Question about Xerox Phaser 8500N Printer
User gets the above error on the actual printer " error 09.038.46:43938 "
  • 4,041 Answers
Solution:
  • Turn off the printer. Turn on the printer.
  • As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display.
  • Release the buttons, it will now come up in the service mode.
  • Scroll down to the function menu, hit ok, scroll to clear isc fault, hit ok. Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Posted on Jan 30, 2010
A friend has a Canon MP630 inkjet which seems to have seized up after a paper jam earlier. He's getting an error code of 5100. If anyone knows what that means it would be much appreciated. Thank...
Hello and Welcome to FixYa!
Error 5100 means that the cartridge can not be detected by the printer.
Actually the printer is not actually loading the cartridge and showing you the error
. To solve it:
First of all turn off printer
then remove both the cartridges from the printer.Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches. After it return the cartridges and turn on the printer.Error will be automatically remove
I hope this solution helps you
Thank you and Keep using FixYa!
Jul 20, 2011 | Canon MP830 All-In-One Printer
I can't print on my printer it says you're printer is currently offline
The users who are experiencing offline errors while using the HP printers are suggested to check the connections, settings and printer hardware before proceeding any further. The connection to and from the printer shall be verified thoroughly by the users and any anomalies if found shall be fixed then and there. As these errors can also be caused by printer hardware issues, the users are suggested to check with different key components of the printer like the cartridges, feed tray and more and fix any issues if found. Restarting the printer and the computer after following the above mentioned procedure will help in solving and preventing the offline errors with your HP printer.
Mar 16, 2011 | HP Office Equipment & Supplies
Printer offline. how do i get it back online
The users who are experiencing offline errors while using the brother printers are suggested to check the connections, settings and printer hardware before proceeding any further. The connection to and from the printer shall be verified thoroughly by the users and any anomalies if found shall be fixed then and there. As these errors can also be caused by printer hardware issues, the users are suggested to check with different key components of the printer like the cartridges, feed tray and more and fix any issues if found. Restarting the printer and the computer after following the above mentioned procedure will help in solving and preventing the offline errors with your brother printer.
Jan 10, 2011 | Brother HL 5040 Laser Printer
When I turn it on it starts to ware up and I get an error message engine panic
Can you give me the exact brand and model number of your multi-function printer?
What is the exact error message that it gets?
Any additional information will help us in resolving this issue.
Thank you!
Apr 07, 2010 | Konica Minolta PagePro 1390MF All-In-One...
My printer Brother HL-6050DN show ERROR E50. How can I fix it?
Oct 21, 2009 | Brother HL 6050 Laser Printer
Deve Home sensor Error as occur cannot get printer to work
The web does not offer alot on this error. However the users manual indicates it is a fuser issue. Try a new maintenance kit. That should include the fuser and all rollers.
Dec 16, 2008 | Samsung CLX 3160fn All-In-One Printer
Merroy error 100.10.10
There isn't a known error of 100.10.10 on an HP2600n. The is an extremely rare 101.000 which is color plane registration but I'm guessing your not getting that.
I'm assuming your actually having one of the following:
10.0000, 10.0001, 10.0002, or 10.0003
10.1000, 10.1001, 10.1002, or 10.1003
These are supply errors (toner cartridge). The toner cartridges have a smart chip on them and if it's not reading correctly you can get one of the errors I mentioned above in the "10" errors. In that case look at the last number in the string to isolate it. "0"=Black, "1"'Cyan, "2" =Magenta, "3" = Yellow. Simply replace the identified cartridge.
We have seen a lot of refilled or self refilled cartridges that the supplier or user didn't put a new smart replacement chip on the cartridge, pulled the chip without replacing or actually put the wrong one on the cartridge. This would cause the "10" errors. In some rare cases a surge in power can knock out a chip on the cartridge.
Here's a photo of the chip on the black cartridge to help you locate it.
If you are getting a "10" error identify the last number to identify the color and replace the cartridge.
If you are ACTUALLY GETTING AN ERROR 100.10.10, contact HP as it is an undocumented error and likely only HP may be able to resolve it. I have even researched the error through Canon (they make they base machine for HP) and Canon has no record of this error either.
I hope this helps you. If so hit it with a FIXYA. Thanks.
Aug 28, 2008 | HP Color LaserJet 2600n Printer
6B10 problem
If you still need the user guide, you may find it here: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=12804
I'm afraid that here is already a mechanical problem on your printer if displays 6B10. It's a paper feed sensor error on your printer that means you need to have it serviced with an authorized canon technician.
Hope this helps.
Thanks.
Jul 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Tally T2280 THS ERORR 001
I have been told that this is a Printhead, or Logic Board fault.
Git rid of it on customers by cleaning printhead(two screws then taking printhead out & cleaning connections, Replacing).
But now i have THS error 009 ??
Dec 11, 2007 | Tally Matrix T2280 Printer
Xerox Phaser 8500N Printer Logo
71 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
