Question about Marantz Audio Players & Recorders
Marantz 2200 turntable speed will not adjust
The turntable will only run on 45 speed and not on 33
3 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: Sony PS-LX250H turntable speed adjustment on underside, how??
Great detective work.
Let's collaborate on this for the benefit of others who may have the same problem.
L.IN should be the point at which the Lead-In groove on the LP would be, where the tonearm will drop to play an LP
RET should be the point at which the tonearm will lift up and RETurn to its rest at the end of the LP
That leaves us with SW. If your source is right this will affect the Speed. I can't imagine what the W stands for.
Since this turntable lacks the traditional strobe light and dots along the platter rim for determining if it's on target speed-wise we have to improvise and make a Strobe Disc.
It has radial marks on it and you place it on the turntable like a record. The lights in your room running at 60hz will make it appear to be stationary if the speed is correct; slowly creeping CW if too fast; CCW if too slow.
Here's a link to a PDF from which you can print your own disc... http://www.extremephono.com/ftp/60Hz.PDF
Here's what you do. Lay the trimmed Strobe Disc on top of a record while it's playing one of the outer tracks. This is because the stylus imparts some drag so we want to factor it in.
Then adjust the screw exactly one turn Clockwise and note how the speed has changed. Trial and error should get you to where you want to be.
Posted on Apr 05, 2009
Grubhead
  • 5126 Answers
SOURCE: My turntable runs fast. At
There are generally two ways the speed of a turntable is set. Firstly in the power supply section, you might find two presets one for 45 and one for 33. These are adjusted by placing a screwdriver in them. The other way is by presets in the bottom of the motor. This generally only applies to the 9 to 12 volt motor types used mostly on belt drive turntables.
Posted on Feb 16, 2011
Record player turntable runs too slow. How to troubleshoot?
If this is a belt drive turntable the belt might be in the wrong position or is slack due to wear.
Jun 12, 2017 | Audio Players & Recorders
2 problems, 1st turntable run at 45 speed when on 33 setting. 2nd, turntable won't move unless you help it.
It depends if these are belt or direct drive decks. If they are belt, then in the first fast speed one the belt might have slipped and is now on the 45 setting when it should be on the 33 setting.
The other deck has either a really **** belt, or a bad motor, or needs oiling or having grease or muck removed from it's works.
A whole list of problems can make direct drive decks act this way.
Oct 31, 2015 | Audio Players & Recorders
How do I adjust the speed of a Sony LX250H turntable? The answer is not in my manual.
Presumably you mean correcting the speed to play 45 and 33 correctly?
Some turntables have the speed control(s) as a preset(s) built into the base on the underside of the unit. Often covered with a sticker. You simply remove the sticker and stick a small screwdriver in the thing and turn it.
Others have the preset inside on a circuit board, got to by removing the bottom of the turntable. Others have it built into the motor itself.
You should replace the belt first if the speed is slow on both 45 and 33, before adjusting the motor speed.
Apr 25, 2014 | Sony PS-LX250H Turntable
Turntable Speed Problem
the motor has gone or theres a short on the wire going to the 45 switch, or the switch is gone & isn't switching over.
Mar 02, 2013 | Audio Players & Recorders
What's the correct way to use the strobe light to set turntable speed?
The turntable may have a pattern on the edge of the turntable. If not you need a turntable strobe disk that you place on the turntable like a record. The pattern on the disk or on the edge of the turntable will be marked for 50 Hz or 60 Hz frequency.
The strobe marks on the disk or on the turntable are for 33 RPM and 45 RPM and for both 50 & 60 Hz mains frequency.
To adjust the turntable for the correct RPM, turn on the strobe light and the turntable set it to 33 RPM and shine the strobe light on these marks and adjust the speed setting until the 33 RPM marks appear steady and not moving. You may want to check it for 45 RPM as well.
Make sure you use the correct mains frequency marks ie. the 50 or 60 Hz that your electricity system uses.
Feb 25, 2011 | Audio Players & Recorders
My turntable runs fast. At the 33 1/3 selection speed, it actually runs at 34 1/2. There must be a way to adjust that speed. Can you help? Tks, Tom
Feb 13, 2011 | Philips Audio Players & Recorders
GOING FROM 45 TO 33
I don't know if this model is direct driven or by belt. If it's belt driven then the belt could be fitted incorrectly, or faulty. Another possibilty is that there's a fault in the motor control circuit.
Jul 28, 2009 | Gemini PDT-6000 Turntable
Speed switch doesn't work
hi, maybe you hve to replace the tack switch of your turntable even thougr you switch but the contactss maybe not in the connection,,
Apr 09, 2009 | JVC AL A158BK Turntable
My 33 & 45 speed giving problems
HELLO
I have just posted a cure for this deck, it is to do with the microswitches under the speed select buttons - they need to be replaced. Just repaired mine today - now there are no more problems selecting speeds.
If the speed goes back to 33 when the deck is switched off, this is because 33 is the default.
ALL THE BEST!
Nov 30, 2008 | Gemini PDT-6000 Turntable
Ion turntable speed problems
Turn the tturntable over, there is a speed control pot on the bottom
Nov 07, 2008 | ION Audio iTTUSB Turntable
48 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
