Question about Senco Fusion FN65DA 18V 15 Gauge Cordless Finiah Nailer
Firing pin won't return on my senco fusion gun
5 Suggested Answers
pocketwatch6
  • 7 Answers
SOURCE: Gun will not drive pins flush with wood. Wood is
What is your air pressure setting. A finish nailer such as this usually requires 70 lbs to drive flush. Adjust air to this value and test fire in scrap. Keep adjusting air presure until nail drives flush.
Posted on Nov 23, 2009
  • 10865 Answers
SOURCE: how to reconect the spring
helloo cerr..... here is a link to all of the senco manuals, parts etc. you should be able to get what u need from this link. you can print out the manual or just save it on your puter if u don't want to print it out. Joe
http://www.senco.com/ProductLiterature.aspx
Posted on Apr 16, 2011
  • 885 Answers
SOURCE: senco nail gun sfn30 is only firing every second nail in
You have damaged o-rings in the gun. Remove the head cap & valve assembly, remove the ring on top of the cylinder, remove the cylinder & piston. The cylinder is in tight so work it out carefully. Check the condition of the following: a split flat ring with a rubber o-ring under it on the top of the piston and two o-rings on the outside of the cylinder. If these are damaged air will leak around the piston instead of pushing it back up. The inside of the gun should be clean with a light coat of oil on everything if you are oiling it properly before use. Dirt in the gun means the gun is being laid on the ground without the air hose attached. Dry innards means no or not enough oil is being put in the gun before use. Oil pooled in the bottom of the gun means too much oil is being used. Senco doesn't make a rebuild kit for this gun, you'll have to go to the Senco website http://www.senco.com/ or other website like http://www.ereplacementparts.com to get a parts breakdown of your gun and order the o-rings (any part beginning with LB) individually. If you replace one, replace all of them and grease them up liberally when reassembling the gun.
Posted on Feb 02, 2012
  • 885 Answers
SOURCE: senco fram pro 602 nail gun firers but no nail just a hole from firing pin
First, check that you are using the proper nails. The FP602 needs Full Round Head nails with plastic collation. If you are using Clipped Head nails with the paper tape collation the angle of the nails not let the driver catch the next nail and drive it into your work.
If you have the correct nails, check the magazine to make sure the nails are feeding all the way up to the driver. If there is anything blocking the way or if the spring on the feeder isn't taught enough to pull the clip all the way up the driver won't be able to catch the next nail and drive it in.
Posted on May 08, 2012
Pin nailer problem
Nice video, you did not mention a model number so I will give you general information. If your nailer is oil free type (gun will have stamped on body, no oil ), and you have been using oil directly or indirectly, most likely rubber diaph. is bad or leaking slightly thru head. Replace headvalve. If your nailer uses orings in the head /headvalve instead of diaph. type firing valve, remove head pull headvalve and apply plenty of white grease or silicone paste and retest. If gun works with grease then most likely needs oring kit and or trigger valve or orings in the trigger. If the gun still will not function correctly with grease in the head, then orings in the trigger are worn. Good luck
May 23, 2013 | Air Tools & Compressors
Senco nailer won't fire nails, but the firing pin dents the wood almost 1/4 inch.
Hi Jes,
Are the nails moving freely in the magazine if you pull the mag spring back? If so, then the driver blade is not returning to top dead centre - leaving enough of the blade to stop the next nail moving into the nose. This could be caused by a slight back pressure in the cylinder so, check the exhaust is clean and free of any swarf. Or check the O Ring on the driver blade, even though you've just replaced them....
Mar 01, 2013 | Senco & Frame Pro 601 Framing Nailer
My senco frame nail gun isn`t working
First get an exploded view of gun and parts list and numbers from senco.com,,take nail gun apart,,,take a good look at the rubber bumper stop to see if it is broken,,look at the driver nut to see if it is tight,,,,you can go to juldan.com once you have gotten a list of the worn parts,,,juldan sells complete o ring kits along with nearly all parts needed for your repair
Jan 18, 2013 | Senco Air Tools & Compressors
Senco fram pro 602 nail gun firers but no nail just a hole from firing pin
May 05, 2012 | Senco Tools & Hardware - Others
SB 1842bn
When a firing pin won't return it's usually caused by damaged o-rings inside the gun. The most likely culprits are the o-rings around the outside of the cylinder or the rings on the drive piston. Another cause could be a cracked cylinder or bent driver. Remove the cap on top of the gun and check the condition of the o-rings, cylinder and driver. You'll have to order any parts that need to be replaced as Bostitch doesn't make a rebuild kit for this gun. Don't forget to lightly oil the o-rings with pnumatic gun oil when reassembling the gun. Most pin and finish nailers say they are oil-less but they still need a drop once in a while to keep the o-rings from being damaged.
Feb 14, 2012 | Stanley Bostitch HP118K 23 Gauge Headless...
Senco nail gun sfn30 is only firing every second nail in
Jan 29, 2012 | Senco Tools & Hardware - Others
I need a new firing pin for a senco finish gun
you can go to senco.com and with your model number you can download a parts diagram and also purchase parts from their site. Let me know if you need more assistance.
Sep 02, 2011 | Tools & Hardware - Others
Angle brader firing problem
not real familiar with the gun in question, but when i have that problem with my Senco guns I usually make sure the nose is clean of gunk and spray some WD40 up the nose
Jul 22, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Senco finish nailer not firing nails
firing pin called the driver is probably broken or needs new seals max air pressure 125 psi senco sells repair kits
May 13, 2009 | Tools & Hardware - Others
Senco SN4 misfiring intermittently
This is a discontinued tool by Senco but there are still parts available for it. It sound to me that the o rings and possibly the firing valve need to be replaced. I would recommend going to Senco.com and you will find a complete parts diagram in their discontinued tool section. They also have a toll free number if needed and you can talk to their air pro. I have rebuilt quite a few of these and they are not that hard just make sure to clean all the parts and use lube when replacing O rings.
Jan 01, 2009 | Tools & Hardware - Others
Senco Fusion FN65DA 18V 15 Gauge Cordless Finiah Nailer Logo
491 people viewed this question
Top Senco Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Senco Air Tool and Compressor Expert? Answer questions, earn points and help others
