Question about Microsoft Windows Vista Home Basic for PC
PC will not stay in sleep mode.
When I try to put system into sleep mode it automaticly restarts.
I'm using windows vista home basic.
    Problem Solver:
  • 12 Answers
it's not a hardware-problem - it's a windows feature PC will not stay in sleep mode. - smile_wink.gif - (and it really is one !) - please try this:
To prevent a USB mouse from waking your PC
1. Open Device Manager by clicking the Start button, clicking Control Panel, clicking System and Maintenance, and then clicking Device Manager.
2. In the list of device categories, expand Mice and other pointing devices.
3. Right-click the entry for the USB mouse, and then click Properties.
4. On the Power Management tab, clear the Allow this device to wake the computer check box.
5. Click OK.
Don't forget to do this with your mouse + keyboard !
Posted on Mar 12, 2009
Vista will not sleep
I may try, but first please answer these questions:
1. Which program are you trying to put Vista with to sleep?
2. Do you have a laptop or a desktop PC?
Of course I will reply, I always do.
Feb 24, 2013 | Microsoft Windows Vista Home Premium with...
Sleep/hibernate mode
Hi, If the computer seem to wake from sleep mode for no reason? Some device settings can cause the computer to return from a power savings state when not expected. If the computer is using an optical mouse, changes in light can cause the computer to wake. Network activity can cause the network hardware to wake the computer, especially when the network is always on (like cable and DSL connections). High Definition Audio audio may also cause the computer to wake from sleep mode. Use the following steps to prevent the these hardware devices from waking the computer:
  1. Click Start c00847244.gif , and then right-click Computer .
  2. Select Properties , and then click Device Manager in the left panel of the window.
  3. Click the plus sign ( + ) next to the device that needs to be adjusted. If you are using an optical mouse, select Mice and other pointing devices . If the computer is using an "always-on" connection, click Network Adapters . To check the high definition audio, click Sound, video, and game controllers .
  4. Double-click the name of the device to open a Properties window.
  5. Click the Power Management tab, and remove the selection from Allow this device to wake the computer . Figure 6: Power management tab for a mouse c00851648.gif NOTE: If you prevent the mouse from being able to wake the comuter, wake the computer using the Sleep button on the keyboard or from the power button on the front of the computer.
  6. Click OK , close the windows that are open, and then restart the computer.
  7. Click Start c00847244.gif , and select the Sleep/Standby button to see the problem still exists: If the problem still exists, go to the next Step.
  8. Disconnect all non-essential connected devices (printers, scanners, USB drives).
  9. Restart the computer with only the original mouse, monitor, and keyboard connected. If this resolves the sleep/standby problem, one of the connected devices was causing the problem. Replace one device and test to see if the problem occurs again. Continue adding devices and testing until the you find the device that is causing the problem.
If you have already tried all the above steps, you can try the steps below: Many software components start up automatically and run without being seen. Most of these programs are not necessary to the work performed on a computer, but can interfere with sleep/standby mode. For troubleshooting purposes use the following steps to prevent programs from starting when Windows is first opened.
  1. Click Start c00847244.gif , and then type msconfig into the Search field and then press the Enter key.
  2. The System Configuration Utility appears. Click the General tab, select Selective startup , and then and remove the check from Load startup items . c00847247.png
  3. Click OK to accept the changes and restart the computer.
  4. After completing these steps, Windows opens using Selective Startup. A small reminder may appear when Windows restarts. Select Don't show this dialog again and click OK to prevent the reminder from re-appearing every time the computer is restarted.
NOTE: To undo the changes made in this process repeat the steps above and replace the checkmark next to Load startup items .
  • If disabling Load startup items did not resolve the suspend problem, go to the next step.
  • If disabling Load startup items resolved the suspend problem, enable one startup item and test to see if the problem occurs again. Continue enabling startup items, until you find the software task that is causing the problem. Remove or update problem software.
If the problem still exists, go to the next Step. Upgrading the BIOS and keyboard software If the sleep button on the keyboard still does not work, go to the HP Software and Driver Download page , enter your computer model number into the field provided, and install any keyboard and BIOS updates for Windows Vista. Should you require any further assistance regarding this issue or any other computer related issue in future please feel free to contact get back to us, we will be more than glad to assist you.
Regards
Malik Khan
Feb 01, 2008 | Microsoft Windows Vista Ultimate Edition
My Toshiba Satellite L305-S5875 always crashes on a cold boot.
Part of the problem is the hybernate function it causes windows to become unstable and eventually will corrupt the windows files making vista unusuable. I strongly suggest the hybernate mode be disabled and you make a backup recovery disc just in case windows crashes. By following what I have recommended and shut down windows when not in use will make a big difference in stability.
Apr 22, 2012 | Toshiba Satellite L305-S5875 Notebook
Downloaded a Internet explored 9,windows home vista basic, turned off to restart.now won't go past window error recovery screen,go back n forth between ,load bar,to,safe mode,safe mode command prompt...
If you have windows vista installation disk just repair by system restore. Get try from safe mode or press F8 and use the option most recent setting. If this doesnt solve then contact your engineer to repair windows......
Mar 12, 2011 | Acer Aspire (AST180-US340B) PC Desktop
Sleep mode wakes up on it's own
turning off all the power saving items does not help this- it just ensures that it doesn't automatically power down your hard drive or shut off power to your monitor automatically when you aren't using it.
May I suggest Hibernation Mode as an alternative? this mode saves everything you are doing to disc and shuts your computer down completely. when you turn it back on, it will restore what you were last doing onto the screen, so you can pick up where you left off.
you can find more information on this and sleep mode from here: http://windowshelp.microsoft.com/Windows/en-US/Help/335c6a5d-0304-4af1-b135-6bf6c124dc111033.mspx#EZAAC
Cheers,
-Demolitio
Aug 03, 2009 | Microsoft Windows Vista Home Premium with...
Vista startup problem due to Daemon tools..
if you have the original windows vista OS cd you can boot up as though you are going to install the OS. It will then list the current windows installations on the system. Click on the one you are having problems with and click repair. This should fix the MBR info and other boot up problems.
Dec 29, 2008 | Microsoft Windows Vista Home Basic Edition
Intel 82562V-2 10/100 ethernet adapter does not turn back on from vista sleep mode
If you're using your system as the Host for the other systems, turn off your sleep mode. The Host should be active at ALL times.
Dec 09, 2008 | Intel Ethernet 10/100 Network Adapter
Windows Vista won't start after sleep mode
Please concider avoidind using leep mode.
Just disable it and use power saving instead.
(start - settings - control panel - power options - click on 'change plan settings and change sleep to never)
Thank you for using agadycom.
Nov 21, 2008 | Microsoft Windows Vista Home Premium with...
Unable to completely restart windows vista home b
If this is a name brand system, you would need to use either the restore CD/DVD that came with the computer or the restore partition on the hard drive that can usually be accessed by hitting something like F12 (depends on your computer). It sounds like you already reinstalled so the restore partition is out of the question. If you don't have the restore CD/DVD, you may be able to order it from your computer manufacturer. Other than that, you will need the installation disks/files to restore everything.
May 06, 2008 | Computers & Internet
Microsoft Windows Vista Home Basic for PC Logo
87 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
