Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
My thermostat has a .8 degree swing temperature
I would like it to have a 2 degree temperature what do I have to do to get it to do that?
  • Honeywell Expert
  • 252 Answers
The Thermostat Wizard is an interactive tool that will guide you through wiring and troubleshooting your thermostat, as well as programming it to the most comfortable settings for you and your family. Simply answer the questions from the Thermostat Wizard to correctly connect, troubleshoot and/or program your Honeywell Thermostat. You can even print the instructions and bring them right to the thermostat to help make things easier.
Go to: http://yourhome.honeywell.com/Consumer/Cultures/en-US/Support/Thermostat+Wizard/
Please rate my answer!
Posted on Mar 12, 2009
Thermostat not holding temp
Thermostats have a swing setting. It can go over a few degrees and drop below a few degrees from your set temperature. This is to prevent it from starting and shutting down the boiler too often. Hope this helps.
Feb 14, 2016 | Heating & Cooling
Am I able to adjust the 'hysteresis' of my digital thermostat?
Some thermostats allow you to change the differential value - that is how far below the heating (or above the cooling) set point before calling for heat (or cooling in the case of air conditioning). The built in 1 degree differential setting provides the most even temperature in the space at the expense of more frequent furnace firing and stopping. Many people prefer this mode as opposed to allowing wider swings in temperature for less frequent furnace firing and stopping. If you wish to change this setting, you'll need to replace the thermostat as it is not user adjustable in this model.
Nov 02, 2015 | Honeywell RTH6350D1000 5/2Day Prog...
What is the mormal temperature swing of a Refrigerator?
What you call temperature swing, is hysteresis. For a refrigerator it only is allowed a few degrees. 1 or 2 up and down. A swing from 32 to 45 is far to big. Unless the factory can prove they advertise these figures. I would never buy a frig like that.
I would contact the dealer and ask him / her to replace the thermostat and if that is not possible to bring another refrigerator.
Something is really wrong with yours.
Jun 11, 2014 | Kenmore Side by Side Refrigerator
I have a Skytech 3301 for a propane stove with some thermostat problems.
Great question! It sounds to me like the Skytech's swing temp setting may be out of whack.
Here is a quick link to the product page with a link to the owner's manual at the bottom if you need: Skytech 3301 Fireplace Remote.
Below is an excerpt on how to check and modify the swing temp settings for the Skytech 3301. (I apologize if the copy/paste formats poorly).
The Thermo Mode on the transmitter operates the appliance whenever the ROOM TEMPERATURE varies a
certain number of degrees from the SET TEMPERATURE. This variation is called the "SWING" or
TEMPERATURE DIFFERENTIAL. The normal operating cycle of an appliance may be 2-4 times per hour depending on how well the room or
home is insulated from the cold or drafts. A smaller "swing number" increases the number of cycles so the room temperature is more
constant. A larger "swing number" decreases the number of cycles, which saves energy, in most cases. The factory setting for the "swing
number" is 2. This represents a temperature variation of +/- 2
0
F (1
0
C) between SET temperature and ROOM temperature, which determines
when the fireplace will be activated. The "SWING" number values are:
1=+ 1
0
F (.5
0
C), 2= + 2
0
F (1
0
C) and 3 = + 3
0
F (1.6
0
C).
SETTING THE TEMPERATURE SWING (TEMPERATURE DIFFERENTIAL)
1. To change the temperature "SWING" setting (1-3), press the TIMER/TIME and DOWN buttons
simultaneously to display the current "SWING" setting in the SET TEMP frame. The letter "S" will
display in the ROOM TEMP frame on the LCD screen.
2. Press the UP or DOWN button to change the temperature differential or "SWING" (1-3). See above
for 1-3 "SWING" temperature valves.
3. To store the "swing number press the SET button or allow 15 seconds to lapse, and the new "swing
number' will be automatically programmed.
MANUAL CHECK OF " SWING" OR TEMPERATURE DIFFERENTIAL
The operation of the factory set "THERMO SWING" can be checked by adjusting the SET TEMP 2
0
F above or below the room temperature.
This will cause the system to turn ON or OFF. Normally the system will only respond to temperature changes every two minutes. Manually
changing the SET temperature will activate the system in less than 10 seconds. IF the "SWING" is changed, then a new room temperature
differential will respond. Factory setting of "SWING" temperature is 2
0
F.
