Spin wont get up to full speed and it stops after a few goes
Just had a blocked pump - pump unblocked and it works through all the cycles but when it gets to spin it wont get up to full speed. It will try but gives up after a few goes.
  • 15,935 Answers
It appears your Pressure Switch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
No fast spin at end of cycle
You may have burned up the motor's starter windings. About the time it eases up to speed, the motor overheats, and shuts off. Five or so minutes later, the overheat switch resets and it attempts to start the spin cycle over.
Jun 02, 2015 | Washing Machines
Why my washing machine will start the wash cycle but will not spin or rinse?
the drain pump is probably blocked or overheating, when it starts beeping which lights are flashing reading from right to left e.g. 1,3,5 also what is the model number?
Aug 17, 2014 | Fisher and Paykel Washing Machines
Wont adavace after wash cycle like its stuck replying back
Hi just read your posting. The problem appears to be your drain pump is either blocked or faulty.If you would like I can guide you throe the removal of the pump. The reason it does not reach full spin speed is there is still water under the bowl slowing it down.It is impossible to drain the machine by hand completely.Please reply If you require extra help on the pump removal.
Jun 07, 2010 | Fisher Paykel EcoSmart GWL15
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Hoover 750 l top loading .......wont spin proporly
check the lid switch its not working or its already cracked open
Dec 15, 2009 | Washing Machines
Hoover AM1100 Washing machine, wont final spin.
The noise, is it a grinding noisy like worn bearings?
put the washer on drain only - is the pump working ok, take the filter out to see if it is turning ok, does that make a strange noise?
If the pump is fine, its back to that noise, it could be be a faulty tacho on the motor ( regulates the spin speed) or motor bearings - has the motor spindle a lot of play on it?
Let me know how you get on and good look!
Nov 09, 2009 | Washing Machines
Top sprayer wont spin . dishwasher goes through cycles and only partially cleans. bottom sprayer does spin.
The sprayers are not powered but rely on the water pressure to spin them. If it's not spinning it could be
the spinner isn't engaging in the top rack as you slide it in
blocked jets on the spray arm
blocked feedpipe to the spray arm
faulty pump
Most dishwashers are fairly easy to dismantle to check the first few
Jul 02, 2009 | Maytag Dishwashers
Washer will not drain after wash cycle or the spin cycle
check to see if your pump is slightly plugged with a sock or ?
Your top loader should pump out in about a minute and a half when totally full of water.
Aug 11, 2008 | Whirlpool GSC9455 Top Load Washer
Bosch Nexxt 700 spin problems
yes it could be normal if the balance control senses that the load is uneven however the same problem could be caused by a blocked filter or blocked sump hose.
Dec 30, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Maytag performa pye/g2200,3200
when you say the drum wont spin even manually. Do you mean the drum is too stiff to turn by hand? If so the bearings may have seized up solid. If the drum is free to turn by hand, the pump may be blocked, or burned out & not allowing the water out. If so the circiut wont allow the machine to spin. If thats the case, unblock or replace the pump
Oct 20, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
