Question about NEC AccuSync LCD52VM (White) 15" LCD Monitor
Nec monitor nec LC15M monitor model 500P.When turned on green led flashes continuously but no signal, after a minute or two no led all dead.
SOURCE:
SOURCE: nec 700 crt
Not a solution at all, but I'll post that I have a NEC MultiSync FE700 monitor that I purchased back in 2001, and have I been using the monitor since that time. Lately the monitor has been showing signs of 'acting up'. I read on the Internet that CRT monitors generally have a working life of about six years. It may be, depending on years of use, that the monitors are just reaching the end of their life.
Posted on Feb 11, 2008
  • 40 Answers
SOURCE: Monitor does not wake up.
Check the inverter and backlight bulbs.
Posted on Mar 27, 2009
  • 59 Answers
SOURCE: Monitor Not Showing A Picture. Light flashes Yellow and Green.
use the onboard graphics instead of a seperate graphics card (if installed) to test the screen.if it still doesn't work then unplug your monitor from the mains supply and plug in again to reset it. i doubt it's your monitor that is the problem though. but look on the back of your pc for another connection for your screen. the onboard graphics connection is normally vertical near your ethernet port and mouse and keyboard inputs.
please rate me and give me a fixya! if it helped.
Posted on Apr 05, 2009
  • 3 Answers
SOURCE: THE POWER LED (GREEN) IS BLINKING CONTINUOUSLY
power led green is blinking
Posted on Jul 27, 2009
  • 732 Answers
SOURCE: I have no picture when I power on the monitor. The
uopftball, You will need to see some of the longer (6 to 10minute) video clips of "LCD monitor disassembly" / "LCD monitor repair" @ YOUTUBE and understand some basic principles of how a typical lcd monitor lights-up it's LCD glass panel. As for being the "same" concept as a laptop, Yes! and NO. Do you know anything about how the fluorescent lamps are lit on the rear side of the lcd panel? Changing a lcd on a laptop is not same as inspecting and repairing a switch-mode-power-supply or CCFL inverter (electronic ballast) power supply. The hardest part of monitor disassembly is removing the plastic rear cover from the plastic front bezel. There are usually 2 or 3 printed circuit boards( 3 in older) Inspect the SMPS for frosty looking COLD solder joints and bad electrolytic filter capacitors (swollen and possibly leaking) Pics can be viewed @ www.ccl-la.com/badcaps.htm and all over the net. let me know what you find inside the metal ventilated covers on rear of lcd panel. 12fixlouie
Posted on Dec 09, 2009
Kds k917s monitor won't turn on green power light flashes on when plugged in
check the vga cable which get loose connection then the signal from pc not recognized.
Dec 25, 2012 | NEC MultiSync Computers & Internet
I have a NEC PlasmaSync 42MP02. When I turn it on, there's a click the standby LED changes from red to green, but then goes back to red again. Nothing appears on the screen, it remains dark.
Monitor is not receiving the video signal. Check the video connection cable at the back, also test the monitor on a different computer.
Jul 05, 2008 | NEC Televison & Video
Monitor has no picture, repeatedly tries to cycle ON but can't
sounds like power board failure. You can disconect power lead for 30 minutes and try again but it does sound like end of life
Feb 04, 2018 | NEC Mitsubishi Diamond Pro 2040u NF...
CRT Monitor power led is green then becomes yellow. The monitor is blank or black. Pls. help.
Signal from Pc is weak and may indficate a failing video card or a loose connection
Aug 02, 2009 | NEC MultiSync FE700M (White) 17" CRT...
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
NEC 17'' Multisync CRT monitor does nothing when turned on
the green is working ok but orange is usually waiting for an input from the pc (no input signal)
Mar 08, 2009 | Computers & Internet
61MP1 turns off after 5-10 minutes
Ryan
I have a 61MP1 that wont turn on. I get the green flashing light to signal power but nothing happens with the plasma. You seem to know a fair bit. A guy in UK said he'd supply a new power board for $500 but wants my old one in return. Sounds like it might be something I can fix here. Any suggestions. Barry
Aug 02, 2008 | NEC PlasmaSync 61MP1 61 in. Television
Nec 700 crt
Oct 20, 2007 | NEC MultiSync FE700 17" CRT Monitor
Dell P1110
Hi, The part where you see some color bars and blinking green led is what we call MONITOR SELF TEST. A diagnostic pattern consisting of four colors (red, green, blue and white) appears, and the LED flashes slowly. this happens when signal cable from the monitor is disconnected from the tower and leaving the power chord for the monitor plugged in. If the monitor works properly on a different computer. then its a problem with the computer's video card sending out signal. im 85% sure that its a problem with your video card.
Oct 02, 2007 | Dell UltraScan P1110 21" CRT Monitor
NEC AccuSync LCD52VM (White) 15" LCD Monitor Logo
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Thomas F. Schneider
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
