Question about Hunter Electrical All-Weather 3/4'' Round, 48'' Extension Downrod - DR-48 AW Fan
Kohinoor delux usha fan circut diagram
Hi,i have one Usha Fan Kohinoor Delux model, Capacitor and resistance and Regulator inter connections diagram required. all the connections are detached.
How give turns of the usha padastal hyspeed fans coil rewinding
The only time that I have rewound a transformer, I measured the length of coils when they were unwound as opposed to knowing the number of turns.
Jul 18, 2015 | Garden
How saree edgimg can be done using usha janome wonderstich
saree edging prosuder usha wonder machine
Dec 31, 2011 | Sewing Machines
Wall fan remote control usha made not working
Did you repalce battery?Check first if the battery is good and the connection.Also claen the sensor of the remote and the unit.
Jul 13, 2011 | Dryers
Hi i am planning to by usha Janome Allure. is it corect choice
Usha Stitch Magic is much better choice. It has much more stitch types that are good for towels and kitchen napkins. It is really sleek smooth and easy to operate. If your are passionate about stitching, it is worth the extra invesment. The best part of this machine is the interlocking stitch.
Hope this helps.
Dec 30, 2010 | Vacuums
How do you clean the gill on the Sharper image delux spire fan
I recommend using canned air to blow it out from the front. If you have access to a compressor, this works even better. Farmerbear at FixYa.com
Sep 30, 2010 | Sharper Image Deluxe Spire SI788SNX Tower...
Why does a table fan slow down after some time?
Revolving blades in table fans pushes out air towards the front by creating a vacuum at the back of the induction motor. Other than providing air flow, the gush of air also cools the motor. Over time, esp if used in a polluted surrounding, dust collects inside the motor and causes friction in the shaft. If left for a prolonged period, this friction causes heat eventually drying up the lubrication, causing breakdown in the motor amature windings and also a leaky starting capacitor, thus slowing down rotation and also a complete failure.
2. Fans must be regularly taken apart, cleaned and lubricated. It is fairly easy if you are willing to learn. My India made Usha brand table fan is 48 years old and is still running smooth - just changed the start capacitor last year and my National ceiling fans are more than 35 years old.
3. In fact all moving parts in any equipment must be periodically taken apart, cleaned free of dust and grime and freshly lubricated. It will outrun your lifetime and serve the next few generations.
Best Regards,
Mahathev of Malaysia
May 29, 2010 | Cfm 802 Ecofan Table
Usha wonder stitch motor speed very slow ,asked to replace motor
I think try some good quality lubricant first..
here you can find usha sewing machine details...
Aug 13, 2009 | Janome 6019QC Mechanical Sewing Machine
Hi FixYa team, I need a Manual for USHA Janome Wonder
www.mouthshut.com/.../Sewing_Machines_reviews-925345.html
Jun 19, 2009 | Janome 6019QC Mechanical Sewing Machine
Dryers Logo
235 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
