Question about Motorola Mobility Z9 Cellular Phone
Setup Speed Dial on Motorola Z9
I just got my replacement Z9 and I don't remember how I set up the 2-9 speed dials.  Help?
Go to entry in address book, select Options > Add to Speed Dial then Select Position.
Posted on Apr 22, 2009
How do you set up speed dial on motorola EX431G
Wow! No answer since 1/16/13 - 2+1/2 years. At this point don't know if it helps but...
Menu - Contacts - Options - Phonebook Settings - Speed Dial. Set status on and from there seems pretty intuitive to me.
Jan 16, 2013 | Straight Talk Motorola EX431G Cell Phone
How do i operate speed dial on razr
The user manual for the Moto Razr V3 is at: "V3 GSM Motomanual" Motorola http://www.motorola.com/mdirect/manuals/V3c_9496A74O.pdf
Pages 68-69 of the manual (which correspond to pages 70-71 of the PDF file) state: "Calling With 1-Touch Dial To call phonebook entries 1 through 9, press and hold the single-digit speed dial number for one second. You can set 1-touch dial to call the entries in your phone memory phonebook or the SIM card phonebook: Find the Feature M> Settings > Initial Setup > 1-Touch Dial Press To 1 S scroll to the location you want 2 SELECT (+) select the location" Page 8 (page 10 of the PDF file) indicates that the symbols (represented by "M>", "S", and "SELECT (+)") mean the menu key, 4-way navigation key, and SELECT. Page 51 (pages 53 of the PDF file) explains how to store phone numbers in the phonebook -- which you can then call with 1-touch dial.
Aug 24, 2011 | Motorola Mobility RAZR V3
How do I set up speed dialing on my phone DECT1560 ?
ou can save up to 8 phone numbers in your speed dial book. The speed dial keys go from 2 to 9. When you place a call, our system prompts you to "enter the phone number you wish to dial". You just press the appropriate speed dial key followed by the pound sign (#) and your call goes through. No long numbers to enter any more!
If you set a speed dial for our access number on your phone machine, you have to press three keys only to complete a dial - as easy as "1-2#"! That's it!
For example, you can set your parents' phone number as speed dial key 2 and your friend's number as key 3. After dialing the access number from your phone, you will press 2 then # to reach your parents, or press 3# to reach your friend. Nothing could be easier!
Speed Dial set up Instructions:
Dial the access number, wait for prompt.
Enter PIN number, wait for prompt.
Dial: "#" "2" "#" [a speed dial number: 1-9] "#" [destination number] "#". The system will confirm the number.
Example: [#] [2] [#] [5] [#] [011-888-88-88-88-88] [#]
Use Speed Dial:
Dial: [speed dial key (1-9)] "#"
Hope this will help to solve the problem....
Aug 18, 2011 | Uniden Cell Phones
How do I send one fax to multiple receipents?
you need to set up a group to send to. So if the group is always changing this may not help much.
Groups allow you to send the same fax message to multiple numbers (broadcasting). You can store the Groups on your One-Touch keys or SpeedDial locations and then broadcast by pressing a One-Touch key and Fax Start or by pressing Search/Speed Dial, the three digit location and FaxStart. First, you will need to store each fax number you wish to includein your Group as either a One-Touch or Speed Dial number. Then, you can combine these numbers into a group. Finally, you can have up to six Groups, or you can assign up to 131 numbers to one large Group. Each Group uses one One-Touch key or Speed Dial location. To set up a Group, please follow these steps:
1. Press Menu, 2 (Fax), 3 (Set Auto Dial), 3 (Setup Groups).
2. Press the One-Touch key on which you wish to store the Group or pressSearch/Speed Dial followed by the three-digit Speed Dial location where you wish to store the Group. The LCD will read SETUP GROUP:G0 ENTER & SET.
