until you see that it is installing new hardware (something like ROM initializing). If this doesn't work, you may need to add devmgr_show_nonpresent_devices=1 to your environment variables (search that variable to find how if you don't know) and then in the device manager go to view and show hidden. Make sure the device is not plugged in and then remove all references to it in the device manager (any grey USB MSD or HID is what I removed). Now plug in the device while holding in the play button. I had to reboot to complete this part. Now you should be able to load the firmware (this was required here, it will format the device so there will be no files on it, including the ones that it shipped with).
Oct 15, 2008 | RCA TH1602 MP3 Player
I have a dvd writer model LG GSA-E60L an when i install windows xp tells me that it is not digtally signed and also it comes up with error41 cant find hardware wont let me install and also i cant find my...
Code 41
Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)
Recommended resolution
A driver was loaded but Windows cannot find the device. This error occurs when Windows does not detect a non-Plug and Play device.
If the device was removed, uninstall the driver, install the device, and then click Scan for hardware changes to reinstall the driver. If the hardware was not removed, obtain a new or updated driver for the device.
If the device is a non-Plug and Play device, a newer version of the driver might be needed. To install non-Plug and Play devices, use the Add Hardware wizard. Click Performance and Maintenance on Control Panel, click System, and on the Hardware tab, click Add Hardware Wizard.
On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
Jul 08, 2008 | Computers & Internet
Microsoft Zune JS8-00001 Digital Media Player Logo
115 people viewed this question
Top Microsoft Audio Players & Recorders Experts
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
