Question about Hasselblad Flexbody Medium Format Camera
Phase one digital back not working on flexbody.
Does digital mean the tramsmitions are printed out on the screen?
no
It means the radio transmissions are converted from analogue sound waves into a digital format. Then the radio uses a phase shift technique to encode digital information on what is in reality an analogue radio signal.
The receiver then converts the digital signal back to analogue for the sound waves out the speaker.
The advantage is that amplitude variations do not affect the quality of the radio and error correction techniques may also be employed to fix errors in the digital information.
https://en.wikipedia.org/wiki/Phase-shift_keying
Feb 17, 2016 | Radio Communications
M29 wiring diagram
M29 is a semi automatic machine. Wiring is straight forward with the normal variance for single phase and 3 phase. Sorry i don't have a digitized diagram on hand. Maybe later. Dosing, is done with the control board which will need replacement if its not working.
youtube; ukeboy57
Mar 14, 2014 | Espresso RMI La Cimbali Espresso Machine
Digital inverter generator has no 240 volt output
Most power inverters are strictly single-phase. Meaning true 120V or 240V, and no splitting or duplication. It sounds as if your inverter is a single phase 120V, and likely is not stackable on the AC side.
I recommend looking for a Low Frequency Split Phase power Inverter if you want both 240 and 110 volts.
Aug 09, 2013 | Vacuums
SINGLE PHASE WIRING DIGRAM
You need a single phase motor to do that. A 3 phase motor cannot be made to run on one phase.
May 16, 2013 | Ingersoll Rand - Rand Type - 30...
I have a miller cp 300. It is wired for 3 phase power. I need to hook it up to 230 volt power. How do I do this correctly.
You cannot do this... 3 phase and single phase cannot be inter used... see 3 phase is 440 V AC, single phase is 230 Vots AC. This is unless the unit has Dual capability, in this case the wiring could only be wired to a Single Phase. of the unit. You will need a slow blow breaker of the correct rating and also the cable must be similarly CURRENT rated. If it IS only 3 phase, you can purchase after market single phase to 3 phase converters, that will allow you to plug the 3 phase into a single phase circuit and work, they quite costly though.
Mar 22, 2010 | Welding Tools
Powerline ehernet adapter stuck in standby
1. plug out from the electricity socket and plug it in back
2. check with the electric phase because powerline adapter works only with a single phase in the house
3. a house will have different phase try connecting it in the same phase of the router.
4. or else try updating the firmware from the website for ur particular powerline adapter
Feb 08, 2010 | Powerline Ethernet Network Adapter
3 phase to 1
hi,
u can change the 3phase heater to single phase.apart from all the component are of 1 phase.but consumption of current will be mre.apart from machine will run normally.
Mar 21, 2009 | Meiko FV 40.2 Dishwasher
Dusty smoking smell, stops working, trips out power in house.
you forgot to say if it is a 3 phase machine
if it is 3 phase then a phase in the unit is overheating and that will stop the machine then blow the breaker as all phases have to draw equal current
if it is a single phase then the start/ run capacitor or centrifugal start run points are not breaking at speed and so the start windings are overheating and causing the breaker to trip
Take it to an electrical motor rewind shop and have it properly tested with test equipment
Oct 21, 2017 | Hoover F6212-900 / F6215-900 SteamVac...
Vulcan vfbi2 flashbake oven change from 3 to single phase
Are you sure it says that in the manual? I have a single phase. Look at the plate on the motor on the back. If it is 3 phase, forget about changing it over.
Charles
Aug 16, 2008 | Ovens
Hasselblad Flexbody Medium Format Camera Logo
123 people viewed this question
Top Hasselblad Photography Experts
pontelemon
pontelemon
Tony
Are you a Hasselblad Photography Expert? Answer questions, earn points and help others