Jan 17, 2013 | Skytech 3301 Thermostatic Gas Fireplace &...
Whats the right thermostat for 1995 lincoln town car
You will get that at the auto repair house. They will get you the one that corresponds to the size of the engine. 180 degrees is common. Buy it here
$17.27
List Price: $20.38
Save: $3.11
  • BESTSELLER
  • Low Price Guarantee
  • In Stock
Quantity
STANT ENGINE COOLANT THERMOSTAT -- 180 degrees Fahrenheit opening temperature; A high quality, direct fit OE replacement engine coolant thermostat; With 90-day Stant limited warranty.
  • Material: Stainless steel
  • Product Fit: OE replacement
  • Quantity Sold: Sold individually
  • Anticipated Ship Out Time: 1-2 business days
  • Opening Temperature Rating: 180 degrees
View more Fits the following 1995 Lincoln Town Car submodels:
  • 1995: Base; 8 Cyl 4.6L; "GAS"
  • 1995: Cartier; 8 Cyl 4.6L; "GAS"
  • 1995: Cypress; 8 Cyl 4.6L; "GAS"
  • 1995: Executive; 8 Cyl 4.6L; "GAS"
  • 1995: Signature; 8 Cyl 4.6L; "GAS
Nov 19, 2011 | 1995 Lincoln Town Car
Thermostat with huge temp swing
It is normal for a thermostat to have a 2 to 3 degree swing, any tighter and it will tend to cycle the heat and cooling ssytem on and off, very hard on equipment.
You can purchase a digital electronic thermostat, the higher end thermostats will allow you to close the swing down to 1 degree, just remember the above, that I stated.
You will need to read the install and owners manual, to figure out how to change the temp swing.
If this has been helpful, please rate the new guy :)
Please get back to me, if you have anymore questions.
Have a great Day.
Sincerely,
Paul Gibson
Apr 06, 2010 | Heating & Cooling
Hi i have a room thermostat with 4 programs per day on it. in the book it doesn't say if program 2 & 4 are the off times and if 1 & 3 are the on times. the thermostat was bought from wolseley....
On and off is determined by what temperature you set each program for. Example: 6 am - 70 degrees, 8 am - 65 degree, 4 pm - 72 degrees, 11 pm - 65 degrees. You can set the thermostat to fit your schedule and temperature preferences.  Good luck.
Jan 08, 2010 | Heating & Cooling
When this thermostat is in the HOLD position, which cancels the programmed feature, I set the temperature to 72 degrees and the furnace runs until that 72 degree temperature is obtained. Now the thermostat...
If you still have the instructions for the thermostat, then it will show you how to get into the menu and set the swing on the temps. I would try to explain off the top of my head, but its actually quite a bit off numbers to remember. Hope it helps somehow.
Dec 29, 2009 | Honeywell Focus 6300B 5-2 Days...
Carrier Comfort 13 Puron model 24ACA3 / FV4NB006 installed 3/18/08 no longer cooling. Carrier AC1-100 Thermostat checked per manual - all default settings intact. Test override did not turn unit on though....
Verify 24 volts at the low voltage transformer inside the air handler. If it is OK, jump out the red/green and yellow thermostat wires. If everything comes on, replace the thermostat.
Jun 07, 2009 | Carrier 38CKC036 Air Conditioner
My heat is turning on but the fan isnt working. my honeywell thermostat is showing a flame and a blinking battery, and i know nothing about this thermostat, we just moved in . Can u help?
This is not a PC problem
Symptom
Heating comes on, but sometimes it
gets too hot, sometimes too cold.
Neutral not connected
Cure
Check wiring in room thermostat. Look for a
connection to the Neutral terminal (N 2 on
the Honeywell T6060, T6160, and T6360).
Make sure that it is connected (check
continuity).
If there is no neutral available, replace with a
two-wire thermostat, e.g., CT200, CM61 or
CM67. These will also offer extra energy
savings, (Without a neutral connection, the anticipator within the room thermostat does not work,
so the temperature control reduces from ± ½ºC to ±3ºC. People can feel a six degree
temperature swing. Then, if they try to adjust the room thermostat to overcome the
problem, the temperature swings become even worse.)
Mar 16, 2008 | Computers & Internet
Heating & Cooling Logo
646 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
