Question about Dell Processor fan 530
When i start my pc it says alert.cover was previously removed
    President:
  • 2,692 Answers
Go into the BIOS and see if you can reset it from there. You had the side off and the intrusion switch was activated?
Posted on Mar 12, 2009
Cover was previously removed
you can go into the bios and one of the settings is 'cover remove alert' or similar words. you can give it 3 settings: on, off, clear
to stop the boot warning u must set this to CLEAR and save&quit.
then you must go in bios again and choose if u want the feature ON or OFF
Nov 19, 2013 | Dell OptiPlex GX260 PC Desktop
I have a Dell Precision 450.I am getting a "Previous Voltage Failure" alert. How to turn of this power up aler?
If you are still getting it then either your CMOS battery has failed, or your computer power supply has failed,
Apr 15, 2013 | Computers & Internet
I have a dell and it said that i had a chassis intrusion I dont know what it means nor what to do help
That just means the case of the desktop was opened by someone.
http://phubner.eng.ua.edu/Files/Optiplex%20GX620/advfeat0.htm#wp1124663
Security Chassis Intrusion Detection note.gif NOTE: When the administrator password is enabled, you must know the administrator password before you can reset the Chassis Intrusion setting. This feature, if installed and enabled, detects that the chassis was opened and alerts the user. To change the Chassis Intrusion setting:
  1. Enter system setup.
  2. Press the down-arrow keys to move to the System Security option.
  3. Press <Enter> to access the System Security option's pop-up menu.
  4. Press the down-arrow key to move to the Chassis Intrusion setting.
  5. Press <Enter> to select an option setting.
  6. Press <Enter> again after you update the option setting.
  7. Exit and save system setup.
Option Settings
  • On - If the computer cover is opened, the setting changes to Detected, and the following alert message displays during the boot routine at the next computer start-up:
Alert! Cover was previously removed.
To reset the Detected setting, enter system setup. In the Chassis Intrusion option, press the left- or right-arrow key to select Reset, and then choose On, On-Silent, or Off.
  • On-Silent (default setting) - If the computer cover is opened, the setting changes to Detected. No alert message appears during the boot sequence at the next computer start-up.
  • Off - No intrusion monitoring occurs and no messages appear.
May 27, 2012 | Dell OptiPlex GX620n PC Desktop
Opti plex gx110
the cover being removed is a warning you can turn off in bios. if hard disk 0 failed you can check bios and make sure hd0 is still marked as your boot device, you should also open up the case yourself and make sure a cable has not gotten unplugged or moved. make sure both the power and data cables are plugged in if it's sata. if it's IDE make sure that the serial cable and the power plug from the PSU is plugged in. if it still doesn't work you can try a different plug from the PSU. if none of that helps you can download hirens boot cd or ultimate boot cd, boot to the disc and there are hdd diagnostics you can run to find out the actual problem. good luck!
Jan 31, 2012 | Dell Computers & Internet
Alert cover was previously removed
take battery off mother board and put back in .
Feb 06, 2011 | Dell OptiPlex GX260 PC Desktop
My Desktop Dell Optiplex GX200 computer says Alert! Cover was previously removed. Strike F1 to retry boot . F2 for setup utility. I never opened my computer and when I click F1 it doesn't do anything but...
If it is not keeping time then you need to replace the computers clock battery. The battery is a cr2032 battery usually.
follow the below link for instructions on how to do that.
http://support.dell.com/support/edocs/systems/opgx200/en/sm/index.htm
Sep 01, 2010 | Dell OptiPlex GX200 PC Desktop
02 CRV:When my lights or keys alert does not tell me.
I had the same problem with the lights alarm on my 2002 CRV. The alarm is linked in to the door open switch on the drivers side. If you open the door, about half way down on the centre post you'll see a rubber covered push switch. This is held in place by a single phillips screw. Remove the screw and gently pull out the cover. On mine, the wires had become unclipped from behind and just had to be reconnected (push fit).
Apparently this is a fairly common problem caused by the seatbelt being caught in the door and catching the switch.
Mar 25, 2009 | 2002 Honda CR-V
Fan Malfunction??
Sounds like a heat issue, pop the side of your case open and turn on the PC, are there fans not moving? Take a close look at your processor fan if there is one.
Jul 10, 2008 | Dell Dimension B110 PC Desktop
Computers & Internet Logo
102 people viewed this question
Alun Cox
