Question about Bernina Artista 180
Portfolie Freezes As a scroll through my, it freezes. Turn-off the computer, try it again, it does it again. Three attempts, still the same results. Can you help, PLEASE!
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 135 Answers
Are you talking about a communications program on your computer that talks to your Arista? Your question is unclear so I'm not sure what problem you're describing here. However, if you're saying you have a problem with a program you installed on your computer to communicate with Arista... then Un-install the program from your computer. Use the "Uninstall" option, OR go to "Control Panel > Add/Remove Programs" and uninstall the Arista program from there. Then REBOOT your computer and re-install the Arista program. Removing and reinstalling programs like this almost always makes them work properly again.
Posted on Aug 03, 2007
SOURCE:
Computer screen freezes up
12121114 Brother4000D sewing machine freezing
104.238.136.22/F/.../t12121114-brother4000d_sewing_machine_freezin...
12121114 brother4000D sewing machine freezing all the buttons on my ... Machine has a short or some type or computer board problem - take machine to local Pfaff dealer and try with one of their ... Bernina artista 180 screen freezes up.
Sep 14, 2015 | Sewing Machines
Husqvarna sewing machine freezes and stops sewing
Is it a mechanical machine or computerized? If mechanical, it could need a good cleaning and oiling. Mechanical machines need to be oiled, and if not, the old oil solidifies and prevents the mechanical parts from moving.
Mar 15, 2015 | Husqvarna Sewing Machines
My Janome 11000 freezes up
you said it has been in the shop twice do you think that may be they did not check the circuit board out I think it might be in the timing or the board
Feb 07, 2015 | Janome 11000 Memory Craft Special Edition...
since the machine is freezing up it needs to be checked to see if it's
a computer problem or mechanical
Apr 11, 2012 | Bernina Artista 180
After about three minutes, the machine freezes. The power stays on but it will not run.
Sounds like the machine needs oiling. Get the proper oil from a sewing shop (not a department store) and put a drop of oil on every metal-on-metal moving part you can find.
Jan 15, 2011 | Bernina Sewing Machines
My brother CE 4000 sewing machine freezes. After some tinkering I can sew a little then in happens again. It makes a shuddering noise then freezes and shows an E6 error message?
Turn off the power and remove the needle and presser foot.
Remove the needle plate, bobbin and bobbin case.
Clean the shuttle and surrounding area.
Replace everything.
Make sure the flat side of the needle faces to the back of the machine.
Raise the presser foot and re-thread the machine.
Mar 06, 2010 | Brother Sewing Machines
Usb freezes up
If you're trying to see the embroidery designs on the stick, the embroidery unit has to be on the machine to view the designs in the larger size, so be sure to have it hooked up. If you're trying to select the regular stitches and the screen freezes, you need to take it in for service. You have a 5 year electrical / computer warranty on parts if you are the original purchaser. There will be a labor charge if it's over 1 year old.
Nov 07, 2009 | Husqvarna Designer I
Husqvarna designer se
There are 3 main fixes for a freezing SE.
1> Have the latest 12501 update installed, the 12124 had a problem.
2> make sure you have the right hook (the 2 older hooks have this problem.
3> The newer tension assembly with the grounding strap needs to be in the SE as well.
4> there were only suppose to be 3 but if your screen gets weird when it freezes, it could be the video transformer
Mar 03, 2009 | Husqvarna Designer I
My bobbin winder starts and then freezes and an alarm sounds-
Try to sew slower. In my sewing class the bobbin always freezes, and if I go slower it works better sometimes.
Jan 24, 2009 | Singer 7442 Mechanical Sewing Machine
Sewing Machines Logo
51 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Wayne Buss
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