(from the Brother manual)
Nov 18, 2010 | Brother IntelliFax-4100e Fax
How to delete and program in speed numbers for fax
Create speed dial entries for fax numbers that you use frequently. The number of speed dial entries you can set up depends on the HP device. For more information, see the specifications for the HP device.
expanded.gifTo manually create a speed dial entry 1 In the HP Solution Center, click Settings, point to Fax Settings and Setup, and then click Fax Speed Dial Settings. 2 Click New Entry. 3 In the Speed Dial Settings - New Entry dialog box, type a name and fax number, and then click OK. 4 In the Speed Dial Settings dialog box, click Save. The entry is stored on the HP device.
Note If you are creating a speed dial entry for a networked HP device and you are unable to save the entry, another user on the network might have accessed the same speed dial. Wait a few minutes and try to save the entry again. expanded.gifTo create a speed dial entry from the Address Book 1 In the HP Solution Center, click Settings, point to Fax Settings and Setup, and then click Fax Speed Dial Settings. 2 Under Address Book, click Select From. 3 In the Address Book dialog box, select one or more names, and then click OK. 4 In the Speed Dial Settings dialog box, click Save. The entry is stored on the HP device.
Sep 11, 2009 | HP Office Equipment & Supplies
STEPS NEEDED TO PROGRAM SPEED DIAL
For speed dial go to Main Menu >> settings >> initial setup >> Speed dial >> Phone Memory.
Than transfer numbers which you want to assign as speed dial in Phone memory.
Goto particular contact and edit the number and assign it as Speed dial.
May 20, 2009 | Motorola Mobility RAZR V3
Vu 204..new phone, speed dial does not work, goes to verizon wireless message which says call cannot be completed as dialed. Checked numbers they are OK, also happens which #1 for speed dial of *86 which...
I had the same problem and found that the speed dial feature in "settings" is not turned on by default even though voice mail number is pre-programed into the speed speed list. Go to "Settings & Tools/Call Settings/One Touch Dial" and turn the option on.
Cheers,
Don Devine
Mar 30, 2009 | Motorola Mobility VU204 Cell Phone
SETTING SPEED DAIL
Dear rugrats
Please find below the direct download link to the user manual of the V360 phone (PDF file - 5.4Mb Download)
http://www.motorola.com/mdirect/manuals/V360_9495A85B.pdf
At page 45 & 46 you will find detailed information on how to setup the speed dial function of the phone.
Regards
Please don’t forget to rate this solution if it was helpful, it keeps us going!
Mar 01, 2008 | Motorola Mobility V360 Cellular Phone
Speed dial not working
I have done it. I have found a way to chance the speed dial settings on my Samsung D900i.
The following instructions work for my phone but I cannot guarantee they will work for everyone else.
YOU WILL NEED A PEN AND PAPER.
Press Menu > select Phonebook > Speed dial (4) >Select
You should see names assigned to the numbers.
Decide which speed dial number you want to change e.g. 2 Mum Mobile (remember the name)
Press Back > Contact list (1) Select
Type in/go down to that name e.g. Mum Mobile (WRITE DOWN PHONE NUMBER BECAUSE YOU ARE ABOUT TO DELETE IT)
Press Options > Delete (5) > Select > choose Yes > Back > Speed dial (4)
You should now see that Mum Mobile has been replaced with a big number 2. This means that speed dial number 2 is un-assigned.
Press Back > Contact list (1) > Select
Decide who you want to be assigned to speed dial 2 (WRITE DOWN PHONE NUMBER BECAUSE YOU ARE ABOUT TO DELETE IT)
Press Options > Delete (5) > Select > Yes (HERE IS THE WEIRD THING)
Press Back > Create contact (2) > SIM (2) >Select
Type back in the name and number of person you have just deleted > Save > Back > Speed dial (4)
You should see that Speed dial 2 is now the person of your choice.
HOW COOL IS THAT!!!!!!!!!!
Press Back > Create Contact (2) > Select > SIM (2) > Select
Type in Mum Mobile and Number (THE FIRST NUMBER YOU WROTE DOWN) > Save.
That is it, repeat the instructions until you have all the speed dials of your choice.
Hope this helps the many frustrated D900i users out there.
Aug 31, 2007 | Samsung SGH-D900 Cellular Phone
Motorola Mobility Z9 Cellular Phone Logo
124 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
