Question about Technics Audio Players & Recorders
Technics model SE-A808 completely dead Uses audio amplifiers chips typr STK 1050 Power supply seems ok but I am going blind as I cannot find the specs for the unit or the ouput amps chips Can you help TKs Marino Saksida
  • 10,594 Answers
Here is circuit for STK1050 that might help you to repair this unit.
I'm trying to get SA-A808 schematics and let you know.
Posted on Mar 12, 2009
  • 4,234 Answers
If you are looking for the STK1050 ICs, they are available at the following:
MCMelectronincs.com
BDENT.com
Dan
Front left channel on FISHER tad-9925 broken
Chances are that all you have to do is replace STK 411-230E.
Jul 10, 2017 | Fisher Audio Players & Recorders
My Technics SUV 660 is making a crackling and popping sound regardless of where the volume is. It does reduce once the amp has been on for an hr or so. Also the speakers are not consistantly on. Any a
If the sound is on both channels then it's probably a device that is connected to both channels. I don't think it's the power supply. I rather suspect it's in the power amp section, since it's not affected by turning up the volume. If the amp uses one of those STK devices as a power amp, it could even be that.
Image of an STK power amp below:
Feb 17, 2014 | Audio Players & Recorders
Technics SU-G75 overload
I have the same problem..it will be required to remove the board and resolder "cold " solderings... None of above solutions have been helpful, but "you get what you paid for"..and I completely disagree...even if required, remove ALL audio power managing circuitry and replace this expensive original design with TI´s Integrated chips..using PWM technology..unless you want to go back to L6, ot Kts tubes..
Nov 07, 2012 | Technics SU-G75 Amplifier
I am looking for the manuals for Technics SE-A808 Stereo Power Amplifier ST-K808 Quartz Synthesizer Stereo FM/AM Tuner/Preamp SH-R808 Infrared Wireless Remote Unit Kind Regards John
I don't believe that these are available electronically without cost. If you can describe the problem you are trying to solve, I may be able to guide you through the repair.
Dan
May 25, 2011 | Audio Players & Recorders
Power On + red LED turns on + but final relay (click) don't come so no sound
Your audio output transistors are shorted and your unit is staying in "protect " mode to protect your speakers from 40 to 60 volts that is being sent at them from the shorted outputs. If you can use a meter you won't need the schematic MOST likely because the outputs are USUALLY the only parts that short out. The output transistors( or chip ) are mounted to the large, finned heatsink. The #'s on the transistors start with "2SA-" and "2SC-" followed by numbers. There are two output transistors per channel. If your unit uses an IC for audio output then the # on the IC will be "STK-" followed by numbers. These parts are available from tritronicsinc.com. Good Luck!
barneyluc
Oct 17, 2008 | Denon PMA-2000R 2-Channel Amplifier
Technics su-a808 amp & sh-ge70 graphic equaliser.
connect your media source(dvd-cd player)to equalizer in-connect equalizer out to amplifier line in-or aux in-connect amplifier out to your loudspeaker.
Jun 24, 2008 | Audio Players & Recorders
Parts for Technics SE A900S Audio Power Amplifier
Here ya go.
http://www.vancebaldwin.com/products/?MSCAN7062
Mar 13, 2008 | Audio Players & Recorders
Technics SH-AC300 Connection to Power Amp & Pre-Amp
Hi!
The problem is, that your SH-AC300 needs an amp with 5.1 input (but no decoder). For this purpose technics delivered SA-AX710.
So if you'd like to use your current equipment it would be impossible.
The only option is for you to buy 2 more Power Amps (SE-A900S), so that each of 3 amps would take care for one part of music. (one for FL, FR; one for RL, RR; and one for sub and center).
Another option is for you to buy SA-AX710. Then all the problems would be solved with it.
Jan 15, 2008 | Technics SA-DX950 Receiver
371 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
