Question about FindingKing 144 Key Chain Craft Wallet Nickel Plated Findings
Key case parts supply
Line of key hooks for a key case - craft project
    Guru:
  • 42 Answers
Posted on Mar 03, 2015
I have no power going to my Janome memory craft 11000 it's as if a fuse has blown
The Janome Memory Craft 11000 does indeed have fuses on the main circuit board. Often, if one of the motors becomes overloaded, as is occasionally the case if thread gets bound up in the hook/bobbin area, it will blow one of the fuses, to prevent serious damage to the motors or mechanical parts.
They are not easily removed at home, and doing so would not be advised as you would be dealing with delicate electronics on a very expensive machine. I would recommend taking your machine to a Janome dealer to have it fixed. There are a few other possible problems, thought the fuse is most common, and it would be better to have it diagnosed by a technician.
Mar 11, 2015 | Janome Memory Craft 10000
Why does The bobbin holder keeps 'crashing' with a metal 'arm' on the left.
Hum, nothing should
"crash" into anything else while sewing. The Hook (place where bobbin case snaps into) might have a broken "keeper" (internal part that "keeps" the hook stationary when sewing.) Or your bobbin case may not be installed completely or correctly.
Cheers,
Kelly
May 03, 2014 | Janome Memory Craft 9000 Computerized...
I'm doing a rubber stamping project. Should I buy a craft knife?
Yes, you should. craft knives are really useful in rubber stamping. A basic craft knife is all you need. You use the knife to carve the design you want.
Jan 17, 2013 | Office Equipment & Supplies
How to Buy Craft Supplies?
Take inventory of what you have on hand. Before you buy anything, look closely at what you already have.
Create a timetable. All crafting projects should have a rough timetable for completion.
Get specific. Crafting projects often call for specific materials. Measure the materials, if possible yourself. Bring a tape measure to the store.
Work with multiple suppliers. A single store may specialize in wood related crafts. Another may have materials vital for knitters. Buying from more than one store can give you ideas that you may not have realized until then.
Aug 16, 2010 | Crayola Crafts & Hobbies
Where can i buy craft supplies online?
There are some great websites online for craft supplies like Crafts Etc., BJ's Craft Supplies, All Craft Supplies, JoAnn and many others. You can find more information here: http://www.bjcraftsupplies.com/
Aug 16, 2010 | Blitz Crafts & Hobbies
What kinf of personal lifesaving appliances are needed for Sail and powered pleasure craft over 9 m and up to 12 m?
The Small Vessel Regulations set out the minimum safety equipment required on board a pleasure craft according to its type and length. In your case these are the personal lifesaving appliances needed:
1. One Canadian-approved personal flotation device or lifejacket of appropriate size for each person on board
2. One buoyant heaving line at least than 15 m (49’3”) long
3. Onelifebuoy attached to a buoyant line at least 15 m (49’3”) long 4.One reboarding device
Aug 12, 2010 | Cabela's Boating
When I sew it sounds like someing is scrapeing. I have cleaned the bobbin case and when I take the case out it still makes the scrapeing sound.
Sounds like the bobbin hook isn't in properly. Check you book and see that the part thta is a hook and race is inserted properlyl. If they are not lined up just right it won't work right and does make that scraping noise because it is scraping. There is a little red dot that has to be lined up just so. There should be a picture of this in your manual.
Jul 02, 2009 | Janome Memory Craft 9000 Computerized...
WS48515
You lost the 300v line to the tubes that pulls down the brightness. Trace back 300v line to power supply.
Sep 08, 2008 | Mitsubishi WS-48513 48" Rear Projection...
I cannot find out how to oil my Janome Memory Craft 6500 sewing machine.
About all you can or should need to do is remove the bobbin case and clean the lint and stuff out from under it. There is a wick in the center of the hook( the part the bobbin case sits on). Do not mistake this for lint and pull it out. Put a few drops of sewing machine oil on it. For anything more the machine should probably go to a technician as it involves splitting the case and there are some hidden screws. The machine should be serviced once a year if you use it a lot or less often if you don't use it that much. In no event should you go more than 5 years without a professional service.
sewman7
Jul 08, 2008 | Janome Memory Craft 9000 Computerized...
Hitachi Rear Projection Model 500X18B V4F001550 has converge problem. Colors won't align correctly and colors are weak. Tv is not bright enough. The vertical line has a static line. How can I fix it and...
Most likely bad convergence integrated circuits. STK394-160 is the Hitachi upgrade components. In some cases, the supply resistors may burn as well on the convergence board, but these are easily spotted.
Mar 03, 2008 | Philips 50P8341 50" Rear Projection...
FindingKing 144 Key Chain Craft Wallet Nickel Plated Findings Logo
150 people viewed this question
Top FindingKing Clothing Accessories Experts
Da Doc
ray gallant
Bill Boyd
Are you a FindingKing Clothing Accessory Expert? Answer questions, earn points and help others
